09-23-2017, 09:48 AM | #1 |
Rep 93
Not Really Liking JB4
Hey guys new to the forums here and just wanted to give my thoughts on the jb4. I have a 16 328 that i inherited from my wife. I ordered intake, catless dp and ic pipes with the jb4. So far I have only gotten the jb4 and installed it couple days ago.
At first I was really impressed with both map 1 and 2. Very noticeable difference, car feels very strong all the way through redline. But then i started noticing inconsistencies in performance and little hiccups sometimes between 3-6k rpms. I gotta say its not confidence inspiring. I cant tell without logs but it feels like it might be pulling timing, might even be running too lean. So ill probably be returning it and going with one of the other options. |
09-23-2017, 09:56 AM | #2 | |
Rep 239
09-23-2017, 10:19 AM | #3 | |
Rep 93
09-23-2017, 02:25 PM | #4 | |
Rep 239
I actually run map 5 which is an adaptive map. My car runs smooth and surges the same way in each gear. Definitely datalog so you can properly asses your setup amd see if it's even functioning properly. Test with 91, 93, and 100 octane if possible. Also make sure to calibrate the jb4. It behaves differently depending on conditions such as whether and supporting parts. So the way to calibrate it is to put it in 3rd gear and fully depress the pedal from about 2500 rpms all the way to redline. Do this at least three times and the car should pull much smoother. The jb4 can actually take a little while to settle in. Make sure to put in the proper downpipe too (go catless), it's necessary to properly run stage 2 jb4. I wouldn't do maps 1 or 2 without one. Last edited by BMWtight2me; 09-23-2017 at 07:04 PM.. |
09-23-2017, 07:34 PM | #5 | |
#gotboost
517
Rep 861
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
09-24-2017, 04:04 AM | #6 |
Rep 239
OP -- you should datalog 3rd gear pulls in map 1 and post them along with weather temp and octane.
09-24-2017, 08:03 AM | #7 |
Rep 93
I know when i get a chance I will datalog. I just went to map1 and it feels much slower but still has that hesitation. Im just going to return it while im still in my return window.
09-24-2017, 01:50 PM | #8 |
#gotboost
517
Rep 861
Map 0: JB4 disabled
Map 1: Additive target, around 4psi over stock. Map 2: Additive target, around 6psi over stock. Suggested for those with 93 octane and bolt on modifications. Also good for small E85 mixtures. Map 3: Progressive WMI mapping. Map 4: Stock performance with JB4 active for logging only. Map 5: Autotuning map, absolute target of 11-17psi based on octane and conditions. Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only. Map 7: Race gas map. Absolute target of 18.5psi. Requires straight unleaded race gas.
09-24-2017, 02:46 PM | #9 |
Rep 115,980
09-24-2017, 02:47 PM | #10 |
Rep 115,980
09-24-2017, 03:52 PM | #11 |
Rep 463
Is map 2 or map 5 more agressive/powerful? Say if we ran 2 gallons of e85 in a full tank of 93octane, which map is better to run (with flex wires)?
09-24-2017, 04:15 PM | #13 |
#gotboost
517
Rep 861
You would want to run map 2. Map 5 is for 320i's I believe..
09-24-2017, 11:28 PM | #14 | |
Rep 216
Drives: F30 335i PWG
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
09-25-2017, 07:31 AM | #15 |
Sedan Driver
389
Rep 1,018
exactly. good to hear lots of 335i owners here tho
N20/N26 mapping as of now: Map 0: JB4 disabled. Map 1: PWG models absolute target 21psi peak, EWG models additive 4psi peak over stock. Map 2: PWG models absolute target 22psi peak, EWG models additive 6psi peak over stock. Map 3: Progressive Methanol Injection. Requires BMS methanol kit or BMS FSB for meth pump control. Map 4: Stock performance, JB4 on Map 5: Absolute targeting map with a peak boost 17psi. Suitable for 320 & 520 applications. Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only. Map 7: Race gas absolute target map. Peak boost 23psi. This is a fairly aggressive map and increases engine damage risk. Use with caution.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
09-25-2017, 07:49 AM | #16 |
Rep 504
i know this may be a silly question too, but is the car up to temp? I know for me i had inconsistencies with just the JB1 but significantly more noticable when cold. Even with no piggyback, it's 'ordinary' when not up to temp.
Again.. probably a silly question, but just thought I'd clarify. |
09-25-2017, 07:53 AM | #17 |
Rep 2,957
Make sure the firmware is up to date. Do N20s have PWG/EWG differences like the N55? If so make sure you have the EWG harness
09-25-2017, 08:17 PM | #18 |
Rep 190,750
inconsistency can be due to lot of factors that are not related to the JB4
Why blame the JB4 when you did not even datalog?
feng127.50 |
09-26-2017, 07:11 AM | #19 |
Rep 93
Simple car is super smooth before jb4 and even map 4. Im hardly the firrst person to experience this, while doing some research I found many threads in this forum where people experience the exact same thing.
09-26-2017, 08:09 AM | #20 |
Rep 2,957
Yes but it could also be a simple setting in the JB4 menu that's causing the issue. Could be MAF issue or loose plug or any number of things. Logging will give you your answer.
09-26-2017, 09:58 AM | #21 |
Rep 93
I know man i just havent had a chance to, trust me I wanna dl I just havent had time. Besides I need to install windows. Its not a loose plug or else the same thing would happen in map 4.
09-26-2017, 10:11 AM | #22 | |
Rep 3,211
I think yer doing the right thing returning it and going with a simpler solution or waiting for a flash |
