BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19" F32
      09-15-2022, 09:47 PM   #1
jnj2455
Drives: 440i 6MT/RWD/MPPSK/2VF
19" F32
Looking at a set of wheels, which have the following specs for my F32, RWD, stock M adaptive dampers:
Wheel sizes are
-19x8.5 +30mm front, w/ 235/35/R19 tire
-19x9.5 +35mm rear, w/ 275/30/R19 tire
I know nothing about offsets but I do believe the rear set in particular is a bit on the aggressive side. To that end, I'm wondering if I give it a bit more sidewall, will I have rubbing issues?
AKA change to:
Fronts = 235/40/R19
Rears = 275/35/R19
      09-16-2022, 12:49 AM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
235/40/19 + 265/35/19 is a better combo for the width, offset, appearance
J555568.50
      09-16-2022, 07:53 AM   #3
jnj2455
Thank you. Do you think the 265 width will cause stretch? Because based on what I can see the 275 is kinda stretched as is. Or will more sidewall offset that?
      09-16-2022, 11:28 AM   #4
alohasurftoad
Here is 265/35/19 mps4s on 9.5 ET45. imo it is not stretched nor bulged, but perfectly fit on 9.5".
also, your planned ET35 will be poking 10mm more than the photo
jnj2455367.50
