09-30-2015, 03:34 AM | #1 |
Rep 286
Automatic Transmission
This may be a silly question but...
Is the BMW 8AT Transmission designed to sit in Drive at all times? Assuming you have DESELECTED the Auto Start Stop system, I never know if I should shift to N at the Traffic lights or not. As the footbrake is released whilst in D you do feel a slight "bump" as the transmission feels as though the gear is selected. I would be really keen to hear anyone's views. |
09-30-2015, 03:43 AM | #4 |
Rep 13,043
Drives: BMW M340I G20
If I leave mine in D I don't feel any bumps,when taking off.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
09-30-2015, 04:43 AM | #5 |
Rep 1,503
Leave mine in D with the handbrake on when waiting at traffic lights, junctions, roundabouts etc.. If I know I'm going to be stood for a long time I put it in P and apply the handbrake. Never use stop start, turning it off is part of my startup routine.
09-30-2015, 07:19 AM | #6 | |
Rep 11,292
Yes also leave it in D all the time. Only time it comes out of D is for reversing - or when I park it on the drive.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
09-30-2015, 07:47 AM | #7 |
Rep 2,444
Drives: 2018 630iGT sport
09-30-2015, 08:09 AM | #8 |
Rep 738
I just push the 'P' button to put it in Park when I stop. If I'm on the flat, that's it. If I'm on a slope, I'll also put the hand brake on.
Are you saying that if you put the hand brake on while in 'D', it disengages the gearbox?
X3 M40i Carbon Black
09-30-2015, 10:09 AM | #9 |
Rep 74
09-30-2015, 10:13 AM | #10 |
Rep 1,503
I think it can be coded to stay off all the time but from factory it's a turn it off every time situation i'm afraid.
09-30-2015, 10:17 AM | #11 | |
Rep 15,858
Shouldn't really be any bump as such, as you are still in gear. What is happening, holding on the footbrake NIC engages, the Torque Converter is off loaded (almost like a neutral position). Drag is reduced to something like 10% of conventional TC drag. You could be feeling that transition. The first generation of ZF 6HP gearboxes did suffer from a snatch, one reason was the NIC strategy, sorted with software. Not read of any issues with the ZF 8HP series boxes. HighlandPete |
09-30-2015, 01:40 PM | #13 |
Rep 2,444
Yeah, it can be coded to be off all the time.
10-01-2015, 03:34 AM | #15 |
Rep 1,034
10-01-2015, 08:19 AM | #16 | |
Rep 2,246
I was going to code t out but don't find it too intrusive if I'm honest. |
10-01-2015, 08:56 AM | #19 | |
YOLO
440
Rep 2,854
Other than that , at lights I leave it on & place car in park |
10-01-2015, 08:57 AM | #20 | ||
Rep 199
10-01-2015, 09:00 AM | #21 |
Rep 1,034
With a manual I would say it is no problem at all, put it in neutral and take foot off the clutch to use it, or leave it in gear with foot on the clutch if you don't want to use it so you can choose dependent on the situation. With an auto it is different and you don't have the choice. At traffic lights it is not an issue, stops at the lights and restarts as soon as you take your foot off the brake, the problem I found was at roundabouts and give way junctions. If you come to a complete stop the engine shuts off, which means if you want to pull out quickly there is a delay. Until I coded it off, I found myself creeping up to the junction trying to make sure I didn't come to a complete stop which wasn't always possible. Much easier with it turned off.
