10-24-2016, 07:40 AM | #1 |
Rep 1,381
Side blades/extensions without drilling?
Side skirt extensions, blades.. whatever you like to name them.
Does anybody have a solution to fitting them without drilling them into the bodywork? I just recently had the MP vinyls replaced under warranty and they are nice and fresh, so I don't have any plans on making any destructive moves just yet. Will some strong adhesion tape be good enough?
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
10-24-2016, 10:58 AM | #2 | |
Rep 312
10-28-2016, 11:17 AM | #3 |
Rep 1,739
As mentioned, all the holes are on the underside and are drilled into the non-metal skirts. Seeing as how they are going to see the worst in terms of water and road dirt (and salt, snow and ice if you get it) I don't think you want to just use tape. The mating surfaces aren't perfectly flat and aren't all that wide making tape less secure. You could use betalink but that's worse than holes I think.
