BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Help, dealership could not aim my headlights
      07-06-2017, 09:22 PM   #1
Kevin_Trxn
Drives: '17 340i
Previous owner messed with headlights and they pointed extremely high and because of that I got high-beamed by every other passing car at night. They would literally hit the top of highway signs
I took it back to the dealership that I bought the car from (1hr away) because my local dealership (10mins away) would not do it for free. Local dealership wanted like $200
After a few days I got my car back and drove it at night. The head lights are lower, but are definitely not reset to factory.
I don't really feel like driving an hour to take it back to the dealership for them to half ass it again.
I need help re-aligning my headlights!!!!
If you could post pictures of your headlights pointed at a wall. Measure the approximate distance of your front tire to the wall and measure the hight of your beam on the wall and the distance between the two peaks.
Or is there a diagram/guide out there that can tell me all this? =\
I have the LED head lights pictures below show how my headlights are currently.
One from closer range and one from further range.
You can see that my passenger side is definitely out of line.
      07-06-2017, 09:24 PM   #2
Kevin_Trxn
Drives: '17 340i
Passenger side up close
      07-06-2017, 09:39 PM   #3
Katin
Drives: 2015 328i XDrive
http://f30.bimmerpost.com/forums/sho...d.php?t=742204
Scroll down to page 4. The thread is old and some of the pics have disappeared.
It is unbelievably easy.
      07-06-2017, 09:49 PM   #4
ChubbyWilly
ChubbyWilly's Avatar
Drives: 2015 BMW 335i
This looks normal to me. Park on a flat road about 25 feet away from a wall and measure how high they are. Measurement on the wall should be ground to headlights - 1 or 2 inches.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
      07-06-2017, 09:56 PM   #5
Kevin_Trxn
Drives: '17 340i
Bad quality pic. But if you look, you can see there is a random step down just the right of the peak.
And if you look at my first post you can tell that the passenger points an couple inches higher than the diver side
Interesting 2 inches 25 feet out?
      07-06-2017, 09:56 PM   #6
Kevin_Trxn
Drives: '17 340i
Thanks!
      07-06-2017, 10:18 PM   #7
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
The passenger side should be higher than the driver's side to keep from blinding on coming drivers, and to also provide you more light down the road on the passenger side.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg
2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
      07-06-2017, 10:27 PM   #8
Kevin_Trxn
Drives: '17 340i
There's already a difference in height in the cut off
At a distance when the beams over lap then yes the light on driver side should be lower than the light on the passenger side
Up close they should be relatively the same height
      07-07-2017, 08:48 AM   #9
odus
Call me daddy
odus's Avatar
35
Drives: dont worry
Like others have said the driver should be lower than passenger these don't seem too bad. Also, the BMW projectors don't have the best cut off so that doesn't help.
      07-07-2017, 05:32 PM   #10
GCinFLA
You title is click bait and false.
The Dealer COULD aim your Headlights, you just didn't want to pay them to do so.
      07-08-2017, 01:22 AM   #11
Kevin_Trxn
Drives: '17 340i
Uhh i took it to a dealer to have them aimed and they could not aim them correctly back to factory. So I drove up once already, but like the title could not get them back to factory.
And my local dealer wants me to pay to have it redone a second time and the other dealer is far
All Im asking is for help to aim the headlights myself in order to save myself some time and money.
Thanks for your input
      07-08-2017, 01:31 AM   #12
beto_L.A.
beto_L.A.'s Avatar
Drives: 2020 G20 330i
The xenon headlights on my 2015 F36 looks similar to your picture. Passenger is a bit higher...
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK).
      07-08-2017, 05:25 AM   #13
x5mad
x5mad's Avatar
Drives: iX 40
bmw  [0.00]
You can definitely adjust yourself.
If you have LED headlights make sure that the light switch is in position 2 and NOT auto whilst doing the adjustment.
For vertical adjustment, anti clockwise will raise and vice versa.
If the beam does not move when you are turning the manual adjusters in the engine bay then you will need to adjust the horizontal first as this will then free up the mechanism to allow vertical adjustment.
      07-08-2017, 07:42 AM   #14
COKen
COKen's Avatar
981
Is the dealer telling you they can't aim your lights back to factory specs, or is it your opinion that they can't put them back to factory?
      07-08-2017, 09:09 AM   #15
Kevin_Trxn
Drives: '17 340i
Alright, my wording is confusing. But to clear this up, they want to try again because they half assed it the first time. Im sure if they spent more time the first time they could do it.
But I dont have the time and dont want to drive that far again for them to try again.
And I dont want to pay my local dealer for something that the other dealer should have done before I got the car
Can everyone just drop the details.........
I got the info I needed thanks to those that offered help.
      07-08-2017, 09:10 AM   #16
Kevin_Trxn
Drives: '17 340i
Thank you!
      09-20-2018, 10:16 AM   #17
sledge149
Black Caps
I've seen the post you reference before. But I have a slightly different issue. I can adjust the up and down position just fine, but the horizontal adjusters have a black "cap" on top of the white adjuster. I'm not sure how to remove that cap to get to the screw, or hex, or whatever it is. I feel like if I try too hard, I might break something.
Have you, or anyone, heard of a black cap over the horizontal adjuster before?
      09-21-2018, 02:27 AM   #18
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
You just pop it off (go to 9:30 of the video):
