01-23-2016, 03:00 AM | #23 |
Rep 240
Yeah it sounds pretty dangerous if you were in a situation that required to you get out quick. It just happens randomly you never really know when it will happen.
2013 BMW 335I M-Sport: Premium, Cold Weather, Drivers Assist, Tech, HK, Sports Auto
01-23-2016, 07:33 AM | #24 |
Rep 49
This just started happening to me in my e90. The button to unlock all doors works every time but sometimes pulling the handle inside just makes the peg go up but then goes back down when I release without clicking in the unlocked position.
01-24-2016, 01:35 AM | #26 | ||||||
Rep 3,870
i think i know why
What about cars like myself that are now out of warrantee? Will BMW fix that for me? I am beyond my 50k miles... Quote:
The latest situation for me is: For a couple of months now, the little lock knob indicator by the window door no longer goes up. It is "stuck" in the lock position. But i no longer have the hesitant opening from the inside... In my case, i think the link mechanism from the door actuator to door lock indicator (by the window) must be broken (loose). But this fact doesnt prevent me from locking or unlock the car by any means. If anything its even easier for me to get out of the car. The cabin unlock button can be used to lock and unlock all door as usual. The keyfob can lock and unlock all doors as normal. Other than the little door lock indicator not popping up on the drivers door, but all doors do lock and unlock as intended. Ever since that door lock indicator is not working anymore, i never had the hesitant unlock situation when opening the door handle from the inside (2 pulls and i am out). I am tempted to one day disassemble my driver door and see what got disconnected or could have made the door handle opening not so smooth... I think you will eventually see the same issue as me.
01-25-2016, 12:57 PM | #27 |
Rep 14
update with video
Hi Everyone,
Thank you for all the input. I decided to take a video of the issue when it happened this weekend just to clarify the issue. It seems like a bigger issue than I thought. Anyways, have a look but at the end when I press the unlock button on the center console, the door finally opens. [u2b]https://www.youtube.com/watch?v=IAttxl7pmow[/u2b] https://www.youtube.com/watch?v=IAttxl7pmow |
01-26-2016, 10:40 PM | #28 |
Rep 1,369
Guys, it's a bad lock actuator. I know the tech at the dealership. He's swapped out loads of them. I had 3 swapped in my car alone.
The good news? The new actuator is a lot better than the old one. Get it swapped. |
01-27-2016, 03:08 AM | #30 |
Rep 5,087
Mine had a problem with the passenger front door lock, namely, when unlocked with central lock button the lock pin would pop up in slow motion. The SA confirmed the problem and the tech replaced the lock assembly under warranty, and now it works fine. Yours definitely is a defect and should be fixed under warranty.
tex26702411.00 |
01-27-2016, 05:06 AM | #31 |
Rep 826
Drives: 2017 C43 AMG
OP I had the same issue with my 2013 335i. Kit wouldn't unlock when you pulled the first time. The lock would go up and right back down. But when pressing the unlock button on the center console it worked fine.
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
01-27-2016, 08:32 AM | #32 |
Rep 4,445
Drives: '23 X1 28i xDrive
Maybe it will be a class action, and we can all get a $500 voucher towards the purchase of our next BMW; and the lawyers can get 33% of the settlement.
03-01-2016, 08:44 AM | #33 |
A family of bimmers
2745
Rep 7,741
this is happening to my f30 passenger side door. previously had the issue on my e90 and it was the door lock actuator. Its going in this week for this and to see why i have a squeaking in one of the front wheels (maybe the brakes)
03-02-2016, 03:50 PM | #35 | |
Rep 421
03-02-2016, 03:54 PM | #36 |
Rep 247
I had this same issue on my 2012 F30 335 and it was the lock actuators (both front doors). Replaced them and no problems since (going on 10 months now).
03-09-2016, 04:58 PM | #38 |
Rep 918
04-19-2016, 11:40 AM | #39 |
Rep 5
I am experiencing this same issue on my driverside door after two weeks of buying my CPO 13' 328i. Only way to successfully unlock the door is by pressing the unlock button on the dash. I'll be scheduling an appointment to have this taken care of.
04-20-2016, 01:45 AM | #40 |
Rep 97
Drives: F30328i x 2 (yes, 2)
Well known problem
Both replaced under warranty on mine.
04-20-2016, 09:11 AM | #41 |
Rep 1,571
I've have recently begun to experience the same issue intermittently. The operating rod will begin to pop up on the 2nd handle pull and immediately pull back down. I can feel the resistance in the handle as well. The Center Unlock button does unlock the door without fail. Looks like the part # is: 51217202143 according to RealOEM (Approx $171). That is for the drivers side on a 13 335i Sedan w/Alarm and Comfort. Think I'll check by Bentley's for the remove/replace steps.
04-20-2016, 10:10 AM | #42 |
Rep 127
I am seeing this in my car. Dang, Im out of warranty though.
Is there a DIY fix for this?
2012 335i | silver | Sport | Premium | DHP | Lane Departure | Nav
