11-11-2014, 04:36 PM | #46 |
Rep 1,894
No worries, glad it worked out.
Can you make a note of the code? I'd like to remove it tonight. For everyone else the code is unique to Moonshine's NBT. |
11-11-2014, 04:42 PM | #47 |
Rep 1,858
11-13-2014, 10:40 AM | #49 |
Rep 2,808
Anyone else's .torrent corrupted? About 6 files on my Europe 2015-1 download were corrupt...
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
11-13-2014, 10:51 AM | #51 |
Rep 1,858
11-13-2014, 01:07 PM | #52 |
Rep 2,808
Mmm weird - used 7zip to do a integration test and it failed as well ah well a 19Gb download to do again on a 3mb useless BT connection. Happy days.
11-13-2014, 01:18 PM | #54 |
Rep 1,858
11-14-2014, 03:38 AM | #55 |
Rep 2,808
Thanks all for your kind offers. I worked out that part18 was corrupt and simply downloaded that one again. All is good now.
What versions of E-Sys and psdzdata are you using? I have v3.26 and v54.0 respectively. The install instructions are very different to the original post in the coding forum. He uses v3.18.4 and v46.3.
11-14-2014, 04:01 AM | #56 |
Rep 1,894
For extracting the DE\1B file it shouldn't matter which version of esys or psdzdata your using. Only really matters if you are coding.
I'm using the same versions as you have stated. |
11-14-2014, 04:51 AM | #57 |
Rep 2,808
OK just in my version it does not mention any folders like EDIABAS. I don't have a .EST token file either.
Do you have all that set in yours? EDIT: So I have used an older version of E-Sys v 3.23.4 which I have downloaded and that has the EDIABAS and .est token but I am still using psdzdata version 54.0. Unfortunately I cannot connect via VIN as that option is greyed out with the error 'No ZGW available'. Any idea what that means? EDIT2: Used a dedicated VM for E-Sys and all works now. That'll teach me for using my work Windows PC
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 Last edited by gr4z; 11-14-2014 at 07:50 AM.. |
11-14-2014, 12:24 PM | #58 |
Rep 2,808
Thanks to all on this thread my map now is on 2015-1
11-16-2014, 05:44 PM | #60 | |
Rep 1,502
Drives: M4 CP SSII/SS
Thank you to Kitster for his excellent instructions and files. I needed to replace the lookup file for the later one posted up but then all was fine. This has now given me the confidence to try a bit of coding. At least I know I wired the cable correctly and that it connects to the car OK. Thanks again
Current: F82 CP SS/SS
11-17-2014, 02:48 AM | #61 |
Rep 2,808
Think you need a code for that - $50 from some online suppliers.
11-17-2014, 03:10 AM | #62 |
Rep 597
11-17-2014, 03:58 AM | #63 |
Rep 2,808
I thought that was just for the map upgrades? You still needed to 'buy' a code for coding. Happy to be proven wrong
11-17-2014, 04:09 AM | #64 |
Rep 8,081
I have an FSC Code - where can I download the maps please?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-17-2014, 04:10 AM | #65 |
Rep 1,858
11-17-2014, 04:22 AM | #66 |
Rep 1,894
NEXT/Premium Maps (19GB download): http://www.e90post.com/forums/showthread.php?t=995629
