BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > used tires for track use
      08-08-2012, 06:27 PM   #1
pkimM3r
pkimM3r's Avatar
205
i have the 17" base line wheels with pirelli run flats.....looking to track the car and wanted to get some used tires.
thinking of going the same size with higher speed rating.
anyone have any recs on which tires to use? ie. stiffer sidewall / etc.
thanks in advance.
      08-09-2012, 09:13 AM   #2
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
I know we discussed this in PM...You should do your first few track days on the stock tires.
      08-09-2012, 09:15 PM   #3
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
I see you're in Socal, plan on hitting up SOW?
It wouldn't hurt to get something with a bit lower profile; this will effectively change your gearing and increase responsiveness.
Regarding type of tires, are you looking for something pretty aggressive, when it comes to street standards? Swapping out the OEM run-flats wouldn't be a bad idea, so long as you don't get something too sticky to the point that tire grip is a band-aid for poor driving habits.
-Matt
| Z4M Build Thread | @violetnites | flickr |
