07-31-2021, 03:41 AM | #1 |
Rep 5
F36 Trunk button closing problem
Hi
I would appreciate some help. I have a 2018 F36 (440i). Inside the trunk there are two buttons to power close the trunk. The button that closes the trunk and locks the doors at the same time intermittently stops working (and pushing the button does nothing). The other button that just closes the trunk (without locking the doors) always works normally. I first thought it may have been a switch issue and changed it. This has made no difference. If anyone knows how to solve this or has had similar issues please let me know. Thanks. Last edited by maq440; 07-31-2021 at 05:56 AM.. |
08-01-2021, 08:10 AM | #2 |
///M ♥ Recycled Dinosaurs
3216
Rep 1,782
Drives: BMW M4, BMW X5 45e
The close and lock button won't respond if it thinks it can't guarantee that it can lock the car (for example, if one of the doors is open / not closed tightly). What you'd need to check is if one of the sensors for those additional conditions are malfunctioning intermittently.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
08-01-2021, 01:36 PM | #4 |
Rep 5
Thanks for the replies. Since i’ve noticed the issue i’ve been sure to have the key fob in my hand when i’ve pushed the button to ensure its in range.
The doors are all properly closed and pressing the lock button on the key will centrally lock all the doors even when the trunk button has not worked. |
08-01-2021, 03:41 PM | #5 | |
Rep 1,141
Try with the fob further away. |
08-01-2021, 04:07 PM | #6 | |
3216
Rep 1,782
Here's some info on how it's supposed to work based on trying on my own F36: 1. Key lock for all doors and trunk lock+close for all doors will work even if any door (except the drivers door) is ajar when the operation is performed. 2. If the driver's door is open, neither the key, not the trunk lock+close operations will work. Seeing this is the case, your issue may not have to do with door close sensors. How about the theory that the trunk thinks the key is inside? Well the trunk shouldn't allow the basic 'close' operation in that case either. So I'd lean towards it being the switch itself or wiring to the switch. It's also possible you're experiencing an electronics glitch of some sort. You may need to see a service center for this. (I'd try hard-rebooting the iDrive head unit, just to try everything -- press and hold volume button for 30 seconds or so) You may also check if there are any faults stored using Bimmerlink.
08-01-2021, 05:14 PM | #7 |
Rep 842
As someone who does not own a f36 I find it so interesting that it has a button to close the trunk and then another button that closes and locks the trunk
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
08-03-2021, 02:11 PM | #8 | |
Rep 5
I used to have the fob in the same hand I pushed the trunk button with so I guess sometimes it thought the fob was still inside and other times it was just far away enough to activate the trunk and central locking. Now I have the fob further away it works every time. |
08-03-2021, 02:44 PM | #10 |
3216
Rep 1,782
