10-18-2017, 07:03 AM | #1 |
Rep 42
Aircon regas....
Has anyone used the mainstream service places (I.e. Kwikfit) for an air-con regas? BMW are after £100 and aren't local/convenient.
Cheers! |
10-18-2017, 07:21 AM | #3 |
Rep 1,455
A DIY kit isn't ideal as to do the job properly you have to extract all the gas, dry the system then put the correct weight (550g ??) of gas back in.
Costs about £50, in theory the machine does all the work so assuming the right settings are known (the weight should be under the bonnet on a label somewhere) you should be OK. |
10-18-2017, 08:27 AM | #4 |
Rep 314
Kwikfit use the same type of machine as the dealers use I believe. They charge £50 for a re-gas in the summer and £25 for the same thing in the winter so wait a bit longer.
10-18-2017, 08:31 AM | #5 |
Fool
1857
Rep 3,542
I've always used kwik fit for air con re-gassing, they use idiot proof kit that is pretty standard across most places and they're cheap.
I would question why your car needs a re-gas though, unless there's been a leak, it shouldn't need it.
10-18-2017, 12:38 PM | #7 |
Rep 42
Thanks for the replies....
The AC effectiveness has gradually decreased over the last 12 months and I'm also finding that along with an unusual low hiss noise, the stopstart is inhibited whilst the AC is on, turn the AC off and the stop start comes back to life... its only recently started doing this. I'm assuming the compressor is working extra hard due to insufficient refrigerant hence the stop start issue. Might be completely wrong but a £50 regas would be a good place to start. At 5 years old and 107k, it's fair enough assuming it not been done before I had it. |
10-18-2017, 12:51 PM | #8 |
Rep 433
no point putting in gas if you don't locatebthe leak first, unless it's not been used and the crank case seal is dry. should be R134a for that year of manufacture
David - Bored with Audi
MY2019 X3 40D M-sport with all the toys. Also a Mini CS for the wife and me to play in at the weekends |
10-21-2017, 09:02 AM | #9 |
Rep 42
Update, just in case anyone’s interested....
Took it into Kwik Fit this morning for an aircon regas, £44 which I thought was ok. Without tempting fate....., it seems to have resolved all the ailments. Air con ice cold, stop-start working again, odd hiss noises gone. The machine determined there was no leak. Hopefully happy days! |
