02-05-2014, 06:04 PM | #1 |
Rep 18
BAVSOUND and AFTERMARKET Amps
Guys,
I upgrade my HIFI to Bavsound and it is great. But then comes my challenge since I want to upgrade my OEM amp. Maybe with a JL. I got recommendation to use JL Slash v3 and would like to know if anyone have this installation or sort of it. Thanks |
02-14-2014, 03:44 PM | #2 |
Rep 389
Would be intrested in this as well,bavsound got my hifi equipped f30 to another sound level.
But would like to know if changing the amp would be beneficial ? Also if it is any recommendations
02-14-2014, 04:44 PM | #3 |
Rep 18
My decision on F30 hifi upgrade
After several rounds here and over 100 posts I read about audio upgrade, this is what I did (and it is not the "best", but what fit my needs) :
1) 1st. bought Bavsound Stage 1. Enjoyed a lot. But not enough since OEM amp does not deliver ! I wish bavsound guys told me that IT WOULD not work with an aftermarket amp unless I added crossovers. 2) Between buying crossovers or changing speakers with higher input, chose to remove them. This is my current installation : A) Audison Bit One B) JL 900/5 C) Hertz Speakers HSK 3 way + Hertz HSK 130 rear doors D) Sub JL 12Tw3v4 at the trunk In fact, if anybody In Brazil wants a Bavsound with 2 weeks use, I can sell it. Also, and more important: use this forum as a resource to understand basics and draw some ideas. Unless you are a DIY installer, I do recommend you to get the best installer you can afford. My choice of installer in Brazil is http://www.audiodesign.com.br/empresa_premios.php. regards |
02-14-2014, 05:04 PM | #4 |
Rep 639
my audio adventures were documented here
http://www.f30post.com/forums/showthread.php?t=936139 never heard the BAVsound in person so I cannot comment. With my upgrades and my experiences over the past 20 years of audio upgrades, in order of making a difference: REALLY good quality source material, good front speakers, good amp(s), good tuning (EQ/processor) and then a good sub, in that order…In the past, we would add a good deck, but not possible in newer cars. |
02-15-2014, 02:02 AM | #5 | |
Rep 389
I am overall satisfied with bavsound upgrade but like you I feel the stock amp a little lacking. Maybe I will wait for bavsound to issue a stage 2 upgrade. I though this would be as simple as getting the technic harness and adding and amp
02-15-2014, 02:10 AM | #6 | |
Rep 389
I myself more for plug and play upgrades with this car. Also going for DIY so ease of install was an important factor for going bavsound With bavsound the sound becomes more alive and fills the car with a sound stage that was missing from the stock setup. If I would quantify what I am missing it would be stronger bass that will remain clean with volume
02-15-2014, 06:50 AM | #7 | |
Rep 639
Why cannot bavsound work with aftermarket amps? Even with my system I feel I need to crank it to hear all the details. Of course if you are parked it helps. More amp power just allows you to hear it all during driving and not turn the dial so high that the idrive deck or amp distorts. From looking at the input to my alpine deck (with software) the idrive deck does protect well and can be cranked almost fully without distortion. Everything is plug and play sort of. Amps and speakers are. Only if you add a processor do you open a lot more issues. |
02-15-2014, 07:42 AM | #9 |
Rep 639
02-17-2014, 02:00 PM | #10 | |
44
Rep 208
Sorry you're not happy, but you CAN use our products with an aftermarket amp in this application. |
02-17-2014, 02:02 PM | #11 | |
44
Rep 208
We also actually have full crossover networks available for purchase separately (not shown on our site) that can be used in these cases, too. |
02-17-2014, 02:38 PM | #12 | |
Rep 93
02-17-2014, 05:26 PM | #13 | |
Rep 389
I hope you guys come up with a stage 2 for hifi system adding amp and sub. That would be great For now I am enjoying the upgraded speaker set they really made a differential to stock and are a great bang for the buck
02-21-2014, 01:26 PM | #14 |
Rep 18
Hi guys
Micah, I did contacted you and since I was about to add a powerful amp, you recommended me crossovers. Instead of adding crossovers I decided.to replace woofer to handle 110-120w, more than 75w. I liked bavsound but you should offer and sell crossovers at your website, and offer to people if they want to go over 75w. For those who look for harness, search my post about it. Had a bad experience here. |
03-03-2014, 01:18 PM | #15 |
Rep 2
Stock speakers can sound good if...
First lemme start by saying that I produce music so whether I'm at home or on the road having a solid sound system that bumps is very important to me. As you can see in the picture, all I did was take out the cargo insert in the trunk and give it to an audio installation place for them to make a fiberglass mold for 2 ten inch subs. I wanted to have subs without using my entire trunk so because there's no spare I was able to make this work. So the subs were installed and the amp is bolted to the ceiling giving it a super clean look with thumping sound. I also had them install an bass volume control inside of the drivers side cubby hole underneath of the headlight controls. The bass is what distorts the sound cause the stock speakers can only handle so much bass beyond a certain volume but when you take a majority of that bass out of the speakers they actually work really well as highs. Now doing this will run you about $500-$700 more than the stage 1 upgrade but it's well worth it!!! I'm sure that if I were to upgrade my speakers to BAVsound then it would make my system that much better but I'm contempt for the time being. Hope this was helpful as your review was helpful to me!!!
03-03-2014, 05:39 PM | #16 | |
44
Rep 208
03-03-2014, 05:41 PM | #17 | |
44
Rep 208
Working on it -- hang in there. |
