10-07-2015, 11:40 PM | #23 | |
Rep 3,225
Don't forget also, you must unhook the battery if you are taking the air bag off! |
10-07-2015, 11:55 PM | #24 | |
Rep 340
It can rotate it to any angle if you turn it hard enough... |
02-04-2016, 01:05 PM | #25 |
Rep 33
02-04-2016, 02:19 PM | #26 |
Rep 3,225
02-04-2016, 04:08 PM | #27 |
Rep 33
02-04-2016, 06:10 PM | #28 |
Rep 246
02-04-2016, 08:38 PM | #29 |
Rep 3,225
02-04-2020, 07:13 PM | #32 | |
Rep 62
05-28-2023, 04:11 PM | #33 |
Rep 261
Drives: 2017 320i xdrive
Additional Advice
Sorry to revive old thread but I just wanted to add some pointers for those who may find this.
I recently did a steering wheel change myself and it was brutally difficult to get the airbag out using the traditional method of sticking in a flathead or T-whatever in through the bottom of the steering wheel. I gave up multiple times and it was a pain. I don't recommend this. What I did was remove the cowel trim pieces behind the steering wheel. Once you do that you can sort of access the clips from behind the wheel. The difference is now you can actually see them instead of blindly fishing around and hoping. Once you locate them and unclip, it took me a lot of force to get the airbag out once it was unclipped. It actually required 2 people. One person pushing in both clips at same time and other pulling out airbag. Taking off the cowel trim piece behind the wheel seems hard but its not. Get a thin flathead and pry it off carefully, itll pop right off but it will require some prying. Kies made a video, but if you never have taken off the trim piece you will need tools to pry it, he made it look WAY easier than it actually is. Extremely misleading. Attached is a photo showing where to pry upwards to get the trim behind the steering wheel off. Ignore the M sport wheel in the photo, this advice is for base F30 wheel. |
05-28-2023, 05:02 PM | #34 |
Rep 16,065
I removed the cowl as well, it makes the job much easier being able to see the clips. I also used a couple of trim removal wedges to put outward pressure on the bag, so you don't need another person yanking on it while you release the clips.
