      06-19-2013, 09:30 AM   #3851
Dan_335i
Drives: 2014 335i EBII MSport
if you car gets bricked can bmw repair it free or for a cost? while bricked everything in car wont start like engine start?
      06-19-2013, 10:08 AM   #3852
shawnsheridan
shawnsheridan's Avatar
Originally Posted by snovi View Post
Just got my cable in today for my 335 Shawn, could you pass along the latest e-sys + token info for me?
aaron.m.dempsey@gmail.com
Much appreciated!
Email sent.
      06-19-2013, 12:55 PM   #3853
pth_nl
Drives: BMW 116d
BMW F20 EU model 2012
I'm new to this forum. Driving a 2012 BMW F20 EU 116d. Since I cannot find a similar topic in the F20 forum, could you please help me out?
I have already purchased a cable. Would coding work on my car using E-Sys 3.18.4 and PSdZData 48.3? Could someone please send me a mail how to obtain these files? My email address is paulusma@hotmail.nl
Many thanks!
      06-19-2013, 08:16 PM   #3854
shawnsheridan
Many thanks!
No, that combination won't work on any F20 / F30, as the 48.2 PSdZData is the last working version with E-Sys 3.18.4, for F20 / F30 chassis.
So, try 48.2, and hope it works. If the car was last programmed with ISTA/P >= 2.48.3, you will need to update to E-Sys 3.22.5 and the latest PSdZData.
Email sent.
      06-19-2013, 10:35 PM   #3855
secretagent888
Drives: F30 328i 2013
coding newbie
Hi,
I have no experience with coding but exploring as my F30 328 is currently being built and I want to be prepared. Am I right in assuming that I will need to use E-sys 3.22 with my car when it arrives in late August and how do I get this version.
My friend has a late 2012 build 328 - will 3.18 work with his?
Thanks in advance for your help
      06-19-2013, 11:12 PM   #3856
shawnsheridan
Originally Posted by secretagent888 View Post
Hi,
Yes, you will need the E-Sys 3.22.5 and the latest PSdZData.
As for your friend's F30, it is impossible to guess. The build date is completely irrelevant. What matters only is what version of ISTA/P was last used to program the car. If it was >= ISTA/P 2.48.3, he too will need E-Sys 3.22.5 and the latest PSdZData.
      06-20-2013, 01:25 AM   #3857
secretagent888
Ok Thanks for that. I will use the E-sys 3.18 that I have to check his version.
Where can I get version 3.22.5 and latest PSdZdata?
Thanks again for your help!
      06-20-2013, 09:21 AM   #3858
shawnsheridan
PM sent.
      06-20-2013, 10:16 AM   #3859
Lucardos
Drives: F48 X1 192HP MINERAL GREY
could I also have a link for the latest e-sys + PSdZdata?
      06-20-2013, 11:21 AM   #3860
shawnsheridan
PM sent.
      06-20-2013, 11:33 AM   #3861
mattj3
Drives: 2013 328i M Sport
Question on light sequence coding: can you code the front eyebrows (technical term for light strip above halos?) and rear running lights to blink as your lock/unlock/alarm visible verification?
      06-20-2013, 11:51 AM   #3862
chris4chelsea
Drives: F30 Mineral Grey MSport
also can anyone tell me the password for opening the pdf docs e.g. E-Sys - Getting_Started-Coding.pdf ...
      06-20-2013, 12:30 PM   #3863
shawnsheridan
E-Sys - Getting Started Coding - Part 1, from the very 1st Post in this thread, is not password protected:
http://www.f30post.com/forums/attach...2&d=1338274757
PM sent.
      06-20-2013, 01:34 PM   #3864
e70ist
Drives: 2013 F30 328i Sport-Line
Is there a way to code comfort access to a '13 328i after I get the comfort access handles?
      06-20-2013, 01:39 PM   #3865
shawnsheridan
Add Option Code S322A Comfort Acess to VO, and VO Code car.
      06-20-2013, 02:04 PM   #3866
e70ist
What is VO?
      06-20-2013, 02:07 PM   #3867
shawnsheridan
What is VO?
VO = Vehicle Order, aka FA.
      06-21-2013, 05:59 AM   #3868
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
Hi all!
I have retrofitted my F30 CD-Radio with used NBT. I have not TCB.
I add 609, 6NK, 6NR and 620 options to VO and VO coded the HU_NBT.
1. The Navigation tab is not active. Have I to buy FSC code or CAN-filter to activate Navigation?
2. Does voice command 620 require FSC code too?
3. There is not Internet tab in menu. How can I get it?
4. My HTC HD2 phone connecting to NBT via BT as handsfree and audio streaming but not as internet modem. And there is not globe icon near my HTC phone in BT menu.
Help, please.
      06-21-2013, 03:48 PM   #3869
e70ist
Is it possible to retrofit comfort access on a non comfort access f30? The vehicle has been ordered, now it needs to be customized.
      06-21-2013, 08:30 PM   #3870
shawnsheridan
Originally Posted by avgor123 View Post
Hi all!
Help, please.
Your used NBT head unit has the donor car's VIN, and the FSC Codes in it also have the donor car's VIN.
The proper thing to do is flash the head unit and write your car's VIN to it, and then buy from BMW all new FSC Codes for both Nav Application and Voice Control (and SAT Radio, and BMW Apps if needed), and then Import and Activate them in the head unit. This will be very expensive.
The alternative is to use a CIC PnP Activation Module (aka CAN Filter), which will fool you car's CAS Module into thinking the NBT VIN matches CAS VIN, and then you do not need to replace the FSC Codes:
http://www.bimmer-tech.net/shop/bmw-...ivation-module
      06-21-2013, 09:02 PM   #3871
shawnsheridan
You can retrofit anything, so long as money is no object.
Granted this is an E66, but to give you an idea of what's involved, see this video:
http://www.youtube.com/watch?feature...&v=EjSDhpyAH5g
      06-22-2013, 07:01 AM   #3872
e70ist
From what I understand, the wiring is in the car already. I know I will need the comfort access door handles. What I am not sure about is the combox, keyfob, and coding. That's where I'm looking for assistance.
