BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 335 Buzzing/Rattle behind Center Dash
      01-05-2013, 01:53 PM   #1
henryeeex
Drives: 2013 335i
Gaaaaa. it has been 600 miles and it's still there!!!! Anyone else experiencing this issue? Thinking of going to the service once I fully break in the 1200mi. Has anyone to able to pinpoint the exact problem causing this buzzin? Happens all the time when I'm in sport mode going from gear 1-2-3 (auto btw). So sad
      01-05-2013, 02:38 PM   #2
bcl0328
Drives: 2012 328i
search some other threads. been lots of posts about it.
      01-05-2013, 04:43 PM   #3
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Do u have HUD? Mine sounds like its coming from there. But I've only heard it when engine is cold. Fully warmed and I hear nothing
      01-05-2013, 04:46 PM   #4
ducatiboy72
Norway
Drives: F31 M-Sport
Had rattle coming from the navi screen in my car. But it has disappeared by itself now before I had time to bring it in to the dealer.
      01-05-2013, 04:47 PM   #5
TheObviousChild
TheObviousChild's Avatar
322
Drives: '23 M3 Comp xDrive - '21 X3M40
i've heard it too....comes and goes. Still, annoying.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      01-05-2013, 05:08 PM   #6
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
These are all new cars. Sometimes it takes time for these plastics to settle in. Maybe give it a year and see?
      01-05-2013, 05:16 PM   #7
TreDirtyFive
Drives: X3 M40i
mine is horrible...
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      01-05-2013, 06:13 PM   #8
rxander
rxander's Avatar
Drives: F30 Alpine White
Toggle your AC on and off see if that is the culprit.
      01-05-2013, 06:40 PM   #9
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
The plastic area anterior to the shifter squeaks on mine - I can duplicate the squeak by pushing on that area. I've read that they can insulate by placing insulation tape. I just turn up the music
      01-05-2013, 06:52 PM   #10
ny325
Drives: Jet Black E90
Hopefully it goes away. That will drive me crazy. Good luck.
      01-05-2013, 06:57 PM   #11
Frencholivier
Drives: F30 LCI :)
In 2013, is it too much to ask from a $50k car to be rattle-free??
      01-05-2013, 07:43 PM   #12
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
one wonders...
SOLD: 2012 335i Mineral Gray
      01-08-2013, 05:37 PM   #13
henryeeex
Drives: 2013 335i
Found my problem, whenever the front 2 climate vents face upward, it will cause the rattle noise / buzzing. When the vents are position neutral (straight) or down, the rattle/buzzing noise goes away. Hope this helps somebody.
      01-08-2013, 06:00 PM   #14
Frencholivier
Drives: F30 LCI :)
I'm sure it will help other people. Thanks for sharing the solution. But what an odd problem!
      01-08-2013, 08:37 PM   #15
letsavit
Drives: BMW 320d sport
I had a rattle/clipping sound from the air con when I first got mine, it's gone now
It sounded like a fan clipping a loose sticker or something.
      01-08-2013, 08:58 PM   #16
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
I dismounted my whole front dashboard, removed navi etc... Drive it without the parts... Guess what!? The rattle was still there!! So annoying... I bought an X6 and planning on driving the vehicle for one day before I sign any papers when I purchase a new vehicle )
      01-08-2013, 09:27 PM   #17
PK2348
Drives: 2021 330i xdrive
i had a rattling noise coming from underneath the shifter at certain rpms. took it to the dealer. they kept it for 2 days but fixed the problem. First they removed center console and carpet and realized it was coming from underneath the floor. They removed transmission shield, exhaust system and heat shileds and found a vent tube for the tranfer case that was vibrating against the floor. Then they had to disconnect driveshaft and lower the transmission to take out the tube, cut 8mm off and that fixed the problem.
I almost felt bad, but the car is completely quite now. They told me they also put some felt tape all over dash.
      01-08-2013, 10:19 PM   #18
henryeeex
Drives: 2013 335i
Wow, they practically took apart your car. hahaha
      01-09-2013, 01:59 PM   #19
Weaselboy
Weaselboy's Avatar
76
Drives: 2024 M340i
Yep... I had the same noise in mine. Took it in and the dealer pulled all the A/C vents out and wrapped them in felt tape then put it back together. Problem solved.
I agree it is unacceptable to have a ~$50,000 car with rattles like this.
I don't recall seeing this many "rattle" posts with previous new models like the E90 etc.
