07-23-2017, 10:47 AM | #1409 | |
BMWLad
1469
Rep 2,393
Drives: 320D M Sport
5000k HID H7 35W for the low beam projector Normal halogen H7 bulb for high beam, inner housing Hope this helps |
AJ220640.50 |
07-23-2017, 03:44 PM | #1411 | |
Rep 257
Photos here, and similar here. Links to bulbs here. Even if you go for "CANBUS" bulbs that won't throw an error, you will need to do some coding to stop flickering HIDS and fogs that arise when the car sends check signals to the bulbs. Read up on it in the coding forum, it's not difficult. |
AJ220640.50 |
07-23-2017, 03:45 PM | #1412 |
Rep 257
07-23-2017, 05:32 PM | #1413 |
Rep 22
Please help,
I have them installed over the weekend, can someone please tell me if this beam patteren is normal, why is there a pattern drop on the middle Its anoying onthe road to see this uneven pattern Any suggestion please Thanks |
07-23-2017, 07:35 PM | #1414 |
BMWLad
1469
Rep 2,393
Well, it would be rude not to, when asked
07-24-2017, 04:40 AM | #1416 |
Rep 235
07-24-2017, 03:46 PM | #1419 |
Rep 22
Can someone please tell me how to fix this beam pattern, i am seeing 2 overlapping beams, giving me headache,
Also beam on the far left and right are in really strange shape please check the video |
07-25-2017, 01:16 AM | #1420 |
Rep 235
@Tech_Guru your beam pattern looks to be pretty much the same as everyone else's on this thread and has the little bit in the middle missing.
Mine are being delivered today so will put up a photo as soon as they're fitted. |
07-25-2017, 01:25 AM | #1421 | |
Rep 22
Hi, Did you manage to adjust you beam using this adjusters ? Thanks |
07-25-2017, 01:26 AM | #1422 | |
Rep 22
I have not seen anyone who has middle drop, everyone has smooth straight line Thanks |
07-25-2017, 05:41 PM | #1423 |
Rep 5,897
Drives: 2014 335i Black F30 M Sport
07-26-2017, 06:54 AM | #1425 |
Rep 22
07-26-2017, 07:19 AM | #1426 | |
Rep 401
I'm gunna have to move those up cause my bumper isn't sitting properly then adjust the actual beams again, they don't seem too bad at the minute but I have noticed the slight dip in the middle like others have. |
07-26-2017, 09:24 AM | #1427 | |
Rep 22
07-26-2017, 09:47 AM | #1428 |
Rep 5,897
07-26-2017, 09:52 AM | #1429 |
Rep 401
Loosen the arch liner, peel back then loosen the 3 headlight bolts and loosen the bolts on the very top of the bumper in the engine bay and shimmy everything up over, I only have to do this as I rushed it back together in the rain.
Thanks |
08-05-2017, 04:08 PM | #1430 |
Rep 401
Guys, for some reason my halo's never turn on when I unlock the car anymore it's quite annoying as I like them to come on, no matter where I have the light switch, off, auto .. still no joy!
I might play around with the wires as some where angled dodgy when I positioned the ballasts but that has nothing to do with the Halo's!? I sometimes get the dipped headlight fault on the dash but everytime I've turned on the H.I.D's it's gone off and I've check and all of the bulbs/lights are fine. Haven't had the fault come up for for a few days it was daily before that. Thoughts? |
