06-02-2016, 12:27 AM | #23 | |
Rep 83
06-05-2016, 12:30 PM | #25 |
Rep 121
That was my first intent but upon looking further, found that individual lights cannot be coded on or off. Plus, now that everything matches...it actually looks decent and is no longer an eyesore
06-06-2016, 09:31 AM | #26 |
Rep 50
9600 LM led for low beam
Dear All,
I have recently changed my halogen to 9600 LM led.Attached picture.I am very happy with the quality but have problems with cutting line.Any suggestion? |
06-07-2016, 10:07 AM | #27 |
Rep 27
Just wondering if anyone has tried to replaced their halogen with these ones?
https://bimmian.com/Accessories-for-...og-Light-Bulb/ Apparently error free... Interested to see if anyone has used them and their thoughts. Cheers. |
06-07-2016, 10:50 AM | #28 |
Rep 48
This LED has received very good reviews on the BMW K1600 motorcycle forum as a headlight replacement:
http://www.ebay.com/itm/262307059160...%3AMEBIDX%3AIT It's available in a 5000 degree K color temperature, which should look fairly similar to the 4300 K HID headlights on my F36. I plan to try it out for my F36 fog lights. I'll post results if it works. |
06-09-2016, 06:15 PM | #29 |
Rep 27
I replaced my DRL with LED, and H7s with phillips diamond, the two I have left are the blinkers and parking lights...are there good halogen options? I don't really wanna get into the coding, and resisters, etc.
2013 328i Xdrive
Black Sapphire Metallic w/ Dakota Black/Red Highlights | Sport Line | Cold Weather | Premium | Navi | |
04-21-2017, 03:44 PM | #30 | |
Rep 58
06-05-2017, 04:14 PM | #31 |
Rep 9
Hi everyone,
I went through the post a number of times. I have a couple of queries. Firstly, I bought my 2013 BMW 328i recently, unfortunately with the halogen housings. I replaced 1. High/Low beams with H7 Phillips Diamond Vision - 5000k 2. PW24W Parking Bulbs with iJDMTOY 42-SMD - 6000k 3. 13-SMD-5050 DRLs with iJDMTOY 5050 SMD - 6000k Its a much cheaper option, than to change the entire housing for sure. Now, I was quite happy with arrangement until I found out about the varying color temperature. Both my Parking bulbs and DRL's are at 6000k color temperature but I could not find Halogen H7's with 6000k, the Phillips ones are 5000k. Other way round, I could not find DRL's and parking lights of 5000k. The parking lights and the low beams light up together and color difference looks so off between the two. I love the look of 6000k bluish white light. Has anyone able to find 6000k H7 halogens online ? or maybe 5000k PW24W LEDS ? My second question is I have 2 pairs of H7 Auxbeam F-S2 series LEDs lying around. They are good bright 6000k LEDs for both high beams and low beams, alas they do not fit the F30 halogen housings, given the fact that I can code warm and cold checks, is it possible for me to use a converter for the same, I tried two of the converters from amazon but none of them fit. Does any one know a set of LED's or converters for the above H7's that fit F30 halogen housings ? I know its a long post, but I just hope some one would reply ? Your help is appreciated. |
06-05-2017, 04:51 PM | #32 |
Rep 15,966
There's no such thing. Those that claim to have higher than 3000k are playing fast and loose with the facts. They look whiter, because the envelopes are tinted blue. Worse, that tint reduces the lumens output.
06-08-2017, 12:17 AM | #33 |
Rep 177
Did all the iJDMToy bulbs as mentioned here, except the headlights. I probably should've gone the Philips Diamond Vision route for my low beams instead of the HIDs, but I have just ordered the Depo Projector headlights, so the HIDs will work great on those.
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
06-11-2017, 12:39 AM | #34 |
Rep 109
06-14-2017, 08:20 PM | #36 |
Rep 1,436
hello guys if anyone wants to upgrade to full LED please message me. I will send you all bulbs needed and lumens as follows this kit doesn't produce any error but needs coding which i will provide remotely.
DRL 50w Signals 30w Parking 7w Fog Light 8000 or 12000 lumens Low beam 8000 or 12000 lumens High beam 5000 ot 8000 lumens Here is how it looks https://m.facebook.com/pg/fseries.cr...70577699787942 |
06-15-2017, 01:40 AM | #37 | |
Rep 58
06-15-2017, 02:58 AM | #38 | |
Rep 1,436
06-16-2017, 12:17 PM | #39 |
Rep 1
Good to know the 3 series just uses H7
The wife has only had her 330e for 4 days but the one time I turned the lights on the yellowness annoyed me. I thought all 330e's had LED lights but we needed and M-Sport not just a sport. Luckily I have spare nightbreakers or diamond vision to chose from. Does the light housing cover have a warranty sticker on it like some other manufacturers. |
07-24-2017, 05:05 PM | #40 |
Rep 1
Can you PM message me the codes for parking lights and drl pleeeeeease I changed the drl and parking lights to led no errors but theblinking is there
08-05-2017, 05:04 PM | #41 | |
Rep 1,436
DRL TFL_L_KALTUEBERWACHUNG > nicht_aktiv (cold check/left) TFL_L_WARMUEBERWACHUNG > nicht_aktiv (warm check/left) TFL_L_IS_LED > aktiv (bulb recognised as LED/left) TFL_R_KALTUEBERWACHUNG > nicht_aktiv (cold check/right) TFL_R_WARMUEBERWACHUNG > nicht_aktiv (warm check/right) TFL_R_IS_LED > aktiv (bulb recognised as LED/right) parking TFL_S_L_KALTUEBERWACHUNG > nicht_aktiv (cold check/left) TFL_S_L_WARMUEBERWACHUNG > nicht_aktiv (warm check/left) TFL_S_L_IS_LED > aktiv (bulb recognised as LED/left) TFL_S_R_KALTUEBERWACHUNG > nicht_aktiv (cold check/right) TFL_S_R_WARMUEBERWACHUNG > nicht_aktiv (warm check/right) TFL_S_R_IS_LED > aktiv (bulb recognised as LED/right)
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
11-21-2017, 02:46 PM | #42 |
BSME
Rep 114
Drives: 2004 M3, 2014 320i
what is the purpose of the cold/warm checks? i.e. what are we giving up by coding them out? some safety check?
2004 Silver-Grey ///M3 Coupe 6MT
2014 Black Sapphire Metallic 320i Sedan 8AT 2024 ???? |
11-21-2017, 03:13 PM | #43 |
Rep 15,966
The cold/warm checks send a series of short pulses to the bulbs to be sure they're working. Those pulses are too short in duration to heat the filaments in halogens enough to light up. LEDs don't heat to create light, and they react more or less instantly, so cold/warm checks will cause them to blink rapidly for a few seconds every five minutes or so. Resistors won't stop it, canbus ballasts won't stop it. Only coding will stop it. If you do have a bulb blow you won't get a warning, so you'll just have to notice it the old fashioned way: It's darker driving with a blown bulb.
In fairness to BMW the hot/cold checks tell you if a bulb is blown during the day, when the lights aren't on, so in theory you can get a new bulb put in before it gets dark. But I haven't had a bulb blow in at least 30 years, so the need for that particular technology is dubious. |
11-21-2017, 03:24 PM | #44 | |
BSME
Rep 114
