08-27-2014, 06:06 PM | #1 |
Rep 435
ediabas f30/32
Hi I received a cel today due to kombi coding. I may attempt to re-code and see if it clears (the settings I manipulated had previously been coded and did not generate a code then)
does ediabas work for the f32? if so does anyone have a working link they can provide |
08-27-2014, 06:55 PM | #2 | |
Rep 341
08-27-2014, 08:44 PM | #4 |
Rep 341
No problem. No but usually it's because you turned on a feature that you don't have the hardware to support it. At least that was my case when I turned on the speed limit signs.
08-30-2014, 05:03 AM | #5 |
Coding ECU's remotely
445
Rep 1,176
What should the output look like if you read the DTC's and there are no errors?
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
