11-18-2013, 01:16 PM | #71 |
Rep 45
Drives: 2013 328i, 2014 328i
I had this issue on my Sep 2012 build 328i. Drivers side tail light sticking out and loose. Took it to the dealer, who took about an hour. I think their fix involved some adhesive, since they said that they could not do the normal dealer card wash till the adhesive set. They invited me to bring it back for a car wash the next day. That was a couple weeks ago, seems to be okay for now.
11-18-2013, 01:29 PM | #72 |
Rep 376
As a follow up, I had mine replaced a few weeks ago and a week later it happened again. I guess they did not really repair it and just replaced the light cause it was full of water/corrosion. Seems to be ok so far.
11-22-2013, 09:19 AM | #73 |
Rep 616
Just wanted to update this thread a bit. I just took our MY13 320i in for service because the left rear tail light was falling out. My SA told me that it's an extremely common problem and they had a few this week already. Wow!
They installed a new housing for the left rear and used a 'new BMW sealant' to ensure that the right tail light would remain in place as well. Seems like they have a lock on the problem, and once it's fixed it will remain fixed. |
02-20-2014, 11:06 PM | #74 |
Rep 12
This just happened to my MY14 F30 316i M Sport.
08.2013 production at Regensburg, Germany just 3 month driving, i have an appointment tomorrow... UPDATE: they replace it under warranty i found this SIB 63 05 12 Tail Lamp is loose in the trunk lid Last edited by maldad80; 02-21-2014 at 11:13 PM.. |
02-20-2014, 11:27 PM | #75 |
Rep 128
Drives: 2015 BMW x5
This happened to my 328i too. January 2013 build from Germany. My dealer took care of the problem with a replacement part.
02-21-2014, 08:03 PM | #76 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
2012 May build, 43,000mls - no issues.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
09-15-2014, 08:19 PM | #77 |
Rep 443
I was washing my car when I noticed inner tail light sticking out! I am dissappinted in how the tail light attached to the trunk. My car is a 2014 with 8,000 miles on it. This should no be happening already.
09-16-2014, 12:19 PM | #78 |
Rep 127
Wow, this is STILL happening?
The saga with my 2013's driver side tail light was finally resolved... ... and guess what I saw yesterday? The passenger side is loose and sticking out. And I had in for service last week. Oye. |
09-17-2014, 11:01 PM | #79 |
Rep 606
Drives: 2018 F80 Atlantis Metallic
Had the same issue, drivers side...had it fixed about a month ago....so far so good.
Past: 2018 M3 Atlantis Metallic/SS, Comp Pkg, 6MT
Past: 2015 M3 Austin Yellow |
02-04-2015, 01:53 PM | #81 |
Rep 378
Just noticed this on the driver's side of mine 2013 328, 27K on it.. My new car should be here in March, but now i have to waste time taking the old one to the dealer
09-26-2018, 05:56 PM | #82 |
Rep 9
Issue can happen years later
This is a late addition to the thread but I thought I'd share. Both of my trunk-mounted tail lights came loose after the warranty expired. My build was July 2012 in Germany.
As an engineer, I could tell the design of the tabs and how they fit the car was poor. One came loose after 5 years going over a speed bump. The other after 6 years closing the trunk a bit hard. The outboard tab is too tight for its slot - it helps to lift the lip of the slot slightly to reduce the stress on the tab. In one of my cases, the tab broke off. In both cases, other protrusions also broke so a complete replacement was the proper solution... but I didn't trust the weakness of the design. Ultimately I made some metal brackets to hold the assemblies in place. It's not pretty, or easy (don't ask!), but it's hidden and strong. A large amount of good adhesive in all the right places could do the trick - could be stronger than the original design which is flimsy and complex. Good luck. |
09-26-2018, 08:07 PM | #83 |
Rep 448
Just had the same problem on my 2013 Sport Line. I believe I have a broken tab (and no more warranty...) and will have to replace. Anyone have any advice on where to put adhesive when I do the reinstall? I imagine anywhere the tabs make contact.
10-01-2018, 08:45 PM | #84 |
Rep 9
Perhaps all the way around as well - not many places make contact so maybe the area where the foam gasket is. You would want an adhesive that won't eat the foam if going on it. Also, if you are getting a new light, I suggest taking a large screwdriver and gently bending the slot the long (outboard) tab hooks into out slightly to reduce the force on the long plastic tab. This assumes they didn't redesign it - I'm sure mine was overstressed since installation.
jhuber65.50 |
10-02-2018, 08:19 AM | #85 |
Rep 209
The part was redesigned somewhere is 2014 IIRC. Usual retail is about $120-150 for the redesigned part, which features stronger tabs. Many online retailers carry the new part. I am not sure if you need an adhesive. I would be worried about disasembly should the need arises. Also, in my case, I had to screw in the adjusters for the trunk lid as the trunk only shut when slammed.
jhuber65.50 |
02-13-2019, 04:20 PM | #86 |
Rep 3
Hi there. I have a 2012 335i which is well passed its warranty period. Notice the truck tail light was falling off. When to dealership to see what they could do for me given I have purchased many cars from them. Well the best they could do is 15%off the part and no labour... still close to $400. I have to ask this ... since replacing any of the bulbs is done by removing the truck inner panel and NOT removing the tail light assembly... could I just glue the assembly in place?
02-13-2019, 08:47 PM | #87 |
Rep 209
You can. I would not suggest it as if a stone chips your light:something cracks/breaks it, you will have to take it off somehow...taking paint off eith it. Before mine was replaced I had to drive around for a few days with "staples" for a lack of better word holding the light to the trink lid. I used the metal staples that hold together heavy duty cardboard boxes (for appliances for example) - I bent 3 of them in a way to hold the light against tne trunk lid. It was far from pretty but worked great and was not visible from the outside - you can only see it if specifically looking for that alteration when the trink is open. In order to protect the paint I placed a small piece or rubber pad under the "staples". That setup held the light in place for a few days until I was able to get the car back to the dealer. I would not suggest mine as a long term solution but to me gluing exterior parts that might need to be disassembled is at least a tricky proposition.
