BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Transmission Possibly slipping?
      12-13-2013, 04:56 PM   #1
Jay562F30
Jay562F30's Avatar
Drives: 2013 F30 Estoril Blue
Hey guys Ive had my 335 f30 running on jb4 stage 2 Map 7 e85 ER down pipe
Automatic feels like my transmission is slipping on 3rd gear roll off 40 revs up up to 4,500 rpm and feels like a choke rpm's keep going up but car goes no where first thought it was a choke but i guess not started happening when I updated the JB4 to the new software I changed it to map 2 and it doesnt happen on this map , I emailed terry sent him a couple of logs and he is taking a look over them hopefully it is not the transmission maybe just a bug
[FONT="Arial Black"]BMS JB4 DownPipe Flex Fuel[/FONT]
      12-13-2013, 05:01 PM   #2
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Please post Terry's findings here along with your logs!
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      12-13-2013, 05:04 PM   #3
Jay562F30
Jay562F30's Avatar
Will do
      12-13-2013, 05:06 PM   #4
2blu
2blu's Avatar
Drives: 540i XDrive ///M Sport
Interesting. Subbed for feedback.
      12-17-2013, 02:52 PM   #5
BIMMERMANF30
Drives: 14' 335XI, AW, CR, M Sport, 8A
any news?
      12-17-2013, 03:09 PM   #6
JN1
JN1's Avatar
301
Drives: S211 AMG E63
do you know how much power you are putting down?
-JustinNApproved
      12-17-2013, 03:54 PM   #7
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
You guys tuning with autos are crazy. The stock transmission is only rated to hold 332 lb ft. With OP's mods, he's definitely making over 400 lb ft.... maybe closer to 450.
/Edit/ Just looked up the ZF 8HP45 torque limit, and it's 450 nm, which is 332 ft lbs. No more than what a MPPK puts out.
      12-17-2013, 04:24 PM   #8
JN1
JN1's Avatar
301
Yeah I was just reading about that which is making me rethink going BMS Stage 2. On the track the car is pretty quick already and I'm able to pull away from a lot of cars so if I can get my race line and braking cleaned up I should be able to become much faster.
-JustinNApproved
      12-17-2013, 06:21 PM   #9
chetman7
Drives: F80 m3
Where do people keep getting that the 8HP45 is only rated to 450nm?? Everything I read says 500nm
      12-17-2013, 07:20 PM   #10
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
500nm in the diesel versions.
http://www.zf.com/media/media/produc..._DataSheet.pdf
http://en.wikipedia.org/wiki/ZF_8HP_transmission
Even if the diesel version is in there, 500nm is only 369 lb ft.
      12-17-2013, 09:37 PM   #11
ShlemonboostedM
ShlemonboostedM's Avatar
92
Drives: 335i F30
Doesn't 650i/550i have same tranny ?
      12-17-2013, 10:19 PM   #12
2blu
2blu's Avatar
Somewhat. Theirs has stronger internals to deal with more torque. Read somewhere that it's around 20lbs heavier...
But doesn't dinan offer a tune that doesn't void BMW's warranty ? It's rated at 355 hp and 400 pound-feet of torque...
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
      12-18-2013, 09:15 AM   #13
btbossman
Drives: 2013 335xi M sport--2014 M6
Haven't many people been running upwards of 400 ft/lb's with no issues? I though stage 2 was still considered a moderate tune? Im looking to get one and possibly DP to go with my exhaust, but doubt Ill move from map 2, am I looking at any issues?
      12-18-2013, 09:35 AM   #14
2blu
2blu's Avatar
Burger tuning are running map 7 with no issues on their 8 AT putting down very high power.
      12-18-2013, 11:13 AM   #15
CJ2
Drives: 2019 F90 M5
OP, I'm wondering what your fuel pressure may be dropping to in 3rd and 4th. I am running the same setup as you. Map 7, downpipe, and E85. I ran my car in the quarter mile last weekend and had some fuel pressure issues causing the car to bog a little in 3rd and 4th. If this is a fuel pressure issue, you may need to get an inline low pressure fuel pump (LPFP).
What is your PID set to?
What is your auto shift boost reduction set to?
Attach your logs for review if you want.
      12-18-2013, 01:30 PM   #16
eyim1988
eyim1988's Avatar
98
Drives: 2022 BMW M4
2022 M4  [0.00]
My e92 6at is holding 450 torque with no problems.
Current: 2021 X3MC
Past: 2013 bmw 335i, 2011 bmw 335i coupe, 2016 bmw m3
      12-18-2013, 02:34 PM   #17
2blu
2blu's Avatar
What is the E92 6AT rated at ?
      12-18-2013, 09:50 PM   #18
rayg
Drives: 435i
My car doesn't want to shift out of 3rd gear (I believe it's 3rd) either at around 60-65mph at wot, it'll go to redline and sit there about what feels like a half a second too long. It doesn't do it every time, but it does it enough that if I want to wot from low speeds I just use the paddles. Running JB4 map 1.
      12-19-2013, 01:57 AM   #19
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
why do you wot without manual ?
with jb4 ull need to shift at 6k not 7k , your car will still shift at 7k
Docrace 6266
      12-19-2013, 10:36 AM   #20
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
Went back and looked it up. The ZF 6 speed Steptronic (GA6HP19Z) transmission is rated at 400 nm. Very odd, since that is only 295 ft lbs. I think I'm noticing a pattern of these transmissions being underrated (for the most part). Either way, numbers aside, the F30 transmissions should be able to take a little more than the E90 ones.
      12-19-2013, 10:42 AM   #21
2blu
2blu's Avatar
Thanks for the info !
      12-19-2013, 11:55 AM   #22
rayg
Drives: 435i
Why do I wot without manual? Because an automatic should shift more accurately and faster than a human can? But you're right because it's not shifting until redline.
