06-30-2015, 06:01 PM | #45 | |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
i forgot the exact price, but it was $5XX for one and $6XX for the other. im not going to pull the trigger on that yet until I install the DV+ because it seems as if the factory DV has reached its limit and is dumping boost erratically, its either that or the transmission is just giving up. its hard to tell.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-30-2015, 06:12 PM | #46 | |
Rep 15
06-30-2015, 06:25 PM | #47 |
515
Rep 1,063
lol I hate that im the guinea pig but somebody has to do it. Stage 2 was well worth it though!
06-30-2015, 07:38 PM | #48 | |
Rep 681
07-01-2015, 03:27 AM | #49 | |
Rep 1,252
Docrace 6266
07-01-2015, 01:04 PM | #50 | |
515
Rep 1,063
sweet! cant wait!
07-02-2015, 01:54 AM | #51 |
Rep 1,349
Drives: BMW F80 M3
If you look at some logs you would notice I also advice getting JB4 mobile so you see everything live on your phone. Made me feel a lot more comfortable pushing the car.
07-03-2015, 10:42 AM | #52 |
515
Rep 1,063
I'm still not that quite knowledgeable when it comes to reading logs lol but I'm getting better at it. And I do have the JB4 mobile, it's sooooo worth it!
07-03-2015, 12:01 PM | #53 |
Rep 49
07-03-2015, 12:27 PM | #54 |
515
Rep 1,063
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| Last edited by obriennathaniel; 07-03-2015 at 01:14 PM.. |
07-03-2015, 12:40 PM | #55 | |
Rep 15
Around 170 on the x axis: -Pedal at max -RPM's increasing so no shift took place -Appears to go extremely lean (over 17) what is the comparison of "throttle" vs "pedal"? **EDIT** Found information to answer my question: http://www.n54tech.com/forums/showthread.php?t=21269 Is this what we are viewing in the datalog as far as the throttle position? "Note: Corrective actions such as loss of traction control action or ECU PSI over DME BT or very low HPFP pressure can all cause the throttle to close…..without user input." Given boost targets are not met, then I would assume this is directly due to running lean? Last edited by jbreed; 07-03-2015 at 01:09 PM.. Reason: learning as I go |
07-03-2015, 03:07 PM | #56 |
Rep 115,980
07-03-2015, 03:11 PM | #57 |
Rep 243
I agree with mike. CSV files would be more awesome! Also...screenshot of MAP6/3 settings from mobile JB4.
JB4 Stage 2 | aFe Magnum FORCE Intake System DRY | ER Chargepipe | ER CATLESS Downpipe | ATM Intercooler | BMS 2.3 Gal Meth Inj kit | Bilstein B14 | OEM Slotted/Dimpeled front rotors | Cool Carbon brakes | Go Fast Bit DV+ | Pure Stage 2 Turbo | Pure inlet
07-03-2015, 03:20 PM | #58 |
515
Rep 1,063
I'm at work and all I have is my phone, so that's the best I can do for right now. When I get home ill upload the csv files, and two more logs.
I would post the settings but they're not stored in the app for some reason and my car is all the way across Houston at their shop and they're closed for the 4th. I'll probably go up there mon or Tuesday and put that DV+ on and see how everything goes and then post the JB4 settings.
07-04-2015, 10:41 AM | #59 |
Rep 156
Give_Em_The_DD who has an XI 600+awhp 335XI. auto trans...the issue was holding the torque or HP.....he went to the track trying to break his own record of 11.3. on his new tune.....the thing that snapped.....were the axels. that was the weak put when he put down the power....probably more of an AWD thing an an RWD thing. something to consider with LSD and slicks though.
2015 M3 MW 6MT - BM3 | iND
2011 335xi MSport - Alpina shifted FBO on E85 - 388awhp/482awtq |
07-08-2015, 03:21 AM | #60 | |
515
Rep 1,063
07-08-2015, 03:34 AM | #61 |
515
Rep 1,063
CSV Files
Ok, so I installed the DV+ (which was the most INSANELY difficult task of doing without removing the turbo) and now she runs perfect!!!! :happy anim:
So therefore the transmission is holding after all! Level 10 will be further down the road now lol. Attached are the 2 logs I took. (just delete doc and replace it with csv, I guess thats the only way I can upload them) I suck at reading logs, I need to read the JB4 bible again lol. I did three pulls, but didnt record the first pull. the first two pulls were fkn insane, the third pull however i think the JB4 went into failsafe mode or whatever because the boost didnt get very high at all. this was on map 6 (i forgot, thought it was on 5), 93 pump and 50/50 meth. I usually run 100 (to supplement fueling) but the shop mixed it on accident. Ill keep it on map 5 until I install the PI to keep from blowing up my motor lol. I also have new PSS on the rears so now traction is nowhere near as much an issue as it was with my balding Invos. Also Ill be ordering Motiv's PI kit here soon too
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| Last edited by obriennathaniel; 07-08-2015 at 03:40 AM.. |
07-08-2015, 03:08 PM | #63 | |
Rep 851
Just curious how do you get the JB4 mobile to work? Im on iphone and I see an app for 32 bucks is that one it? Can somebody explain to me? I hate having to use cord and laptop mad annoying. Thanks! |
07-08-2015, 03:11 PM | #64 |
515
Rep 1,063
You have to have the Bluetooth connect kit, you can google it fairly easily.
07-08-2015, 04:37 PM | #65 | |
Dream crusher
984
Rep 2,421
I just bought the DV+. Could you give me a quick run down of what I should expect in terms of installing the DV+? Radiator drain, which parts to remove, etc? I have a F10 535. Thanks.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
07-09-2015, 12:49 AM | #66 |
515
Rep 1,063
Well I'm assuming it's going to be different on an F10, I would think easier actually due to having more room but that's all speculation. I didn't remove my water pump or radiator, but I did unmount the water pump and water pump bracket, remove my FMIC, disconnect the radiator fan and associated tubing/cooler that's mounted to it and slide it up about 5" so I can get a drill with an extension and some rounded hex bits in there to undo the 3 screws holding the diverter valve on. The very top screw I had to get using a traditional L shaped Allen wrench. A drill isn't necessary but it makes it easier. If you don't have any I would definitely go buy some rounded hex bits, so you can undo the hex screws from an angle. Should be a #5
bmw, f30, flash tune, jb4 335i, pure stage 2 |
