03-03-2014, 10:36 AM | #5853 |
Rep 8
03-03-2014, 11:41 AM | #5854 | |
Rep 26
03-03-2014, 12:03 PM | #5855 |
Rep 40,868
03-03-2014, 12:39 PM | #5856 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
MN-2.33.2 remains the same. TN-2.33.2 was updated to TN-2.34.1. There is no Internet item in menu. The Internet browser still doesn't work. The WiFi checkbox cannot be checked. WiFi still doesn't work. |
03-04-2014, 08:17 AM | #5857 |
Rep 40,868
Ok, so It seems you must flash NBT.
PM sent.
03-04-2014, 04:15 PM | #5858 |
Rep 8
Does anyone know how to:
1. Code/activate Sport+ mode on the car that didn't come with it? 2. Code S1-S7 instead of just DS? Of course I can see it when I switch gear manually, but I'd like it to show when it does it automatically as well. 3. Torque distribution? I do have X-Drive. I coded it, it is grayed out. Thanks. |
03-04-2014, 04:20 PM | #5859 |
Rep 40,868
1) ICM => IcmKod_B_Sportlenkung = verbaut
2) EGS => Sportschalter = aktive and EGS => Sportschalter_alt (Not sure if it works on F30) 3) Wont work.
03-04-2014, 04:21 PM | #5860 |
Rep 8
03-04-2014, 04:24 PM | #5861 |
Rep 40,868
It won't make a difference. You don't have the DWA hardware.
03-05-2014, 02:44 AM | #5862 |
Rep 68
Drives: F31 Sportline
Hello everybody,
can someone suggest me where to download E-Sys and PszData, for a 2014 F31 (January build)? Thanks a lot! |
03-05-2014, 08:20 AM | #5864 |
Rep 40,868
PM sent.
03-05-2014, 08:46 AM | #5865 | |
Rep 83
I'd love my clock to self-correct since it doesn't seem to keep the time great, but I don't have nav.. Last edited by ardyer; 03-05-2014 at 09:00 AM.. |
03-05-2014, 02:16 PM | #5867 |
Rep 3,154
Hi hope someone can help. I am in Europe and coded EBT yesterday. I got a token from tokenmaster and tried to code M performance logo etc.
All seems ok when I code but I notice that the changes were not applying when I read the data it is how it was orignally. Before I had a token I accidentally coded the entire ECU but I didn't have a token and it seemed to recover after a few errors on the dash. I didn't change anything (edit) as I couldn't without token. But I get these errors when I am coding KOMBI etc in the logs: I am using 3.24.3 and pzdata 51.3 Should I reinstall E-sys? Thanks MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> |
03-05-2014, 02:42 PM | #5868 | |
Rep 1,892
1. Make sure you are selecting the F020 (not _DIRECT) line when you connect to the car and that you are connecting via the VIN. 2. Double check that TokenMaster's .jar file and in the right place and the new classpath is correct as per the instructions. 3. Can you FDL code any other ECU's (like FEM_BODY), or do you get the same error for others too? Good Luck! |
03-05-2014, 02:50 PM | #5869 | |
Rep 3,154
I think I will install e-sys completely again now and install token masters files as well. Could be an authentication error etc. |
03-05-2014, 05:19 PM | #5871 |
Rep 3,154
Shame this didn't seem to fix, I tried FEM_BODY and that didn't work either will try again tomorrow night
03-05-2014, 05:25 PM | #5872 |
Rep 40,868
Try going under E-Sys => Options => Settings => Options Tab and unchecking the boxes for Update VCM and Update MSM.
