03-18-2020, 06:14 PM | #1 |
Rep 809
Help please, OEM wheel locks key lost
Can anyone guide me on what part number do I need to order to replace the key that unlocks the wheel locks on my recently purchased F30 LCI 2017?
I bought the car from a preowned car dealer and the previous owner said that the key was lost. I've searching in realoem.com using my VIN and I get two part numbers, I'm clueless about which one do I need to purchase. BMW OEM Part # 36132453961 and BMW OEM Part # 36136792851 I've lost none of my current and previous Bimmers lock keys in the past, so I'm also clueless if these keys are unique or replaceable, so excuse my ignorance. Thanks in advance to anyone that can guide me. I'm kind of urged to replace this key as new tires are mandatory on this car ASAP. I'm attaching an actual picture I've just taken of my wheel lock. |
03-18-2020, 06:49 PM | #2 |
Rep 2,212
There are different key codes - the dealership usually has all the options.
Your other resort is to pound an oversized socket onto the wheel lock & use a ratchet to remove it. There are some YouTube videos showing this, and even some special sockets to defeat the lock. Good luck!
AlexGT419.50 |
03-18-2020, 09:07 PM | #3 | |
Rep 809
Proud BMW owner
E87 130i — E90 LCI 320d — F22 M235i — F15 X5 30d F30 LCI 320i MSport — G05 X5 30d MSport —— —— —— —— —— —— —— —— —— —— —— —— |
03-18-2020, 09:15 PM | #4 |
Rep 320
thats not a BMW lock...but it can still be removed. you could try and find one of those 'grip' sockets. You know the ones with the really sharpe diagonal teeth that dig into a nut the more you tighten it...
03-19-2020, 05:08 AM | #5 | |
Rep 5,399
The dealer was able to use their key to remove my wheel locks and replace with a stock bolt so I could change my tires. The dealer tried to sell me a new set of their spline style wheel locks but at ~$140 it seemed smarter to just replace the McGard key. If somehow the dealer keys don't fit, like if the previous owner installed an aftermarket set of McGard locks out of the range of BMW keys, you can contact McGard directly. This happens all the time. You can email them closeup photos of your locks on the car and they can figure out which key you need and ship it to you. Hope this helps! |
AlexGT419.50 |
03-20-2020, 09:56 AM | #6 | |
Rep 1,827
They are coded. Taking it to the dealer is your best bet. They'll be able to use their master set to determine which code you have.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
03-20-2020, 03:54 PM | #7 |
Rep 809
03-20-2020, 03:57 PM | #8 | |
Rep 809
So I guess I'd have to wait until everything goes back to normal (hopefully) and try this. Thanks again! |
03-20-2020, 04:12 PM | #9 |
Rep 3,748
Aren't they essential... they should be open. I mean appointment only or like one mechanic per bay... that should be 6 ft apart per social distancing requirement....I know I was told they open for emergency... ie.... tire repair.... stuff like that.
03-20-2020, 04:17 PM | #10 |
Rep 809
I've received an email from the BMW Dealership today, they shared an emergency number to call in. But to be honest, I'm urged to get these replaced but just because I want to be covered in case of an emergency tire change, so I'm not sure if I should call these days or just wait for a while since this is not my only ride.
03-20-2020, 04:48 PM | #11 | |
Rep 1,827
03-20-2020, 05:16 PM | #12 |
Rep 3,748
Yeah...I called America's Tires. They said they open just for emergency...ie tire patching and blown tires.
Anyway not all are open. I just check my local one...close to me. I got tire repair kit on my car. But I like them professionally patch tho. I'm trying to avoid using slime as much as possible. Last edited by Gen13 F36; 03-20-2020 at 05:24 PM.. |
03-20-2020, 08:35 PM | #13 |
Rep 45
I had this issue a couple of months ago and sent a picture to mcgard. $8 later plus shipping and I got those suckers off. A lot easier than cutting them off or smashing a socket on and chancing wheel damage.
03-21-2020, 05:50 AM | #14 | ||
Rep 5,399
04-11-2020, 11:14 AM | #15 |
M340i
395
Rep 986
Drives: BMW M340i
Just realized I lost my lock too. I have a similar looking wheel lock set. It shows up on the dealer invoice sticker as a $160 set. McGard is not opened on weekends and dealer was no help as expected. I have no documentation. May try to find a wheel lock removal tool or just a big socket and beat it on there to remove them. I'm pretty sure no one is going to steal my wheels.
Well I found out I have the high security lock set with a spinning ring. Standard wheel lock removal tool will not work. Last edited by Randy Johnson; 04-11-2020 at 01:59 PM.. |
04-11-2020, 02:01 PM | #16 | ||||||
Rep 809
Proud BMW owner
