08-20-2014, 01:15 PM | #67 |
Rep 180
i read all the post, thanks for all the advice
Will 442m (19") fit a base no-line F30 N20 328i? wanting to buy it off a member but dont want to bother tires rubbing. I see onlilne on BMW the largest they offer for the F30 328i is 18 inch |
09-06-2014, 04:14 PM | #69 |
Rep 37
I am currently riding on the stock 19" staggered setup for my F30 M Sport with M-brake.
I am looking for some 18" CSL replicas for my winter setup and going to a square setup. Would 18x8" ET35 work for all four corners? I also plan to wrap the reps with some 225/45/19 winter tires. |
09-23-2014, 12:50 AM | #70 |
Rep 11
I know there has been a lot of talk about the xDrive issue regarding the wheel setup, but I would like you guys to help me with my setup. Have a new F30 320d xDrive Luxury pack and stock suspension and would like to go with the next setup: front rims 19'' 8.5 et 35 235/35 R19 and rear rims 19'' 9.5 et 37 265/30 R19, would there be any issues with this setup, I really am not yet familiar with the calculations made to see what the right % bracket that I should be looking at, any help would be great, thanks!
10-03-2014, 10:57 PM | #71 |
Rep 67
Nice job with this list!
I hope my question is not off-topic, if so, my apologies. I have 403M 19 inch wheels (225/40/19 and 255/35/19) on my 2013 335i M Sport I would love to get some wider rubber (Michelin PSS) and 19 inch rims to get a flush fit without spacers (if possible) with no rubbing at all. Can someone please guide me on what rim offsets and widths I should be looking for? I am hoping that I can go with 235 front and 265 rear. Much appreciated!
2016 F85 X5M - Black on Black, loaded
2016 F80 M3 - Black on Black, 437M Black wheels, Black kidney grills - SOLD 2013 F30 335i - M Sport, MPPK, MPE, DinanTronics Stage 2, Dinan Suspension - SOLD 2007 E90 335i - Dinan Stage 2, BMW PE - SOLD 2002 E46 M3 Coupe - CSL wheels - SOLD |
10-03-2014, 11:30 PM | #72 | |
Rep 1,738
10-30-2014, 01:31 AM | #73 |
Rep 606
Drives: 2009 e92 335i
i want to run the following set up please help asap
i have f32 with sport pck so 18x8 et34 on 397 square setup want to buy 18x9.5 et 22 square setup will these wheels fit my f32 without any issues i dont want any spacers and its stock height i plan on running front 245/40/18 rear 275/35/18 will there be any issues with what im trying to do? thanks for the help |
11-12-2014, 12:46 PM | #74 |
Rep 70
hey guys, I am trying to get a winter wheel/tire setup and it's driving me crazy.
I currently have a 335i M-Sport with Staggered Summer Tires stock. Which would work better? 1. Square setup: 17x7.5 et 32 with 225/50R17 Blizzaks WS80 2. Square setup: 17x7.5 et 37 with 225/50R17 Blizzaks WS80
2016 340i - m-sport,tech, cold weather, track, drivers assist
11-14-2014, 10:47 AM | #75 |
Rep 324
Thoughts on ?
19 x 8.5 et 24 front 19 x 9.5 et 30 rear Seems a little aggressive for F31 xdrive
16 435i xdrive Msport MPerformance 2 Ind Azurite on Opal
11-14-2014, 11:06 AM | #76 | |
Rep 1,027
Positive Momentum
doyler4.50 |
01-23-2015, 05:33 PM | #77 |
Rep 417
Hi guys, just wanted to get your thoughts on running a square set up wheels but staggared tires. 19 x 8.5 et 35 all around and basically the oem tire size. F- 225/40 and R- 255/35. trying to achieve a flush or slightly inner look. I have an msport lowered in HR sport springs. Thanks.
02-14-2015, 09:26 AM | #78 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Can someone help me out?
Will be getting a 428xi msport with Msport brakes. Will my current m235i wheels work with spacers? If so what size spacers? Thx Current wheel setup are 18x7.5 (et45) 18x8 (et52) |
02-15-2015, 06:30 AM | #79 |
Rep 5,140
F 12mm and R 15mm make them closer to F30/F32 spec, but you can have even thicker spacers depending on how wide stance you like.
Not sure they will clear the calipers though. |
03-16-2015, 10:25 PM | #80 |
***** noob
1369
Rep 10,479
thanks
What if I use the 225/40/18 tires (this is for Xdrive) and put them on the stock 441M wheels front and back...can that work?
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
03-17-2015, 01:25 AM | #81 | |
Rep 5,140
It will affect your speedo and results in huge wheel gaps (at least if not lowered). If your 441 wheels are staggered the rear tires will also look more stretched since the front wheels are 8" wide and the rears are 8.5". |
03-17-2015, 11:01 AM | #82 | ||
***** noob
1369
Rep 10,479
Looks like I'll need a new set
2006 325xi (Sold)
04-08-2015, 08:54 PM | #83 |
It's not just about horsepower, but how powerful your horses are.
38
Rep 563
Hello Friends currently trying to purchase a set of rims for my wife's 2014 f30 base
Was wondering if 19x8.5 et32 non staggered would fit? Sorry i tried to read how to calculate if it fits but im just lost ahha. Any advise would do |
11-30-2015, 10:00 AM | #85 |
Rep 518
Hello,
I am currently awaiting delivery of a new BMW 340i Xdrive sedan w/ M Sport pakage. I need to get winter wheels when i pickup the car. Just want to confirm if this setup will fit. 18" Double Spoke Style 400M (M Sport wheels) - 18x8" ET34 225/45-18 front Square setup with 225/45R/18 Blizzak WS-80 all around? Thank you |
11-30-2015, 11:12 AM | #86 | |
Rep 765
12-16-2015, 07:07 PM | #87 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I'm running square 225/45/18 397s. Can I run a 255 on the 18x8" wheel in the rear without issues and mix it with 245s in the front without messing up the speedometer?
thanks!
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
12-24-2015, 01:32 PM | #88 |
Rep 6
Terminology?
I'm wondering what ET means in relation to wheel offset? I'm trying to figure out which setup is known to fit with no rubbing on a 2013 328i xDrive.
Thanks and great forum! |
