BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Coilovers Options - Comprehensive Overview
      04-03-2014, 08:44 PM   #133
328if30ri
328if30ri's Avatar
Drives: 328i red 2014 m sport
can some one pm some numbers for the best bang for you buck kit i am in the hunt and looking for best set up out 2014 f30 msport shipped to 02910 plzzzzzzzzzz
      05-30-2014, 03:27 PM   #134
hotlikelavadan
Drives: 2014 Estoril Blue F30
Originally Posted by Presario View Post
Dang, if this really is the case, that is a horrible oversight. Can any recent owners of V2 confirm?
Also, I'm close to pulling the trigger on either the Bilstein PSS9 or CKS. If I go with the PSS9, I'll add my findings to this post.
My V1s have the hex hole, I love the suspension but it makes a bit of noise and I am not the only one who has this problem.
      06-26-2014, 02:42 PM   #135
MulattoMajor
Drives: MG F30
Originally Posted by chugster View Post
http://www.fortune-auto.net/fortune5...scoilovers.htm
Fortune auto has a set of coilovers for the f30! I am currently their beta car for the coilovers and I love these. For more info contact them directly.
Any more info on these? Where did you have the install done?
      09-20-2014, 03:10 PM   #136
NISFAN
NISFAN's Avatar
Drives: BMW M2
Just chipping in to share my option.
I fitted Bilstein PSS10 B16 KOMFORT to my F30 (48-229012). These have a longer spring than the normal B16 PSS10. Lowering is in the -10-30mm range, not the -30-50mm range for the normal version. I didn't want to go that low.
I fitted them because I don't rate the standard M Sport suspension ( I've had both Adaptive and passive, both suck!!!). Verdict, wow what a transformation, the car now rides like an M3/M4, no jokes it really does stick to the road. It is also far less crashy when going over potholes, etc. An amazing transformation
Appreciate 7
      10-14-2014, 03:37 AM   #137
fad
Malaysia
Drives: BMW F30 328
mine is KW V2 installed on my 328i.
after a while i notice the bump stop was destroyed. had my car jacked one time at the local tyre shop for tyre swap and noticed the bump stop is like shredded foam and the dust cover wasnt in tact anymore.
also the rear perch or height adjuster need longer threads, at the highest ride the clearance between fender and wheel is only one finger gap.
hate to drive the in laws in my car cos fender scrub and malaysian roads has lots of potholes.
emailed KW and asked if they have a longer perch than the one that came in the box, apparently they do but they dont post it under spare parts in their website had to order them and they came with coil spring as a set.
in all, i guess KW makes good suspension but really should consider on the options of height, i didnt look at this as a problem in the beginning, but when you are running on 19's with 30 series tyres, hits you like a bitch!
      02-10-2015, 09:41 AM   #138
Marshalltj
Drives: 2012 F30
Ok, so I finally broke down and ordered this setup. Found a great price online for almost 25% off with free shipping.
      02-13-2015, 01:35 AM   #139
Stubok
Drives: Melbourne Red F30 328i M Sport
I just installed the BC Racing Coilovers on my 328 F30, and I'm seriously impressed. Great ride, great adjustability, great look (both car and suspension). All in all I'm pretty stoked.
I posted a review on the BC racing coilover discussion. Pictures to follow.
      02-13-2015, 03:55 AM   #140
hotlikelavadan
Did you get camber plates as well?
      02-13-2015, 10:02 PM   #141
Stubok
I sure did. Letting things settle a bit before I start adjusting camber.
      02-13-2015, 11:30 PM   #142
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
i thought the fronts come with the camber plates included, or are you referring to the rears? also, do you need to replace the oem camber arms (e.g. megan racing camber control arms) in order to adjust camber or is the bc camber plates along with oem arms enough?
      02-14-2015, 11:23 AM   #143
Stubok
The set comes with front camber plates. So camber at the front is adjusted with those. The front has control arms that allow the toe to be adjusted. Not sure about caster.
The rear, I haven't really looked into this. I though the rear camber/caster could be adjusted, but maybe I need to change the control arms to get those right.
      02-14-2015, 11:38 AM   #144
f30luxline
e92 - 335i
Drives: thisonetimeatbandcamp
As already mentioned, the fronts come with the camber plates. Although the verbiage on there site may lead you to believe they may be available for the rears they are not. It's because of the design of the rear, the assembly doesn't go through the body as most cars and previous BMW's do. The advantage of this is you don't have to tear apart the trunk.
Fronts are more than adjustable. Dropped 3" my plates are almost centered giving me equal adjustment either negative or positive. This is with my alignment set more to the conservative side of BMW's spec. From factory only toe is adjustable. (slight adjustments can be made within the strut tower for camber/caster but very minimal)
The rear I had to opt for the upper arms from Megan to get my camber within even the aggressive end of BMW spec. (again, I am set on the conservative side & dropped 3"). From factory it is fully adjustable but obviously only so much. Depending on how much you drop you can get away with the stock arms. You should be able to get away with dropping 2~2.5". I was slightly off the aggressive end at 3".
      03-06-2015, 08:53 AM   #145
TC Kline Racing
TC Kline Racing's Avatar
Drives: Many BMW's & Porsche's
OP, would you be so kind as to update your OP with our kits as well?
Link to both the single and double adjutable
http://www.tcklineracing.com/index.c...y&Category=796
Check out our youtube channel for our kits in action! https://www.youtube.com/channel/UC-1...4hRiTYqJ9JdEhw
Thanks!
Double Adjustable with Camber Plates
Single Adjustable with Camber Plates
      03-15-2015, 04:33 PM   #146
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Thanks!
While I haven't ventured into this section in a bit, I saw you commented in the thread and am happy to update. Since moving on from the F30 I've got the TC Kline kit on my Z4M and it's great!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      03-15-2015, 04:38 PM   #147
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Thanks for the contribution & pic of the set, just updated the original post.
-Matt
      03-15-2015, 04:39 PM   #148
tiltmode43
I plead the 5th.
tiltmode43's Avatar
If anyone else has a kit not listed in OP send me a quick PM and I'll update the original post with pics provided!
-Matt
      03-29-2015, 07:22 PM   #149
cmonter3323
Drives: 428i GC
anything for an F36???
      03-29-2015, 08:04 PM   #150
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Delete
G05 - M Performance roof spoiler
      07-06-2016, 04:52 AM   #151
tmdals0213
tmdals0213's Avatar
Switzerland
211
Drives: 2016 340i M-Sport
seems like a lot of people liked your review! i know i did! i plan on looking into these soon
thanks for the write up!
Diligentia Vis Celeritas
      07-15-2016, 01:57 PM   #152
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
sorry for the mini thread hi jack...
Does anyone know if there's a DIY on how to get the trunk liners out to the point in this picture below? Someone posted it earlier in this thread when showing the KW suspension wiring.
Trying to run some electrical wiring (for an exhaust cutout) from under the car and to the fuse box in the trunk.
      07-16-2016, 06:48 AM   #153
SLOWER
SLOWER's Avatar
Drives: 2003 M3
Lift up the floor tray, it pulls right out. Same with the cubby on the right.
      07-16-2016, 01:29 PM   #154
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
thanks! didn't think it would be that easy lol
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5
2013 Glacier Silver F30 335i (sold)
