03-03-2013, 09:24 AM | #2839 |
Rep 57
I came back out to the car this morning, tried again, and got a connection. I have no explanation. I know that the cable was on securely yesterday because I need a pliers to get enough grip to remove it.
I'm sitting in the car now grabbing some documentation (which I apparently deleted yesterday). As soon as I grab everything, I'll switch off wifi, reconnect the enet cable, and start making my backups. Wish me luck. |
03-03-2013, 02:40 PM | #2840 |
Rep 57
Coding went fairly well and I was able to make the key changes that I wanted.
However, I am having trouble changing certain values. I want to make the cameras and DVD work at any speed. (This is for demo purposes, not actual use. I did DVD in motion for my Audi and never used it after proving that it worked.) When I try to change the numeric values, it seems to not "stick." Does anyone have any ideas? Finally, my warm feet want to offer special thanks to Shawn to for letting me know that the engine and the climate system could be running while I'm coding! |
03-03-2013, 03:29 PM | #2841 | |
Rep 40,768
03-03-2013, 08:11 PM | #2842 |
Rep 383
Its been a little while since visiting this thread... Anyone figure out enabling Office and internet features through phone's bluetooth? I have the menu options showing up but haven't got any further... Office only shows my contacts, no sms or anything. When trying to access internet, it says please activate data connection (even though the option is checked when pairing the phone).
Thanks! |
03-03-2013, 10:59 PM | #2843 |
Rep 40,768
48.3 vs. 49.0 PSdZData CAFD Changes - E-Sys 3.18.4 End of Life
FYI. The difference from 48.3 to 49.0 for the CAFD folder is 56 added and none removed:
Left base folder: C:\48.3_PSdZData Right base folder: C:\49.0_PSdZData Left Orphan Files (0) ----------------------------------------------- Right Orphan Files (56) ----------------------------------------------- cafd_0000000f.caf.005_024_225 cafd_000000b5.caf.010_004_004 cafd_000000b6.caf.010_004_004 cafd_000000c9.caf.003_000_000 cafd_000000f9.caf.007_003_031 cafd_000000f9.caf.007_005_003 cafd_000000f9.caf.007_006_008 cafd_00000a07.caf.002_013_002 cafd_00000a48.caf.000_004_009 cafd_00000b0a.caf.000_024_001 cafd_00000b52.caf.002_010_000 cafd_00000c18.caf.013_064_004 cafd_00000ce2.caf.003_001_017 cafd_00000ddd.caf.003_001_017 cafd_00000ded.caf.002_002_007 cafd_00000e69.caf.002_002_004 cafd_00000e69.caf.002_002_005 cafd_00000ed9.caf.002_000_008 cafd_00000fa2.caf.001_004_000 cafd_000001a7.caf.000_012_004 cafd_000007a1.caf.005_028_006 cafd_000007c3.caf.011_000_000 cafd_000007c8.caf.006_008_004 cafd_000007c8.caf.006_009_004 cafd_000008a6.caf.001_005_000 cafd_0000012f.caf.012_006_021 cafd_0000012f.caf.012_006_022 cafd_00000014.caf.004_055_014 cafd_00000014.caf.004_055_214 cafd_00000018.caf.004_010_001 cafd_0000029b.caf.000_008_001 cafd_00000044.caf.008_005_000 cafd_0000067b.caf.002_003_142 cafd_00000069.caf.009_001_004 cafd_00000069.caf.009_001_006 cafd_0000090a.caf.004_001_017 cafd_00000092.caf.004_002_027 cafd_0000106d.caf.012_006_016 cafd_0000124f.caf.000_004_004 cafd_0000157f.caf.008_000_001 cafd_00000163.caf.007_001_009 cafd_00000163.caf.007_001_031 cafd_00000223.caf.013_008_004 cafd_00000286.caf.001_006_000 cafd_00000552.caf.001_029_001 cafd_00000553.caf.001_038_001 cafd_00000694.caf.003_003_042 cafd_00000721.caf.003_006_000 cafd_00000760.caf.006_000_051 cafd_00000794.caf.004_228_005 cafd_00000893.caf.006_050_012 cafd_00000896.caf.006_023_003 cafd_00000912.caf.003_007_009 cafd_00000913.caf.003_004_003 cafd_00001016.caf.001_003_000 cafd_00001060.caf.003_001_003 ----------------------------------------------- ISTA/P 2.49.0 Fxx Integration Levels F001-13-03-501 F010-13-03-501 F020-13-03-501 F025-13-03-501 ----------------------------------------------- NOTE: The 49.0 PSdZData release marks the end-of-life for E-Sys 3.18.4. The changes made to the F20 PSdZData in 48.3 are now across the board in the 49.0 PSdZData. Old Patch / Tokens will no longer work for any chassis. To use the 49.0 PSdZData, you must upgrade.
03-04-2013, 12:03 AM | #2844 | |
Rep 664
Drives: 2013 BMW 335i
03-04-2013, 12:51 AM | #2845 | |
Rep 67
03-04-2013, 02:00 AM | #2846 |
Rep 664
03-04-2013, 02:26 AM | #2847 |
Rep 67
03-04-2013, 05:48 AM | #2848 |
Rep 40,768
Sorry, I have no idea on that.
03-04-2013, 05:49 AM | #2849 |
Rep 40,768
If you have working 3.22.5 and 48.3, you do not need to upgrade again.
03-04-2013, 06:43 AM | #2850 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
REM>3061>RFS_L_IS_LED REM>3061>RFS_R_IS_LED set to active or REM>3061>RFS_L_KALTUEBERWACHUNG REM>3061>RFS_L_WARMUEBERWACHUNG REM>3061>RFS_R_KALTUEBERWACHUNG REM>3061>RFS_R_WARMUEBERWACHUNG set to nicht_activ |
03-04-2013, 07:50 AM | #2851 | |
Rep 84
woah@@ . That's was fast! I just got my hand dirty on 48.3 only a few weeks back.
hi bro shawn, can pass me the link for the orphan files and do I just copy into the same folders as 48.3? Thanks bro. Quote:
03-04-2013, 08:35 AM | #2852 |
Rep 383
Just wondering... Why would someone need the new version of the software and/or the psdzdata if they have a 2012 F30? Or is it only for newer builds...? Thanks.
03-04-2013, 11:46 AM | #2853 |
Rep 664
THank You i will give that a try. I saw some stuff similar to that online but it wasnt for the f30. but it did come in that type of ending for each code. not an experience coder so didnt want to mess around.
03-04-2013, 02:23 PM | #2854 |
Rep 29
Hello everyone again!
I have an issue I don't know if it can be solved by coding or more likely by programming. My Driver side seats are moving forward when I push it back words and the same opposite way when I'm tryin to lower it (goes up) And my moon roof is nut functioning at all no matter how I try to press the button. Does anybody know anything about the programming or where should I try to find solution for it? (Its an F13 with panoramic moon roof and comfort seats) Thx! |
03-04-2013, 07:52 PM | #2855 |
Rep 101
this a longshot, but is there anyone close to the Omaha, NE area that is able to code my car for $50. I need to remove the drl and parking light error and well as some other mods.
03-04-2013, 07:59 PM | #2856 | |
Rep 490
Some screenshot would be helpful |
03-04-2013, 08:01 PM | #2857 | |
Rep 490
03-04-2013, 08:53 PM | #2858 | |
Rep 746
Everything codes ok, just an error when going into BMW Live/Online. It attempts to open for about a minute, then comes up the error in the picture. Internet browsing works fine so I know the tethering is working ok.
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
03-04-2013, 09:09 PM | #2859 | |
Rep 67
I coded 614, 6AL fine into the car. The Internet browser works fine. When I load BMW Live it tries to load and then gives a nessage sayibg "Internal Error". See this post http://www.f30post.com/forums/showpo...98&postcount=2 I get the same error. Regards, Rajesh |
03-04-2013, 09:41 PM | #2860 | |
Rep 490
