08-17-2023, 12:53 AM | #23 |
Rep 1,117
08-17-2023, 06:45 AM | #24 |
Rep 66
08-17-2023, 12:48 PM | #25 |
Rep 1,117
08-18-2023, 02:37 AM | #26 |
Rep 66
This was my post:
For anyone looking for this info, the original shocks on my AH3 are: Front - 31316791555 Rear - 335267911588 Which part of that "makes it sound like one size fits all". Again (in th ewords of an infamous Aussie politician) Please Explain... |
08-18-2023, 02:55 PM | #27 | |
Rep 1,117
Easy. Should have posted. “I have the rare EDC Adaptive M Suspension on my AH3 and the part numbers are Front - 31316791555 Rear - 335267911588 If your AH3 came with a M Suspection or Stock Suspension, the part numbers are different” Would gave been much more helpful. |
08-20-2023, 04:36 AM | #28 | |
Rep 66
BTW I don't have EDC Adaptive M Suspension. You should have posted "Should have posted I have the stock Suspension on my AH3 and the part numbers are xxx" Should I get upset about you posting inaccurate stuff? Do you even have an AH3, and if not, why are you trying to police this thread? I think you need to think about why you are getting butt-hurt about an innocuos forum post that doesn't reference you in any way, and consider getting professional help (or, you know, a life). I hope you manage to get over it soon. |
08-20-2023, 06:37 PM | #29 |
Rep 18
Upcoming projects:
09-09-2023, 05:38 PM | #30 |
Rep 18
Did the intake valve spray clean, through the MAP sensor port just before the throttle body, and cleaned the MAP and MAF sensors with CRC MAF cleaner while I was at it. Changed oil a day later. Noticeable difference! But with that as the first such cleaning in the car's 130k+ miles, I will do it again in 1,000 miles as per CRC's recommended interval. Then I'll do it before every oil change.
This time I just stuck a piece of clear plastic gas-siphon tubing I had in the house into the MAP port. But it barely fit as it was too big to actually push into the hole, which meant it was also too big for a snug fit of the sprayer tube at the other end. For the next clean I will use a narrower tube, threaded through a hole I will drill in a small rubber stopper that will snug into the MAP port. I think this will provide stronger suction of the cleaner into the throtlle body and maybe disperse it more effectively throughout the intake manifold. Anyway, beats paying a thousand bucks or whatever the shop would charge me for walnut blast, a procedure I will not attempt myself. |
StradaRedlands4977.50 |
09-09-2023, 05:44 PM | #31 |
Rep 18
As for the Burger Motorsports oil catch can, I have attempted for the second time to ask them if their unit for 2012-2016 335 F30 N55 cars fits my 2013 AH3. I can't see why it wouldn't but want confirmation. They did not amswer my first email. I do like that their unit uses larger hoses to keep the crankcase pressure what it is without the catch can installed.
09-09-2023, 06:16 PM | #32 | |
Rep 1,117
10-21-2023, 02:19 PM | #34 |
Rep 18
CRC GDI IVD valve cleaner spray hack
Made a short vid of a quick hack to make it easier to inject the CRC GDI IVD valve cleaner into the throttle body. Short version: A 00 rubber stopper snugs perfectly into the hole where the MAP sensor inserts into the intake at the throttle body; a silicone tube through a hole drilled in the stopper lets you inject the spray perfectly into the intake pipe, and the snug fit of tube through stopper, stopper into port and the product's spray arm into the other end of the tube ensures good suction of the spray bursts down the tube and into the intake. Make the gizmo once, use it over and over in the future.
This trick should work for any car where the insertion point you use has a round port; find the size rubber stopper that gives you a snug fit. https://youtu.be/V0e0Pf9SAVA?feature=shared |
11-20-2023, 05:41 PM | #35 |
Rep 6
11-20-2023, 09:45 PM | #36 | |
Rep 1,117
As for finding VIN, Bill of Sale, Title, Registration, Insurance Docs, Driver door / B column, Windshield slot, possibly Engine Compartment, some are behind rear license plate or simply read the car with an ODB scanner. If you still cannot find it, you are out of luck. |
11-21-2023, 03:46 AM | #37 |
Rep 6
Hey guys AH3 owner here, so curious to see if anyone else that owns one has re mapped it yet ? I have stage 1 ecu and the re mapped gearbox 8speed transition, (XHP ZF) she’s a beast but haven’t jumped on a Dyno yet
Any know how accurate the sports displays are on these bad boys? |
11-21-2023, 04:08 PM | #38 | |
AH3 Owner
206
Rep 312
Drives: BMW 335i ActiveHybrid 3
Tags |
335 active hybrid, active hybrid 3, active hybrid worth it, activehybrid 3, bmw active hybrid 3 review |
