04-10-2017, 02:15 PM | #265 |
Rep 2,989
I finally resolved my issue and it turns out that it was a matter of a poor connection(s). I ended up using the replacement pins that are listed elsewhere in this thread. They still didn't seat as firmly as I would have liked them to, but they slid in far enough that the brown pin bank slid into the harness connector without any resistance.
Previously, I had to muscle the bank into the harness and it was distorted somewhat. It does seem as though the replacement contacts are a better fit for the bank. |
04-24-2017, 08:57 PM | #266 |
Rep 740
Just finished the retrofit. Thank you to the ones contributed!!
Some added notes: The replacement pins listed a few pages behind does work but will not click in place. Make sure you push it enough that the connector housing channel clears the new pin (if you look along the channel as you push in the pins, you'll know what I'm talking about). I noticed when placing the new pins into the harness, the pins were touching behind each other. Watch out for that. I placed a small strip of electrical tape between the two rows. Initially, after finishing the retrofit, I got the dreaded PDC error. Ran ISTA/D and it shows an error on center left - no communication. Pulled the REM harness back out and I accidentally placed the pin one spot over (I had it in 52 and not 51). Took 2 minutes to fix this. Using the step drill bit tool and stopping at 18mm was a bit tight fit. The rubber gasket on the sensor wouldn't fit right without pinching. I could've opened it a tad bit more as the sensor isn't flushed with the bumper. I may fix that another day. When testing out the PDC, I have this tiny delay when displaying objects and trying to figure out if this normal or not.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
05-01-2017, 09:19 AM | #267 |
Rep 740
For those looking for the PDC sensors...18.99 each OEM BMW (black) and free shipping! (Not affiliated with the seller, just helping other members out.)
http://www.ebay.com/itm/301733207844...%3AMEBIDX%3AIT
08-14-2017, 08:09 PM | #268 | |
Rep 47
ISTA+ was reporting this as well: REM 80320E: Ultrasonic sensor, rear outer left, sensor fault: Programming - The ultrasound sensor has a fault in the sensor programming. - The fault code entry happens if the ultrasonic sensor was not programmed correctly at the supplier's place. Thanks to all |
08-31-2017, 07:12 AM | #270 |
Rep 44
hi can anyone verify the connectiins i have madde from the front bumper pdc plug to the rem...
Pin 1 front pdc to pin 48 rem Pin 2 front pdc to pin 36 rem Pin 3 front pdc to pin 53 rem Pin 4 front pdc to pin 40 rem Pin 5 front pdc to pin 41 rem Pin 6 front pdc to pin 52 rem is this correct? |
09-06-2017, 07:56 AM | #271 |
Rep 3,055
Hello,
I've retroftted Rear PDC to my F30. I bought used REM(700) and VO CODED it.Before that i've added 507 to SALAPA and also VO CODE HU_NBT. ISTA+ says that two sensors are not responding(two on the right side). I've checked the voltage and the sensors(I've switched them with the left side) and that is okay,(voltage is about 11V on power wire and sensors cable).I read I-STEP and it's 14-07-505(current) and it was 14-07-503(last and shipment). I've tried to DETECT CAFD FOR SWE to match my current I step level(it's 14-07-505) and after I press CODE(REM) E-SYS says that "target svt does not match to TAL data". Am I doing something wrong? Don't know where to look, is it physically in connections or in sensors or it's something connected with coding. On iDrive screen I have "parking assistance not available). Any help will be appreciated. THANKS! |
09-22-2017, 02:40 AM | #272 |
Rep 1
Hello I have F32 428i 2013.11 with NBT. I want install front and rear PDC. What i understand i need replace REM p/n 61359329703 V4. With what p/n I need buy REM?
10-22-2017, 10:47 AM | #273 | |
Rep 1
Same problem F20
I have just installed the kit (rear) in my F21 and I got the same problem (no pdc on my car originally), after changing REM (re-used), installing all the sensors, adding 507 on SALAPA, and coding HU_NAV and REM (new CAFD generated..). Not errors while coding but the same error message I can see when selecting reverse. It was quite difficult to fully introduce the pins (REM), and more difficult to get the module back into the connector. Reading your posts I think could be the same, problem of poor connection or so. Did you finally solve the problem changing the complete connector and pins? I have to install ISTA or similar for errors detection. I appreciate any help on that. Best regards. |
11-25-2017, 08:26 PM | #274 | |
Rep 765
01-13-2018, 04:52 PM | #277 |
Rep 17
02-01-2018, 06:16 AM | #279 |
Rep 1
Problem with CAFD
Hello,
after I swap my REM with a 700,and I tried to code it. The problem is that CAFD for my I-Level ist not listing (see picture), although I use PSdzData 61.5. My I-Level is F020-15-07-502. I'm grateful for any advice |
02-12-2018, 01:01 PM | #281 | |
Rep 765
Are u sure they are oem??
02-12-2018, 01:27 PM | #282 |
Rep 740
I'm 99% sure I saw BMW stamp and part number on it as I wanted to keep everything OEM (excluding the wiring that couldn't be bought). Send a message to the seller and confirm with them.
04-24-2018, 03:16 PM | #284 |
Rep 941
If anyone is looking for parts for a front and rear retrofit hit me up.
I have all the original brand new BMW parts never installed as well as 8 PDC sensors and front and rear harness. Also have the REM module with correct pinout. Never got around to installing it. Thanks
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
04-28-2018, 12:49 PM | #285 | |
Rep 765
Is this tru that no line bumpers are not marked? Or maybe he jus didn’t see the real faint cross that marks the spot? Anyone else with no lone who did this have the marks for the sensors?
Thank you. Quote:
