03-01-2016, 01:47 AM | #45 | ||
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
03-01-2016, 08:08 AM | #47 | |
Rep 67
I have the following values but doesn't seem to do anything. The folder location is correct. PHP Code:
03-01-2016, 10:58 AM | #48 | ||
Rep 902
Mine which works.
03-04-2016, 03:39 PM | #50 | |
Rep 208
I played around in the software but I haven't found any option... |
03-04-2016, 07:24 PM | #51 | ||
Rep 902
03-05-2016, 01:27 AM | #53 | |
Rep 902
03-05-2016, 10:55 AM | #55 |
Rep 208
It worked without knowing the level installed. I have slected an old Level and everything worked fine. Now the f34 Can be selected in champ2 and the graphics display the correct car.
03-05-2016, 01:57 PM | #56 | |
Rep 902
03-05-2016, 04:04 PM | #57 |
Rep 208
Perhaps your computer is faster than the Dealer one...? ;-)
I have made the Upgrade with esys. In Ista I get a "connection to car lost" error everytime when I calculate the measure plan... |
03-06-2016, 12:25 PM | #58 | |
Rep 902
03-06-2016, 02:24 PM | #59 |
Rep 208
So you just selected Firmware Upgrade in Rheingold and then the measure Plan calculated the Time and afterwards the upgrade was performed? Did Ista show you which ECUs will be affected prior starting the Upgrade process?
03-06-2016, 02:25 PM | #60 | |
Rep 902
03-06-2016, 02:53 PM | #62 | |
Rep 902
03-06-2016, 07:20 PM | #64 | |
Rep 902
Using ISTA or ESys not sure what that issue is.
03-14-2016, 12:11 PM | #65 | ||
Rep 67
03-14-2016, 01:22 PM | #66 |
Rep 3,940
ecu flash |
