01-27-2020, 10:09 PM | #45 | |
Rep 340
01-28-2020, 06:29 AM | #46 | |
Rep 159
I guess the key thing to change is caliper type because SPBR did change that for rear and front. I compared the stock CAFD file with SPBR modified one by saving the CAFD before and after adding SPBR HO_Wort. |
01-28-2020, 01:03 PM | #47 | |
Rep 340
https://f30.bimmerpost.com/forums/sh....php?t=1517682 |
01-29-2020, 03:46 AM | #48 | |
Rep 159
01-31-2020, 11:34 AM | #49 |
Rep 79
My biggest concerns with this would be the changes in bias and pressure-torque transfer function, neither of which would be immediately obvious by just driving the car but may cause issues with safety in an emergency stop.
1. Brake bias- I can't find info on piston size for the standard brakes, and what I can find for the M sport is questionable (44mm x 2 rear, 40mm x 4 front). That gives a pretty rear-biased setup (63/37) which is pretty normal for an EBFD car. I *thought* I remembered finding that standard rear calipers had a single 38mm piston. If anyone knows for sure, please post it up. If that IS the case, that's much more forward biased (69/31). That means that running M Sport brake code on standard brakes would tell the ECU to pull back rear brake pressure a lot sooner than it should, and you could sacrifice significant stopping distance since the rear brakes would not be doing as much work as they could be. If the rear pistons are the same size for all, then it's not as much an issue. 2. Pressure-torque transfer function- This is the bigger concern for me at least. The brake ECU assumes a certain transfer function for pressure vs. torque. In other words, it assumes that every psi in the system generates xx ft-lbs of brake torque at the wheels. The M Sport brakes will generate more brake torque per psi of brake system pressure because they're acting on a larger rotor (lever arm). Changing this value means the ECU now expects a different brake torque for a given line pressure. If you're in a situation where the brakes are decelerating at a certain rate due to lockup, the ECU will try to bleed pressure to restore traction. It's now using the wrong value for how much pressure to bleed. M Sport brakes will need less pressure bled off for the same reduction in brake torque at the wheel, so your brake ECU will now undershoot its target and the wheel will continue to lock up. Whether this is an issue depends on how aggressive and responsive the PID loop is inside the controller. It could be that it works fine on dry pavement, but locks up on snow and ice. If you do this, I suggest doing some real-world testing in controlled conditions to evaluate whether it's affecting things negatively. You might not feel any difference in day to day driving, but there's a real chance you could be negatively affecting the system in safety-critical conditions and you damn well better know what those effects are before you drive it on public roads. |
rybski52.00 |
02-22-2020, 07:28 PM | #50 | |
Rep 3,032
Drives: 2019 M2 Competition
Reserecting a very old thread, but these are GREAT instructions but missing really critical pieces, plus I get an error I cannot figure out. Running esys 3.27.1 with psdzdata 4.21.32 trying to code for SBPR => Connect (select 19_11 F20) and connection via VIN => Expert Mode => Coding => Read FA => Save FA (save to file name file.xml) => Editors and viewers => FA-editor Select file.xml in the select window => Go to HO-Wort and right click on "Edit," then type "SPBR" under the HO-Wort file There is no edit.. right click on HO-Wort and select New - > HO-Wort. This gives a nested option under HO-Wort, name it SPBR => Expert Mode There is no enable FA, I can only find that back under the coding section => Coding => Select the FA, right click "Enable FA" and "Calculate FA" to verify that no errors are found after adding the SPBR. I get this error: No FP could be generated from FA "". [C002] no FA2FP known for Entwicklungsbaureihe F032 [858] Cannot continue past the error => Check the vehicle profile to locate the "" aftermarket retrofit "and check" SPBR_18_ZOLL_SPORTBRAKE "has been added to the file => Write (write) FA to your car. No confirmation window will appear after saving the FA to the car Where is this function? Is this under coding? Maybe I dont see it yet because I cannot activate the FA => Expert Mode => Coding => Read (read) the FA. You are able to see SPBR be added to the HO-Wort folder on your car. => Read SVT, and locate the "DSC" (File Folder SVT / ECU / DSC), then right-click the "DSC" folder and select "Code". Consolidation should start immediately. => Allow the coding is over, and repeat step 1 to save a copy of the new FA.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 02-22-2020 at 07:57 PM.. |
02-23-2020, 10:42 AM | #51 |
Rep 3,032
Wow.. talk about beating my head on a rock, but finally the IT skills started to kick in and I think I have this solved.
What I noticed as I deleted and copied and deleted and copied the PSDZDATA folder like 100 times, is it was like 7k files. I tried another laptop just in case, and when I extracted the data rar, I noticed it was like 12k files.. wait hold on. Went back to my primary laptop, uninstalled everything, reinstalled 3.27 and the launcher, plus a FRESH download of the data lite file and extracted again (12k or so files whatever, but a lot) and then copied THAT into the correct c:\data location.. Launch.. connect... read.. hit activate FA on the file.. BAM 10ish seconds later its ACTIVE! Calculate works now too, in about 5 seconds. I haven't coded the car yet, but I think this came down to a bad extract of the data file the first time and missing files. No !#$!#$!#$ clue how that could have happened, but it appears to be working now. The instructions are still missing a layer of granularity to make the steps easier, but at least I think my problems are solved.
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
02-23-2020, 10:45 AM | #52 |
Rep 3,032
I dont see the "write" function or a button that seems to show that..
02-23-2020, 10:50 AM | #53 | |
Rep 40,969
BMW DIY Guy3086.50 |
02-23-2020, 12:04 PM | #54 |
Rep 3,032
Success! I thought I would write up the instructions again to make it all a little more clear, so painful NOOBS like me to VO coding might have less trouble.
Use the correctly configured and tokened launcher Pro with esys 3.27. Plug enet cable into your car and laptop, ensure you give enough time to get link lights on your laptop. (Mine takes about 5 seconds) Top Navigation bar: => Connect Select 19_11 F20 (or appropriate model, F20 is correct for F3X models, NOT _direct options) and connection via VIN option (field should be populated with your VIN if it can see your car. If not, check your cable), click connect. Lefthand nav bar => Expert Mode => Coding => Read FA button => Save FA (save to file name whatever you want, file.xml) => Editors and viewers (or click EDIT button after previous step) => FA-editor Select file.xml in the select window => Expand FA folders (FA, FZAuftrag, Type) to HO-Wort and right click on "Edit," then type "SPBR" under the HO-Wort file There is no edit.. right click on HO-Wort and select New - > HO-Wort. This gives a nested option under HO-Wort, name it SPBR => Expert Mode => Coding (It will ask if you want to update to the edited file, YES) => Select the FA, right click "Enable FA" Will take roughly 10 seconds, Check the vehicle profile to locate the "" aftermarket retrofit "and check" SPBR_18_ZOLL_SPORTBRAKE "has been added to the file => Expert Mode => VCM => Lower section File tab, Vehicle Order, ... to select your modified FA file. => Right click on loaded FA, Calculate FA => Lower section, Master tab, Write FA FP No confirmation window will appear after saving the FA to the car, though far lower left you can see a small message saying FA written. => Expert Mode => Coding => Read the FA. You are able to see SPBR be added to the HO-Wort folder on your car. => Read SVT button on the right, and locate the "DSC" (SVT window, expand ECU, find DSC folder), then right-click the "DSC" folder and select "Code". Coding should start immediately. You make get a message you need to activate the FA, if so, right click and activate, then code DSC. Fun happens.. car will chime, may get a brake error.. coding will finish, last screen should be success and close. => Once the coding is over, and repeat step 1 to save a copy of the new FA. You can double check that SPBR is now under WO-Wort => Click disconnect, then uplug from your car. Enjoy!
Onizukachan1118.00 FastFrog143.50 |
08-12-2020, 09:45 PM | #55 | |
Rep 48
Can this coding also be done using bimmercode?
08-12-2020, 09:51 PM | #56 | ||
Rep 3,032
