02-12-2013, 11:41 PM | #1 |
Rep 615
Drives: 2017 G30 540i M Sport
Garage List 2002 BMW Z3 Roadster [0.00]
2007 BMW 335i Coupe [0.00] 2012 BMW 335i Sedan [0.00] 2006 BMW M Roadster [0.00] 2017 BMW 540i [0.00] 2015 BMW 428 Gran C ... [0.00] |
F30 Wipers - How to Get Them Away from the Windshield
So I've RTFM, and the directions on how to get the F30 wiper blades away from the windshield (to clean the glass) aren't doing it. So can anyone solve the mystery - how do you do it?
Mine G30 540i M Sport Hers F36 440i Gran Coupe |
02-13-2013, 12:29 AM | #2 |
Rep 3,566
Easy. Switch the ignition on and then off. Lift up the wiper switch till it won't lift any more. Let go. Wait until the wipers sweep across the screen twice. They will come to rest in a vertical position. Carefully lift each blade back off the screen and clean.
02-13-2013, 10:23 PM | #3 |
Rep 615
OK, so here's the missing step in the owner's manual - after shutting off the ignition, you also need to shut off the electronics. Won't work with ignition off but electronics on. Thanks.
02-15-2013, 12:21 AM | #4 |
Rep 686
The fact that we have to go through this just to raise the wipers irks the hell out of me.
I can understand it's probably for aerodynamics, but it's very possible someone may try to raise the wipers without knowing the procedure and damage them. Is this how it is for all BMW's? What about Mercedes,Audi, Lexus? |
02-15-2013, 12:56 AM | #5 | |
Rep 490
02-15-2013, 07:02 AM | #6 | |
Rep 3,566
It's pretty obvious that neither wiper can be lifted terribly high in the off position, so unless one is very heavy handed, I believe there shouldn't be terribly many 'injuries' to the hood. The F30 is the first model since the E36 (cannot comment on the E30 and earlier as I never owned one) I have had to go through this routine. All wipers on the E36, 46 and 90 lifted off from the horizontal off position. My wife's C180k's wipers lift off from the horizontal off position.
02-15-2013, 07:19 PM | #7 |
Rep 615
At least for the F30, BMW reverted to a physical thumb wheel to control interior lighting. On the wife's E92 it was controlled through iDrive...not good.
02-15-2013, 07:22 PM | #8 |
Rep 5,803
pisses me off that it will dry sweep the windshield twice.
kern4174446.50 agootz9f300.00 |
02-15-2013, 07:28 PM | #9 | |
Rep 615
02-15-2013, 07:55 PM | #10 |
Rep 615
Look at the upside...you're driving an Estoril Blue MSport.
02-15-2013, 08:16 PM | #11 |
Rep 189
Unless you have a nice wife, who wants to be helpful and tries it, without knowing that it is not as simple as it seems
2016 F26 Alpine White M40i
2014 F25 Alpine White 35i Sport - Retired 2012 F30 Melbourne Red 335i Sport Line - Retired 2007 E92 Space Grey - Retired |
02-15-2013, 08:45 PM | #12 |
Rep 5,803
True.
05-10-2018, 05:30 PM | #13 |
Rep 225
chenry2357.50 WallySlash96.00 |
05-10-2018, 07:52 PM | #14 | |
Im real pressed.
104
Rep 203
05-11-2018, 07:09 AM | #15 |
Rep 303
I just pull a wiper up from the windshield a few inches and while holding it with one hand, I wipe the windshield with the other. Easy day. It doesn’t hurt the wiper and you don’t have the wipers rubbing on the windshield when trying to get them in the 12 o’clock position. This works for wiping down the windshield but not fir changing the wipers of course.
05-11-2018, 07:20 AM | #16 |
Rep 16,080
+1. Having the wipers set below the hood not only improves the aerodynamics of the car but also reduces noise. The aerodynamics don't matter all that much at 70MPH, but they do at 100MPH or more. You only need to put the wipers in the up position to change the blades, and as that's only a once a year proposition probably done by your shop anyway it's not big deal, unless you're a perpetual whiner unable to either RTFM or search out a youtube video.
