BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Who says the factory boost control system can't make big power?
01-04-2008, 09:49 AM | #68 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
can you post up the corresponding Air/Fuel graphs or wideband readouts for those charts?
thanks |
01-04-2008, 10:56 AM | #71 |
Rep 983
I am more and more impressed at your achievements Terry. You are showing the world that you surpass many competitors with a fraction of the logistics.
Congrats, great numbers. |
01-04-2008, 10:57 AM | #72 |
Rep 2,587
01-04-2008, 11:00 AM | #74 |
Rep 1,600
Drives: e90 335i
01-04-2008, 11:00 AM | #75 |
Rep 2,587
They are below the dyno graphs. The dyno wideband reads 1/3 pt leaner than my LM1 in car wideband for some reason, but I trust the LM1 ratios as they've matched exactly on other dynos.
01-04-2008, 11:36 AM | #76 |
Rep 2,587
Thanks! I've always taken the "keep it simple" approach to things. It doesn't give you the best profit margin, but makes for a simple and reliable setup. This dyno is just an example of that. If you compare it to other posted 400rw dyno charts you'll immediately see why I stuck with the factory boost control system.
01-04-2008, 11:44 AM | #77 | |
Rep 256
terry, or shiv, or whoever, one of you guys should hook up an obd2 reader to your car with/without this cone filter setup and check your intake air temperature readouts. i can see how the cone filter setup might gain power on a dyno with the hood open and fans blowing on it, but with it closed and no heat shield i wouldn't be surprised if you were actually losing power. when i first got my M3 i made my own 'cold air intake' that turned out to be a 'hot air intake' and i made worse than stock numbers. sure it sounded nice, but that's where it ended with me. as soon as i got a proper cold air intake setup my car seriously woke up. the only thing i can think of that is an advantage (if you see it that way) is if the air was warmer, but there was more of it coming in you might see a slight bump in power...but that situation is also more dangerous with higher chances of detonation due to the temps. i'd just really like to see some testing done on this setup, because i'm a skeptic at this point and i don't even own a 335 btw, great numbers terry!
01-04-2008, 12:04 PM | #79 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Great job terry. Looks like the intake was good for some extra horses. So how many H pills can you stuff in there? So I guess we are at a JB2HHR now? lol.
Keep up the good work. Hands down the most cost effective set up so far. |
01-04-2008, 12:07 PM | #80 |
Rep 2,587
JB2H^2R. 2 is probably the limit, it just depends on the car. Some cars can't even use 1 H pill.
01-04-2008, 12:11 PM | #81 |
Rep 954
Drives: 2008 AW 335xi
Juice Box makes some nice power. It will be interesting to see if my 335xi has a chance at 300+WHP with the JB2. With the R im sure it does. Hopefully I dyno stock around 250-260ish WHP. Can't Wait.
01-04-2008, 01:30 PM | #82 | |
Chief Executive
300
Rep 2,886
I'm assuming the dyno readout was based on a wideband 02 sensor? Great stuff. |
01-04-2008, 02:14 PM | #83 | |
Rep 2,587
01-04-2008, 02:51 PM | #84 | |
انا خارج الكلبه
Rep 401
I'm sold on the DP's...just need to receive the custom fabricated set. All the best to you at the track. You'll hook-up well!
01-04-2008, 03:35 PM | #85 |
Rep 2,587
Sounds good! Get that 12.4x on drag times too...
01-04-2008, 04:47 PM | #87 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
01-04-2008, 04:59 PM | #88 | |
Rep 2,587
It's just two 3" air filters with 2"->3" magic muffler couplers. Actually the couplers could stand to be a little bigger, maybe 2 1/4". |
