02-26-2018, 12:33 PM | #67 |
Rep 832
Drives: 2019 G01 X3
Nice car and mods so far! Looking forward to hear/see how the KW V1’s work out for you.
What are the wheel specs? |
02-26-2018, 02:51 PM | #68 | |
Rep 1,467
Its been awhile since I installed them or even drove the car lol but i think 19x8.5 235/40/19 front, 19x9.5 265/35/19 rear. The rear is going to be extremely tight. I will probably have to run the coilovers on highest setting and possibly dial in some negative camber. The front should be good, i hope that monster gap disappears. It should look worlds better once im done. The coilovers have been delivered, so now its just a matter of me figuring out the best way to install them. Any reason why I couldn't install the rears one day and the front on a different day?
03-04-2018, 11:09 AM | #69 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
Insane435477.50 |
03-04-2018, 08:19 PM | #70 |
Rep 1,467
The car is still in storage. Until the weather breaks, I wont install the coilovers. I plan on taking the car to a rent-a-lift and knocking it out. I'm thinking in 2 weekends I should be able to do it.
ceedawg467.50 |
03-04-2018, 09:24 PM | #71 | |
Rep 2,639
03-04-2018, 09:43 PM | #72 |
Rep 1,467
I think offset will play a part. I have ET35
03-05-2018, 06:33 AM | #73 |
Rep 2,639
I had ET42, but I still think ET35 should be okay, KW V1 doesn't drop as much.
03-13-2018, 06:58 AM | #74 |
Rep 1,467
Made a little more progress. I installed the AFE dry intake - drop in filter. I also managed to change both Oil Filter Housing Gaskets. This job took me about 2.5 hours start to finish. I took it slow even though I have done this before on my N52 car. I would say if you have some free time and need to fix this leak, I would DIY. Mine wasn't leaking too bad yet, but i do have 55K miles and I could start to see it failing along the back and slightly in the front.
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 Last edited by Insane435; 03-13-2018 at 07:44 AM.. |
04-14-2018, 10:55 PM | #75 |
Rep 1,467
The KW V1 suspension is finally installed.
04-14-2018, 10:57 PM | #76 |
Rep 1,467
Bootmod3 installed:
04-15-2018, 01:40 PM | #78 |
Rep 190,807
04-15-2018, 02:17 PM | #79 |
Rep 1,467
RIDICULOUS. Transforms the car and I have so much more confidence. Ill let you know how it tracks. I have an event this coming Saturday.
04-25-2018, 09:43 AM | #85 |
Rep 1,467
Yes. There's so much more potential i can unlock with a custom tune as well.
04-25-2018, 09:44 AM | #86 |
Rep 1,467
I had no issues on the track. I'm at less than 1 finger gap all around.
05-08-2018, 08:50 AM | #87 |
Rep 1,467
I just installed the Power Stop Track day pads. The bite is very good, however, I am squealing like no other. These are worse than my original M sport pads. I am going to take them out and grease the pads tonight. I tried using this Permatex Brake Quite instead, but with no luck. I should have stuck with what I know works. I am also going to flush brakes and use Motul RBF 600. I will report back on the track results this weekend!
05-08-2018, 09:53 AM | #88 | |
Rep 2,639
They squeal asf and the fade very quickly on the track. |
