01-23-2018, 10:21 AM | #46 | |
Rep 158
You just said what I said but worded it differently. Fact is, the JB4 has no idea what the Timing target is that's programmed into the DME if its not factory timing (or whatever BMS programmed it with). And just about every person running the JB4 is not on factory timing, because most have custom BEFs. So again, the JB4, does not know what timing the DME is shooting for. We both agree here, it bases its logic of "Good timing to raise boost" off of an average. That very logic is why it REQUIRES several pulls to know whether or not to increase the boost in respect to boost additive or reduce it. FACT, DME pulling timing is and will always be faster than the JB4 reacting over several pulls. Because like I said the DME pulls timing and reduces and raises load in real-time (instantly) as a function of what ever settings you tune into it. I'm not sure how I can explain it any better. Sure, there are times a quick large knock may not be caught be the DME and cause catastrophic failure. It happens on Racecars with hundreds of thousands of dollars into tuning and logging equipment (on just one car). So for you to make a post (portion of) insinuating that the JB4 would catch it, is quite silly. Yes, flow reading tied to the DME would improve things (which is coming with flex fuel). But everything I say is true. But, I'm not going to keep going back and forth about it. So I'll agree to disagree and move on. I appreciate your input though, and I'm sure other do as well. |
FSociety3812.50 |
01-23-2018, 10:29 AM | #47 |
Rep 352
The fact is that seeing this "debate" is good for everyone. Is good for people like me who want to learn more about how Flash DME or Jb4 BEF works.. Pros.. Cons.....
With all this information every person can get to their own conclusions and choose any of the solutions. Thank you for for the information to you both Twisted Tuning and Mike. More info is always welcome. |
01-23-2018, 11:56 AM | #48 | |
Rep 115,980
Having the JB4 able to run autotuning logic provides a lot more flexibility over anything the DME can do itself as you're not confined by the DME's logic paths. It takes the DME quite a bit of knock before it decides to travel down the super knock load and fueling tables. With the JB4 you can program it to do whatever you want as quickly as you want. And with the ability to do back end flash maps now there is an endless world of possibilities on the tuning end. These are not mutually exclusive technologies. BMS always says do as much as you can on the flash side and then use the JB4 to do everything else. As far as WMI is concerned JB4 is a much better and more feature rich piggyback than the torque byte piggyback you're using that doesn't have CANbus or even 10% of the functions a JB4 provides. And BMS provides those back end flash maps fully unlocked fully free so customers who want to tweak things or hire 3rd party tuners still can to fine tune as much as they want. Anyway it's early days in development so as things progress I'll post more details on the various things those trying to tune flash only are missing out on. Mike |
01-23-2018, 01:25 PM | #49 | |
Rep 158
I'm trying to leave this alone, but part of this post bothers the heck out of me. RED: You are aware that a person does not have to be logging for the DME to do its job, correct? Once the DME is programmed how you want it, it handles everything as you programmed it. So I'm not sure why you just said what you said as if the JB4 is doing something special by monitoring. If a person wants to datalog or monitor the DME, they can. The DME doesn't stop doing its job because you're not looking. BLUE: are you aware that you can set the DME to drop as much load as you want it to in response to timing corrections? INSTANTLY. This is NATIVE DME logic. I can program the DME to target 220 load if ZERO corrections/knock are being registered. Then have it target 150 load if -3 correction is pulled. This happens in real time faster than a JB4 can see it. Superknock reactions are different and can be altered as well when they intervene. You know how many JB4 logs I have seen with -6 to -10 retard on cylinders and still targeting boost full tilt? too many to list. Long Story Short, in direct reference to Meth control. With the TB/MC-1 controller, that will kill boost in the event of a pump or meth flow issue with the meth system. Anything else, DME is there for that. If someone wants steering wheel controls, by all means run the JB4. But outside the Steering wheel controls. Flash only with an ECU made to run the car the right way (not altering signal to trick the DME into doing something) is the best way to operate Modern day cars. This will ALWAYS be the case in reference to Performance Calibration and making Power..... 1. Fully Suited Standalone 2. Fully Suited DME Flash Tuning 3. DME Flash w/piggyback 4. Piggyback That order will never change. Unless you happen to be running some old tech ECU from the 80s-90s. then 3 may switch places with 2. We are at a point where Factory DME's are so advanced they can handle everything. |
01-24-2018, 10:00 AM | #51 | |
Rep 115,980
With a flash the DME will knock quite a bit before average timing drops low enough for it to travel down a knock path on load targeting. And the driver will never know what is happening. With the JB4 that logic is fully programmable and can be made as sensitive as you'd like. But the best case scenario and entire point is with JB4 boost only being increased after WMI is flowing sufficiently to support and fuel the higher boost levels so you avoid tip in knock in the first place while WMI is spooling, and avoid knock from sudden flow droppage during a pull, WMI kit failing to turn on, etc. Mike |
01-24-2018, 10:34 AM | #52 |
3441
Rep 79,212
You guys need to try the spray and pray method, it's much easier...
harkes1077.00 terryd5150507.00 |
01-24-2018, 02:38 PM | #53 | |
Rep 182
There is no point leaving the table virtually flat, but raising it across the board when you are running much higher boost and then being surprised when it doesn't react appropriately. Or effectively doing the same by manipulating sensor inputs or taking over the wastegate. |
01-25-2018, 03:03 AM | #54 |
Rep 2,357
I have these two logs showing JB4 meth safety operation. Both logs in Map3 with 50 adder and scaling at 60. Full flow = 20psi. What happens in the time frame of milliseconds - no idea, but boost is being reduced as a result of flow in real time.
(A Dane in China) |
01-25-2018, 03:23 AM | #55 |
Rep 2,357
I am guessing that this is a DME "desperately" trying to control a "too much boost and not enough octane" situation?
Not my finest Map6 moment...
(A Dane in China) |
01-26-2018, 12:06 AM | #56 | |
Rep 752
Or I can't put E85 as the HPFP is already at it's limit? Thanks! |
01-29-2018, 03:54 AM | #57 |
Rep 2,357
So with DME controlling boost an extremely simple on/off system with a Hobbs switch and a relay could be used? On/off work fine with JB4...
Twisted Tuning Last edited by harkes; 01-29-2018 at 04:43 AM.. |
01-29-2018, 04:24 PM | #58 |
Driver
199
Rep 516
01-30-2018, 06:27 PM | #59 |
Rep 2,357
01-30-2018, 08:57 PM | #60 |
Driver
199
Rep 516
02-20-2018, 01:36 AM | #62 |
Rep 100
Reading this thread has me seriously questioning my level of intellect. I feel like there are maybe 10 words used that I understand their meaning in the context in which they were used. There is so much knowledge here and it is so incredibly far beyond my scope of comprehension, it's actually depressing me.
Sorry for the random peanut gallery comment, I'll just let myself out. |
terryd5150507.00 |
02-20-2018, 10:43 AM | #63 | |
3441
Rep 79,212
08-10-2018, 12:31 AM | #64 |
Rep 2,357
zinner
Hi. Just got my CM5-LT. How did you wire it for RPM and MAP (or did you use TMAP) signal? I actually just want mine to spray at +10psi no matter the RPM so maybe that signal isn't even needed?
(A Dane in China) Last edited by harkes; 08-10-2018 at 12:38 AM.. |
08-10-2018, 08:49 AM | #65 |
Rep 801
TorqByte makes and OBD2 plug break out. That’s what I ordered with my CM5-LT. I’ll be installing it later this week.
08-10-2018, 05:49 PM | #66 | |
Rep 2,357
This is perfect. I'll just hardwire it like I did for the JB4 so all looks stock Ehmm, but what about MAP? Should be able to tap into the factory MAP/TMAP?
(A Dane in China) |
