02-20-2018, 02:59 PM | #23 |
A family of bimmers
2745
Rep 7,741
I like the idea of giving a vendor my list of bolt ons and they recommend the tune for my car and i'm able to flash it myself. Im not looking to make it on street outlaws or set any world records but a nice tune to compliment my mods for daily driving is just fine by me. Not having to open up the ECU is a nice perk now as well. OBD flash is awesome. Looking forward to having it done this summer.
02-20-2018, 03:25 PM | #24 | |
3441
Rep 79,212
If you want to maximize power, a custom (or pro tuned) tune will always be ideal. I think a little bit of Jargon and the title of the thread is throwing off what the subject of this thread really is. Is the question if you should get a flash tune or if you should get a pro tune? For most people a professional or custom tune isn't recommended until you are done modding where you can than maximize horsepower. |
02-20-2018, 03:36 PM | #25 |
Rep 1,348
2k15 335i Msport xdrive 6spd
02-20-2018, 03:53 PM | #26 | |
Rep 1,348
However, I think Matty's biggest issue is not being able to run catless without setting off the emissions police. The problem for him is the OTS tunes do not appear to be able to prevent this issue if he does goes catless. So the way to do it he feels is with a custom tune . Folks have told him to purchase a high flow cat which he feels will be an expensive restriction. So he wants a custom tune.
02-20-2018, 05:47 PM | #27 |
Rep 1,206
Ceedawg. Totally. The fabspeed is a beauty. thats the only one I'd consider. It's also 1400. Meanwhile I can get a dp for 250 and make the double the power. Dude. I swear you must Have a serious reading comprehension issue. Why must you say "restriction". Restriction just doesn't fit in this context at all and it's the last time I am gonna respond with that. The idea of the cat or cstless being a bottle neck comes into play when you want to run a lot of boost meth upgrades turbos etc. meaning really pushing the car to make power. However that's not what I am doing and the majority of the threads you are commenting on where you defend your choice of keeping the cat. It's just not relevant. Please get this thru your head. I am going to explain it once more and I know others have. A dp is shown to make great power in this platform. A person like me that wants to run bolt on has choice A where they add a tune ic exhaust and make 320hp and choice b where they run those plus a dp and make 370. I am not sure how the hell the term restriction comes into play. It's a or b. Add power or don't add power. You are talking 500hp applications and it's not relevant here or in other threads when the person is talking about a bolt on daily. JESUS
02-20-2018, 05:50 PM | #28 | |
Rep 1,206
02-20-2018, 06:15 PM | #30 | |||
Rep 965
Drives: 2016 F36 435x MSport
It isn't fairy dust it is because a cat CAUSES A RESTRICTION IN THE EXHAUST FLOW thus creating more backpressure on the hot side of the turbo. An engine is nothing more than an airpump ... more air in = more air out = power. You cannot have one without the other two. EDIT: Do note, there is a HUGE difference between "restriction" and "restrictive". No one is debating the latter here, but certainly the former holds true.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current Last edited by paimon.soror; 02-20-2018 at 06:28 PM.. |
ceedawg467.50 |
02-20-2018, 06:39 PM | #31 | |
Rep 1,206
The way you are using restriction is accurate. The way he is isn't applicable to my or your car. He is saying that a car can make great power with a cat. He says it's Not a "restriction" in making power Bc newer high end cats like those found in high end European cars are efficient. That may be correct. He and, I believe you,have pointed to a few shops that are making 500whp with the stock cat in place. I am saying GREAT. that is the case. I am not debating that. A bmw can make great power with a cat in place. HOWEVER!!!! This concept isn't applicable in MY OWN car and objective. My goal is to make good power via boltons and a tune only. In that case you have two scenarios as I outlined before and commented in your thread. I can make 320ish with tune ic. Or I can make 355-37o with tune ic and DP. I totally don't get the debate. It's well documented. I am not debating that a cat has to be removed to make power, a lot of power . Like not at all. I am saying that for a bolt on lightly modded car removing the cat getting a tune. Running more boost. Installing a fmic to keep it safe will make much much more power than with the stock cat in place. This is well known information. |
02-20-2018, 06:49 PM | #32 | |
Rep 1,206
In case you want to argue further here is his point that he expressed many times that I basically have brain damage from reading. He is arguing about something entirely different than what me and u want to do. And him for that matter (based on what he has written elsewhere. In terms of his own objectives. )
02-20-2018, 06:51 PM | #33 | |
Rep 1,348
02-20-2018, 06:56 PM | #34 | |
Rep 1,348
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 02-20-2018 at 07:03 PM.. |
02-20-2018, 07:11 PM | #35 | |
Rep 1,206
it's you man. You are adding information that isn't relevant at to a discussion/question. It's like you have some stupid axe to grind. It's ridiculous. People like myself or the other guy and some others say they want to run a bolt on car and are trying to decide if they should get a dp. You chime in with oh you can still make power with a cat in place. No shit! But that's isn't the question. You are making comparisons to bolt on cars vs ragged edge 500plus cars. Etc. it's stupid. The correct response, since it's been asked a million times,is, dp can add significant power in a bolt on car. However the draw backs are smell, noise, and emissions. The user must make their own judgement if those things are something they want to deal with for the additional hp which is a significant amount My advice to the other dude is... given the weight of these cars I think a tune isn't enough to keep most happy for the long term. I recommend a dp or if you don't mind spending get the fabspeed. But do something. Bc the gains are significant when removing the stock cat. This is all well Documented. |
02-20-2018, 07:14 PM | #36 | |
Rep 1,206
02-20-2018, 07:17 PM | #37 | |
Rep 1,206
You can be "done"all you want. But you are also completely out of your mind |
02-20-2018, 07:18 PM | #38 | |
Rep 305
Also map switching is a great feature, just because you have 93 everywhere you live doesn't mean you'll find it anywhere when you travel. To be able to switch maps in order to run at safe levels for the octane your dumping in is key for people. Unless your software company has figured out knock adaptation, which most haven't, you'll need map switching if you run anything past 91. |
02-20-2018, 07:29 PM | #39 | |
Rep 1,206
One thing I will add is that when it comes to the power aspect I never trusted dynos. They are all over the place. It's all about the ET AND TRAP. I am pretty sure the guy I am using dyno reports low numbers. I will 1000% be going to strip to get an accurate representation. |
02-21-2018, 08:35 AM | #40 | ||
3441
Rep 79,212
As I mentioned in my previous post, I think there is some confusion on the jargon being used. So I ask, what do you define as a custom tune? What are you referring to when you say switching maps? See with regards to map switching, tunes like JB4 and MHD offer different maps you can select based on octane and mods and that is why there is map switching, in case you change mods (or octane). As far as a custom tune goes, well there are many interpretations of what that means. Are you referring to going to a local tuner and having them flash your car with a tune they made? Or are you referring to adjusting a OTS map to maximize power either locally or remotely. You can also custom tune a JB4 to maximize power too. All these questions are hard to answer without knowing what tuning platform is being used and the end goal. I think it's best to back track to find out what you are really trying to figure out here. I guess you are trying to weigh out all the options and what is the "best tune"? I'll be the first to tell you there is no perfect solution. |
ceedawg467.50 |
