08-31-2017, 04:25 PM | #12409 |
Rep 521
I think I'm going to need new links, my car was updated to the latest i-step by the dealer today to clear an error. Does this require a new e-sys or psdzdata?
08-31-2017, 04:29 PM | #12410 |
Rep 40,654
You can't
08-31-2017, 04:30 PM | #12411 |
Rep 40,654
PM sent.
Araemo190.50 |
08-31-2017, 05:26 PM | #12412 |
Rep 8,364
It does always show if you completely shutdown vehicle and minimize time between reaching car and starting. Otherwise, you will not see it.
08-31-2017, 05:40 PM | #12413 |
Rep 2
Hi I recently got the ENET cable and tried the E-sys 3.28.1 version but don't have the token. Tokenmaster has suspended new activation codes for the time being. I am wondering if you can share the links for the software so that I can code folding mirrors with lock/unlock? Thanks in advance .
08-31-2017, 05:48 PM | #12414 | |
Rep 8,364
08-31-2017, 08:12 PM | #12415 | |
Rep 40,654
08-31-2017, 08:33 PM | #12417 |
Rep 40,654
PM sent.
08-31-2017, 09:26 PM | #12418 | |
Rep 239
08-31-2017, 11:48 PM | #12419 |
Rep 8,364
I see mine every time on all my BMW's. Like I said, timing is key. One thing that helps car sleep is setting electronics to go off when open driver's door. But, you still must minimize time between reaching car, unlocking and starting.
09-01-2017, 07:16 PM | #12420 | |
Rep 9
OK, looking at all the coding options, I *may* want to change a few other things....
Module:FEM_BODY Section:3040 Function:CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK Value:aktiv Default:nicht_aktiv Comment: If Auto-Lock is enabled, then all doors will unlock at ignition shutoff. Since my seat heaters are HOT!!!, I can change (lower) FEM_BODY, 3090, TEMP_LEHNE_FTUFE_*_FRONT to a lower HEX value? (where * is the level 1,2,3 of the light on the dash). Substitute SITZ for the seat bottoms. Also, if I wanted to have the mirrors fold in when the car is locked. I see FEM_BODY, 3110, ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN. It is to "Fold Mirrors when holding lock on Fey Fob or Comfort Access". I don't necessarily want to have to "hold" the lock button down to fold the mirrors. I just want it to fold the mirrors when I lock the car and unfold them when I either unlock the car or unlock then open the drivers door. Is this the right option? I don't see a different one. How do I tell which headunit I have? 6NH, 6NK, or 6NS, what is NBT, or CIC? I have a 2016 with NAV. Thanks in advance? Can't wait to get my cable from Amazon. |
09-02-2017, 11:52 AM | #12421 |
Rep 1,076
Can I get the latest psdz data files? Trying to code an F22 but says no zgw available and hence can't connect via vin.
Also probably need the latest esys version. Thanks! Last edited by Gabreigns; 09-02-2017 at 12:43 PM.. |
09-04-2017, 02:56 PM | #12422 |
Rep 44
Hey gand. Is there a way to reduce sensitivity of the hands free trunk release feature (part of ComfortAccess) via coding, or disable it altogether?
Mine is too sensitive, and sometimes reacts on garage door movements... annoying as hell. |
09-05-2017, 08:55 PM | #12423 |
Rep 1,467
I have 2 FDL coding questions:
1) I am trying to change the animation of the idrive boot sequence to the "M" sequence. The cheat sheet says variant_1. Does that mean change the werte value from "00" to "01"? Or do I chnage werte to "0"? 2) When coding the Sport in iDrive menu by coding: Macro_fds ICMKOD_B_SPORTINDIVIDUALISIERBAR Has anyone heard about getting a fault memory after doing the FDL coding? Someone in the below thread mentioned it produces an error Code in ICM... Post #88 http://f30.bimmerpost.com/forums/sho...1086229&page=3
09-05-2017, 09:03 PM | #12424 | |
Rep 8,364
2. There are often false positive faults when coding modules that affect drivedrain (eg DSC or ICM). If you see anything on the dash/CID, clear with external transmitter. |
Insane435476.50 |
09-05-2017, 10:25 PM | #12425 |
Rep 1,467
Will this show as a check engine light? And what do you mean by external transmitter?
09-05-2017, 10:31 PM | #12426 | |
Rep 8,364
Coding: Getting Started Guides, Tips, & Cheat Sheets - See "4. Helpful Hints & Acronyms" Coding: (No Request) Latest Software Links - See "E-Sys - Install Instructions - v.14.pdf" for external transmitter |
09-07-2017, 02:40 AM | #12429 | |
Rep 8,364
Soul_Glo13343.50 |
09-07-2017, 05:25 AM | #12430 | ||
Rep 7,484
