12-05-2013, 05:24 PM | #1 |
Rep 216
DTC/DSC Sport and Sport +
Ok, so I've read the owners manual on these issues extensively... However,I'm not able to make great sense out of it. I thought that I had it figured out... Anyway, I'm going to explain the way that I understand the different settings and then explain the way my car specifically behaves so you guys can correct me...
Now, before I go on I want to note that I have a 435i M Sport... So, if I understand everything, Eco Pro has the most muted throttle response and the most muted steering feel. The car becomes like an efficiency vehicle and can even do regenerative coasting to save gas. ASS is active always in this mode unless it is manually turned off. DSC is on fully nanny mode unless I turn on the DTC manually with a quick push of that button. Comfort Mode has slightly better throttle response and maybe slightly tighter steering. ASS is active always in this mode unless it is manually turned off.DSC is on fully nanny mode unless I turn on the DTC manually with a quick push of that button. Sport Mode has the tightest steering feel and much more immediate throttle response. ASS is not active in this mode. DSC is still on full nanny mode unless I turn on the DTC manually with a quick push of that button. Sport + is the exact same as Sport Mode with the DTC button pushed. Now, where my confusion begins is that I believed that I could put the car into Sport + and depress the DSC/DTC button for ten seconds which would turn the entire nanny off. Therefore, it would allow me to drive in Sport mode with DSC completely off allowing for whatever amount of wheel spin I can make the car do. However, everytime I have been at a stop and I have the car in Sport or Sport + mode and depress the DSC/DTC button for ten straight seconds, i get the light that DSC is off, and I notice my engine shuts off because I am stopped and it has automatically moved me back in comfort mode... Now, that obviously doesn't seem right. Also, and this seems more straight forward, with the 435i Sport Auto, if I have the car in Sport + and the car in manual shift mode, I have complete control over the shifts, even into the redline. However, if I'm just in Sport mode and manual shift mode, the car will shift itself before the red line... Does that sound correct? Any help, please be gentle, first time owner here... |
12-05-2013, 05:44 PM | #5 |
Rep 216
So, when in Sport mode and I press the button briefly to turn on DTC and it says "Traction" It's supposed to go into comfort mode not the equivalent of Sport +?
12-05-2013, 05:47 PM | #6 |
Rep 139
12-05-2013, 05:51 PM | #7 |
Rep 216
Exactly, my car is 435i MY 14 so it came from the factory like that, and my ASS remembers last setting on start up.
12-05-2013, 05:56 PM | #8 |
Rep 222
Looks like i need a software upgrade. My ASS is active in all driving modes unless manually turned off.
12-05-2013, 06:36 PM | #9 |
Rep 216
12-05-2013, 06:37 PM | #10 | |
Rep 10,509
DSC full off shows "sport settings" on the screen so it is still dsc off with the car in 'sport mode' (i.e. what you wanted should be possible and maybe you had the gearbox in D setting) |
12-05-2013, 07:02 PM | #11 | |
Rep 216
12-05-2013, 07:37 PM | #12 |
Rep 376
I noticed the same thing.. kind of a bummer.. when in sport and sport + and you turn traction all the way off it kicks you back into comfort mode...
12-07-2013, 10:31 AM | #13 | |
Rep 536
One thing I dislike about this car is if I disable all nannies by holding the button down for 10 seconds...it throws you back in comfort So to my knowledge now way to have all nannies off and be in sport mode Im hoping someone will correct me in this as I haven't played with it too much |
12-07-2013, 12:56 PM | #14 | |
Rep 216
12-07-2013, 01:31 PM | #15 |
Rep 387
Yes, as far as I can tell, the only SPORT setting that's missing when you hold down the button to turn off DSC is the extra sensitive throttle mapping. You still get the reduced steering assist and, I think, stiffer shocks from DHP (which I don't have, so can't empirically test for.) You get the sportier AT shift map by moving the gear select lever to the left. I think that disabling the sensitive throttle mapping is a good thing, since with DSC disabled all traction control and some stability control functions are handled by the driver's right foot, and being smooth during high performance driving is very important.
So, to sum up: DTC ON plus transmission in DS equals SPORT+ minus throttle mapping. |
