06-25-2013, 11:19 AM | #1 |
Rep 941
Xdrive...will launching at 6k rpm harm drivetrain?
So I'm really enjoying the xdrive experience in that I don't just sit there burning through first and second gears like my old RWD 335i. I routinely drop the clutch at 6k rpm and boy does this car take off like a bat out of hell. Question is will it likely break anything in the long run?
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
06-25-2013, 11:44 AM | #2 | |
Rep 808
If this is a serious question, you probably should've stuck to an automatic. 2014 AT's come with launch control, even better |
06-25-2013, 01:27 PM | #3 |
Rep 941
Why don't you keep your pointless comments and suggestions to yourself?
06-25-2013, 01:35 PM | #4 | |
Rep 202
Regardless, yes, you will break stuff. She's not made for that treatment. Matt |
06-25-2013, 01:42 PM | #5 |
Rep 6,986
Hell yes, you'll break something - the clutch, u-joints, rear axle...the car was not made to take that kind of abuse.
I gotta wonder sometimes...
06-25-2013, 01:48 PM | #6 |
Rep 941
First gear, no riding just dumping it. Obviously I wouldn't do this on a daily basis but purely at the track on quarter mile timed runs.
06-25-2013, 01:51 PM | #7 |
Rep 941
So assuming a u-joint breaks or worst case a flywheel or axle is it possible that the dealer can pinpoint it to high rpm launch on a leased vehicle?
06-25-2013, 02:09 PM | #9 |
Rep 411
Yes.
06-25-2013, 02:20 PM | #10 |
Rep 254
Drives: E30 M3 & 325ic-F30 335i Xdrive
If you own your car I would stop dumping your clutch at 6K, your putting alot of strain on all of the power train system (Clutch, transmission, XDrive system). I mean you have a warranty, but no car deserves or can with stand that kind of abuse. I would also get an extended warranty to cover the car later on down the road. BMW will mostly know what you have been doing so i dont know what else to tell you. You can keep dumping the clutch at 6K and see what happens .
06-25-2013, 02:37 PM | #11 | ||
Rep 808
Excessive clutch wear/premature clutch failure or other drivetrain problems resulting from this crap won't be covered under regular maintenance or warranty. You need hundreds of gear changes to wear in the clutch and flywheel, or you run into damaging more than just the clutch Also, dumping your clutch at a high RPM isn't exactly the best time wise. There's a sweetspot between traction and RPM's... hence why launch control doesn't take the engine to a redline when you smash the pedal. |
06-25-2013, 02:46 PM | #12 |
Rep 173
most likely the first thing that will get damaged will be your clutch.. probably the slave cylinder. you may have damaged it already... even if it's warped you won't feel it fully.. but the rest of your transmission definitely will.
then maybe your synchros will start to fail due to the clutch not disengaging fully, etc. i'm not familiar with all wheel drive systems.. so anything else that follows suit. you may have also glazed your clutch discs by now too. seems like such a silly thing to play around with considering how many systems you could potentially fail. good luck.
'13 F30 335xi • white/black • m-sport
06-25-2013, 03:07 PM | #13 | |
Rep 941
06-25-2013, 03:12 PM | #14 | |
Rep 941
06-25-2013, 04:08 PM | #15 | ||
Rep 808
I'll stop trolling now. In my last post I was just trying to give you some advice. Break the clutch in for at least a few hundred miles. Dumping at high RPM doesn't mean fastest (probably make a couple tenths of a second difference in a 1/4m). Sure, doing it a handful of times it most likely won't destroy anything, but if you routinely do it, it'll cause a problem. |
06-28-2013, 07:44 PM | #16 |
Rep 59
When abusing anything, it is highly probable that things will start to break. However, the clutch is supposed to take this abuse by being the consumable. Once the clutch is replaced by something more stout, other things will start to break (ie: bearings).
AWD launches are out of this world (came from the evo family). |
06-28-2013, 10:16 PM | #17 | |
Rep 1,075
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
06-29-2013, 03:10 AM | #18 | |
Rep 106
Sorry, couldn't resist... |
06-29-2013, 07:00 AM | #19 |
Rep 436
This.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport |
06-29-2013, 10:24 AM | #20 |
Rep 2,385
Only if you hate your vehicle. My uncle rallies them (tarmac/Targa type events) and it's the one difference between 4WD and RWD is that you cannot just dump the clutch in a 4WD like you can in a RWD because it put too much stress on the drive-train. Or maybe he's just soft on his car because he wants to finish the rally.
06-29-2013, 12:39 PM | #21 |
Rep 646
The car has tremendous torque just off of idle. Can't see where dumping the clutch at 6k will result in a much faster time. That sort of abuse is just putting a lot of extra wear and tear on the car for no real gain. You will break something eventually and then you will just be parked at the side of the road. That isn't fast!
07-03-2013, 02:57 AM | #22 | |
Rep 59
Awd launches puts less drivetrain stress than 2wd launches due to torque transfer/splitting to 4 wheels opposed to 2. Evos are an exception due to very small gearlands from the transverse tranny layout. That's why the 5 speed is the choice for tuners. Still, hell of a lot of fun. |
