07-17-2012, 10:15 PM | #1 |
Rep 70
Cruise Control
Why do I have to turn this on every time I start the car? Is there anyway to leave it on?
P.s. Automatic start stop comes on every damn time. Why not the cruise? |
07-17-2012, 10:39 PM | #3 | |
Rep 158
but I like the setup on my E90. It's ready when I want to set a speed without having to enable the system then set the speed. I'm still waiting on my F30 so I guess it's time to get back in my downloaded copy of the manual. |
07-17-2012, 10:52 PM | #4 | |
Rep 960
In the online manual it states:
07-18-2012, 01:02 AM | #5 |
Rep 4,935
Drives: 340i MPPSK
My hunch would be that it's a safety feature for the vehicle to forget all Cruise Control settings between engine starts, as you'd want the driver to consciously activate and set the system.
Having the car recall a previous state/setting could be dangerous. For example I wouldn't want the car to remember any Cruise Control settings from when my other half was driving the car previously.
Life is a state of mind |
07-18-2012, 02:26 AM | #6 |
Rep 729
My 10 year old E46 switches off the cruise control every time. I'd assumed all BMWs did it. Agreed that it's a little annoying but I'm sure it's a safety thing to avoid them being sued by idiots who don't know what they're doing.
07-18-2012, 03:01 AM | #7 |
Rep 243
On my car the CC has a switch, so it is always "On" or "Off". But i am pretty sure it forgets the last set speed on restart.
I never tested it by pressing recall while on traffic, maybe it does nothing, maybe it goes Toyota... |
07-18-2012, 03:54 AM | #8 |
Rep 35
CC needs two button presses to activate.
First to switch the system on/standby. The second to set the current speed as target. Then you use the rocker to move the target speed around the speedo. Turning the system off from its active state also takes two presses. One to put it into standby and another to turn off completely. This operation makes sense to me. Especially good now that the 'set' button used to be Volume Up if I recall correctly. Much safer... |
07-18-2012, 04:33 AM | #9 |
Rep 243
Sounds complicated, what's wrong with one button to turn on and set to current speed ? I don't see anything dangerous happening if set by accident, it just keep a constant speed, and if you break it deactivate anyway no ?
07-18-2012, 05:24 AM | #10 |
Rep 35
It is more about consciously activating it... Rather than a slip of a finger - especially since it was a volume control on previous models!
The safety aspect is probably most extreme in this example. You're accelerating onto the motorway and the system is accidentally activated as you pass 40mph. You make it to 80, realise you're going a little too fast and take your foot off the gas. After a short delay cruise control decides it needs to brake to achieve 40mph in a reasonable time and the car slows down unexpectedly. There shouldn't be a risk of someone going into the back of you before you work out what's happening - but tailgaters exist and this is a real possibility... |
07-18-2012, 05:41 AM | #11 |
Rep 243
Sounds more like poor ergonomics, my CC is a button at the end of the left stalk, so there is no risk of setting it by mistake.
Safety is a poor excuse, if there is a dual of mishandling making it 2 steps does not change that fact. You could set CC ON before getting on the freeway, then still get what you described. |
07-18-2012, 06:28 AM | #12 | |
Rep 160
2013 335i xDrive
07-18-2012, 07:12 AM | #13 | |
Rep 821
Joking aside, is it really that bad? Every other car I've ever had works the same way. |
07-18-2012, 07:21 AM | #14 |
Rep 243
Lol actually I don't have to press the gas to move forward, I just release the break and cruise at 5mph
And no I don't care the slightest about CC I almost never use it, I am an engineer so I am just curious about poor implementations. |
07-18-2012, 08:27 AM | #15 |
Rep 729
Interesting - I find the exact opposite. I hate driving a car without CC now because I'm constantly having to look down to check my speed. With CC I can just set it and concentrate on the road.
07-18-2012, 09:00 AM | #16 |
Rep 243
That what the HUD is for. Personally I find that CC makes the drive too boring, I prefer to stay alert and play with the car while watching for radars
07-18-2012, 09:47 AM | #19 | |
Rep 15,858
Just give Jeeves the check list.... HighlandPete |
07-18-2012, 10:01 AM | #21 |
Rep 3,307
The wipers I'm on board with not staying on. Keeps them from going on at the gas station every time the attendant cleans my windshield like my Mercedes does.
CC, who uses this so much that it matters? Why but a BMW if you use cruise that often.... Sport mode, that one I agree should be easily programmable in the standard menus, but still, it's just a push of the button. ASS, well that one is deserving of its name and at the very least, should default to off when you go through the labor intensive process of putting the car in sport . Realistically, aside from those they've deemed relevant to safety, all of this should be programmable in the standard menus. It's all computerized, let us configure it how we want. I don't think any of it is worth more than an "ehhh," but no reason it can't be customizable either |
07-18-2012, 10:19 AM | #22 |
Rep 243
That's so true, otherwise it starts to look like your not driving a car but an airplane. Lucky we can code most otherwise It's button fest at each startup...
