BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Anyone successfully retrofit the 2017+ szl / turn signal + wiper stalks?
      09-25-2022, 05:08 AM   #1
anom3
Drives: F30 335ix
I seen it on a few of the non English forums....
Anyone retrofit the newer style stalks with 100% functionality?
      10-08-2022, 01:53 PM   #2
anom3
Drives: F30 335ix
For those that are interested... I just did this.
I used the stalks from an F16 part # 9368591.
It was plug and play. The only thing to keep in mind is if you have a heated steering wheel you need to modify the cabling to the button slightly...
All the info is here (not my page, but I used it as a guide when ordering the part) : https://www.drive2.ru/l/556261075507480217/
      11-26-2023, 07:01 AM   #3
)2dano2
Drives: BMW 420D F33
Hi there
I'm trying retrofit a heated steering wheel but the stalks are hard to find the part number you listed is widely available and a lot cheaper. I read the guide you recommended but it says the heating worked without needing to change anything? From what I could make out from it being Russian. Do you know what wiring needs to change?
I have all the parts just need the stalk
Thanks
      02-06-2024, 02:22 PM   #4
isenc2
isenc2's Avatar
Drives: 340i xDrive Stage 1
Originally Posted by )2dano2 View Post
Hi there
Thanks
In case you're still wondering about this mod, I just posted a review and guide. Mine is a 2016 340i, had the "normal" non returning stalk fitted. Just so u know, the process is pretty involved.
https://f30.bimmerpost.com/forums/sh....php?t=2076804
