01-28-2024, 10:48 PM | #1 |
Rep 20
Help with 6WA Retrofit for HU_ENTRY
Hi Everyone,
I知 trying to do a 6wa retrofit but I知 not seeing a lot of guidance for HU_ENTRY folks. I don稚 have a MOST cable attached to my kombi and I知 pretty sure I don稚 have one in my car at all since I have the standard hi-fi and no NAV. I saw that the MOST cable is needed in order to have Esys read the kombi and to do so, the easiest way is to upgrade my HU. I already did so with an android HU that has Apple CarPlay installed inside of it. It does have a MOST connection so would that work? Is there any other steps I知 missing here or anything else I知 not understanding? Thanks!! |
01-29-2024, 03:27 AM | #2 |
Rep 150
You need the MOST connection between the HU and the Kombi to make the 6WA do its magic.
The coding of HU and Kombi is done with E-sys and the bus used is the K_Can2 |
01-29-2024, 08:12 AM | #3 |
Rep 20
01-30-2024, 12:01 PM | #5 |
Rep 1,758
I also have base cluster and thinking of upgrading. I already did the NBT/EVO ID6 upgrade with larger screen and NAV. Does the MOST cable go between the cluster to those round ports in the large interlocking connector on the back of the radio? (Basically two "pin" round connectors).
2016 428ix, r, 2018 430iC, 2018 330it
