10-23-2013, 05:44 PM | #1 |
Rep 196
Winter Tires for 441M Wheels
Can I run a square setup for the 441 M wheels?
18" M Double-spoke style 441 M 8JX18 ET:34 8.5JX18 ET:47 TireRack recommends 225-45-18 but then offers an alternative of 225-45-18 for the front and 245-45-18 for the rear. |
10-24-2013, 08:44 AM | #3 |
Rep 196
10-24-2013, 08:47 AM | #4 |
Rep 597
Hi
I put Continental TS830P 225/45/R18 RFTs on my 400m (same size/offset as yours). There are only two approved BMW winter tyres in those sizes - the other being a Pirelli SottoZero II. Pics are here: http://www.f30post.com/forums/showpo...&postcount=224 http://www.f30post.com/forums/showpo...&postcount=231 |
10-24-2013, 08:53 AM | #5 | |
Rep 196
10-24-2013, 09:08 AM | #6 | |
Rep 5,140
225/45-18 looks a bit stretched on 8" wheels, will be even worse on 8.5". Since you have X Drive, you should not choose 225/45 front and 245/45 rear, since it could cause damage to the all wheel drive system. For a great look there are two options, either OEM staggered setup with 225/45-18 front and 255/40-18 rear or a square setup with a slightly wider tire, 235/45-18 or 245/40-18. However wider tires will not give you the best performance if you drive in a lot of snow during the winter. |
10-24-2013, 11:55 AM | #7 | |
Rep 196
10-25-2013, 01:00 PM | #8 |
Rep 29,202
Yes, no problem. Go with 225/45/18.
I had 225/45/17 winters on 17x8 and 17x8.5 on my e90, and now I have 245/40/19 on 19x8.5 and 19x9 for my F10.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-16-2015, 07:47 PM | #9 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Bump
Anyone know if these 441M can fit a square setup of 225/40/18 as I already have a set of this size tires I want to use these winter tires and then get a new set for summer Thanks Last edited by ska///235i; 03-16-2015 at 10:30 PM.. |
03-17-2015, 12:53 PM | #10 |
Rep 104
Alternate Square Setup
I have the same wheels, but went with 245/40-18 Michelin Alpin PA4. You will need 10-12mm spacers to run the rear wheels in front.
B |
