07-26-2013, 12:29 PM | #331 |
Rep 623
"irrelevant internet chatter" lol, that's a good one. What an imbecile.
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara |
07-26-2013, 04:14 PM | #332 |
Rep 391
They are indeed a bunch of stupid, lazy dumb a$$holes who take us for idiots. After all the changes to my car there is no way in hell that the noise level is as loud as before... But i was essentially being told that's the way the car is.
Dont accept the bullcrap. Btw frogman did you get your doors adjusted? Oh... One interesting tidbit i will share with you is that when i took my car in two days ago to have the creaky exhaust diverter valve replaced, they noted on my report that the sound proofing i applied on the wheel arch is a non BMW soundproofing part and may be a fire risk. The verbal explanation was that the turbo hose gets really hot in summer, so i need to be sure the material used is fire proof. Not an issue in winter (which is our current season down under). F@ck me man. That thin plastic sh!t wheel arch is directly under the turbo hose.... So is that going to melt and catch fire too? Anyway i will remove a small section, but they need to look at the materials they use! Interesting that they were hunting around under the bonnet to identify this when they were supposed to be fixing the exhaust.
2018 BMW X3 xDrive30i M Sport
[sold]2013 BMW X3 xDrive30d [Sold] 2013 F30 328i |
07-26-2013, 04:37 PM | #333 | |
Rep 1,892
I was worried about the turbo / exhaust heat too. I got that firewall soundproofing material for the arches. I checked the surface temps after a long hot drive, and it was fine; I could keep my hand on the material and it was cool enough to touch. I also put the firewall material in the engine facing side of the foam on the left and right side brake line access holes for the same reason. I'm going to play around the drivers window a bit this weekend, there have been some good suggestions on this thread to see if I can reduce it some more. I'm actually really close to being ok with the noise level, I just a little bit less swooshing / buffeting noise around my left ear (Left Hand Drive) and I'll be happy. |
07-26-2013, 04:56 PM | #334 | |
Rep 623
Client 0. Dealer 1.
07-26-2013, 05:20 PM | #335 |
Too much is never enough
655
Rep 3,079
I think one of the biggest issues is the fact that the glass seems to really transmit a lot of noise from the outside. You may simply be hearing the noise generated by the air rushing over the car. Has anyone mic'd the glass on an F30 and compared it to glass on previous generations. The engineers need to get creative in their quest to keep the weight down. I personally have noticed that I can hear quite a bit of environmental noise when parked with the windows closed.
And I don't think dealers take everyone for an idiot by default. Anything that has to do with someone's individual perception is very difficult to deal with. It's basically Goldilocks syndrome. If scores of people come in with the exact same issue then it might go somewhere. But in the grand scheme of things a 16 page thread on a forum is a terribly small sample. Do a roll call and see exactly how many people are actually experiencing it. It's not 16 pages worth. And no, I'm not defending the dealers universally. Some are tools. But they all aren't. |
07-26-2013, 06:37 PM | #336 |
Rep 72
Try sitting in a parked car on the street with all windows shut and no music - listen to the outside traffic's noise level. Actually a very acceptable isolation.
Now, try driving with a fully open driver's window. You'll notice a ghastly wind noise coming presumably from the mirror area at speeds above 50 mph. Next, try folding the left mirror and drive with the open driver's window again. You'll notice a marginal decrease in the noise level. Next stage would be to detach the left mirror completely and repeat the test. I'm not sure how to do this safely and correctly. My point is: the noise isolation itself is fine and has been designed to withstand a certain noise level (otherwise at standstill you would hear the outside traffic as if it were inside the car). The problem is that something is causing an unproportionally higher noise level at higher speeds - either the outside mirrors or the chassis construction itself. In the first case there _might_ be a solution (one tip is to take a look at the mirror shape of the upcoming F80). Last edited by lightyear36; 07-26-2013 at 06:43 PM.. |
07-27-2013, 02:52 AM | #337 | |
Rep 391
sadly you are correct!
07-27-2013, 07:53 AM | #338 | |
Rep 179
07-27-2013, 10:22 AM | #339 | |
Rep 15,858
The F30 which I had a few weeks ago was no noisier than my E91 330d for wind noise. I still believe precision of assembly could be the main issue, as there seems to be a mix of opinion on noise levels through the build period. Without reading all through this thread again, have any of you guys recently temporarily added something as simple as PVC tape to where you suspect the wind intrudes, or used something like blu-tack on the ends of window seals, trim sections, etc.? To smooth out irregular joints, terminations, or turbulent areas. HighlandPete |
07-27-2013, 07:08 PM | #340 | |
Rep 320
07-28-2013, 03:17 AM | #341 | |
Rep 15,858
HighlandPete |
07-28-2013, 04:57 AM | #342 |
Rep 34
I sealed the inner of the side mirror covers and the wind noise dropped significantly. It seems the noise is coming from a whistling effect when wind passes through the side mirrors.
07-28-2013, 04:59 AM | #343 |
Rep 320
I tried taping the outside, but it didn't seem to help. I have tried using foam backer rod as well by stuffing it around the inside perimeter, but the thing that helps reduce it the most is holding either a rag or a glove over roughly a 5" long section at the top back corner of the window. Although the mirrors have been speculated to be the issue, I certainly don't believe tha to be the case, or not on my car anyway. I have even noticed the noise to be reduced as ambient temperatures are higher presumably causing seals to expand. If I could figure a way to fix this spot, the car would be nice and quiet. Road noise really varies depending on the surface. It ranges from deathly quiet to quite obtrusive. I don't mind that as it adds to the road feel, but the wind noise adds nothing but an annoyance. It's just wrong!
07-28-2013, 05:01 AM | #344 |
Rep 320
07-30-2013, 06:50 PM | #345 |
Rep 144
I thought this thread has been dead so I stopped following. I too had the same wind noise issue, took it to a local dealer near my house 3 times. The shop foreman claimed it was normal and said he tested other cars, which also had the same noise level. I even requested to sit in and test drive with him and he still claimed that noise was normal. After so many times back and forth, I gave up and almost believed in what the dealer told me that the noise was normal. Until recently, I brought the car to a dealer near my work place for an oil service, since I was there I thought might as well give it another try and tell them about the wind noise issue I was having. To my surprised, the windnoise was significant reduced when driving home from the dealer. The service paper says the dealer found excessive gap between the molding on the windshield and the driver's window, they had to replace the molding. I hope that help some of you, I guess the story here is dont give up and try more than one dealer.
07-30-2013, 09:39 PM | #346 | |
Rep 623
07-31-2013, 12:58 AM | #347 |
Rep 144
Im in So Cal, Orange county to be exact. I had my car before and after the wind noise issue was resolved, so I am pretty sure I can tell the different though I have to agree with you that it can be very subjective. I am not sure if being in the passenger seat will help because I can still heard a little wind noise from the passenger side when driving on the freeway if I pay attention and listen close enough. im planning to come back to the dealer and ask them to fix my passenger side but im not sure if they will agree because it is pretty hard to justified and tested. it will require the shop foreman sit in the passenger seat with the driver. And the dealer made a scuff marks on my car :'( but I will save that story for another day
07-31-2013, 11:01 AM | #348 | |
Rep 320
07-31-2013, 11:30 AM | #349 | |
655
Rep 3,079
07-31-2013, 11:47 AM | #350 | |
Rep 320
07-31-2013, 12:09 PM | #351 | |
Rep 227
My noise got slightly better after the dealer adjusted my door. Still wind noise, but maybe 10 or 20% better than before. |
07-31-2013, 12:15 PM | #352 | |
Rep 320
Tags |
noise, wind noise, wind-noise, windnoise |
