12-12-2014, 08:40 PM | #23 |
e92 - 335i
179
Rep 743
JB4 does not use all of the same connectors, it doesn't use the MAF and it taps into the CAN which stage 1 doesn't. Other benefits of JB4 is map 7 and code clearing which in turns allow you to run a catless DP without CEL lights.
12-12-2014, 08:55 PM | #24 |
Rep 187
Drives: 2013 F30 BMW 328i
I just ordered the usb cable and will be going that route as here in Florida there is ample 93 octane.
12-12-2014, 08:58 PM | #25 |
Rep 5,316
Drives: G80 M3 6MT
I know, all I'm saying is the maps that are +3 and +4 psi should preform similarly to running stage 1 in +3 or +4 psi mode
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
12-12-2014, 09:00 PM | #26 |
Rep 187
I think I had not even realized there was more than one setting on the Stage 1. I had to go read up about it. Thanks for posting. It was appreciated.
12-12-2014, 09:15 PM | #27 | |
Rep 5,316
Drives: G80 M3 6MT
Either way please comment back
Scott, Partner
12-12-2014, 10:04 PM | #28 |
Rep 187
I will definitely keep it up to date. There is almost always a trade off.
12-13-2014, 09:27 PM | #29 |
IG @bmwF9xG80
3812
Rep 7,592
Sounds good congrats!
Cant wait to meet with you and compare our tunes.. RaceChip Ultimate here
60-130mph 6.5s X4M #HCP
12-23-2014, 06:42 PM | #30 | ||
Rep 187
12-23-2014, 06:49 PM | #31 |
Rep 5,316
Drives: G80 M3 6MT
Perhaps contact BMS To be sure. They are very quick to answer emails
Scott, Partner
12-23-2014, 06:57 PM | #32 | |
Rep 187
12-23-2014, 10:55 PM | #33 |
Rep 187
Sent an email tonight. They responded tonight. There is only one map on the stage one jb3. There is no 4 psi 93 octane map. You have to install the jb4 for that map. Not a bad expenditure of cash but not what I hoped for. Maybe I will do it down the road. For now I just want to know what map 6 is.
12-23-2014, 11:01 PM | #34 | |
Rep 5,316
Drives: G80 M3 6MT
http://f30.bimmerpost.com/forums/sho...d.php?t=842342
Scott, Partner
12-24-2014, 12:16 AM | #35 | |
Rep 187
12-24-2014, 12:12 PM | #36 |
Rep 187
Bumped the boost to 4 psi and running 93 octane. So far no compromise on drivability, but I also can't really objectively state that it is really cranking that much more power. Definitely not the difference between stock and stage 1. Will write more once I have had some time with it and put it in other modes besides sport and DS.
12-24-2014, 03:15 PM | #37 |
Rep 350
When I install the stage1 bms and put some 100oct gas th difference was very clear at the track. Full stock with only bms stage1 I did 13.7 13.6 constantly.
12-24-2014, 03:49 PM | #40 |
Rep 187
A little more information.
http://www.n54tech.com/forums/showthread.php?t=19049 Found this helpful in understanding what it's doing. |
12-27-2014, 10:07 PM | #41 |
Rep 702
Have had BMS Stage 1 on my 328 w/ Injen for a couple months now and love it, so just bought Stage 1 for my wife's 320 and looking forward to more power in that car! Right now the difference between two is HUGE
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
12-28-2014, 01:42 PM | #42 |
Rep 187
Other than what appears to be worse mpgs I have been enjoying 4 psi and 93 octane with the BMS Stage 1. It pulls hard though it may be placebo and it is a lot less than objective because I also installed an m performance exhaust at the same time. So take it with a grain of salt.
As an FYI the email I received from BMS stated the following, "We don't recommend raising the boost over stock on the 28i models (328/528, etc) as it is preferred if you need additional performance that you purchase the JB4 instead. More information about the stage 1 and JB4 tuners for the N20/N26 engines can be found here: http://www.n54tech.com/forums/showpo...69&postcount=1" |
12-28-2014, 08:25 PM | #43 |
Rep 187
Been a couple days since bumping it up. I have been scooting around with the wife and kid in the car, so nohard acceleration. I have noted a jerkiness during shifting that was not there with 3 psi when half open throttle accelerating. Will play with it tomorrow when it is just me in the car and see if I can get a repeat.
12-29-2014, 06:11 AM | #44 | |
Rep 5,316
Drives: G80 M3 6MT
That's what other people reported. Not as smooth power delivery with 4psi.
Scott, Partner
