08-09-2018, 10:08 AM | #23 |
Rep 14,131
Drives: G82 M4C X-Drive
I really like that red accent! Looks like a high quality product, congrats!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
BMW DIY Guy3090.00 |
08-09-2018, 06:34 PM | #24 |
Rep 3,034
Drives: 2019 M2 Competition
Sorry for the delay.. I took these on the commute home today.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
disintegrator66433.50 |
08-10-2018, 04:11 AM | #25 |
Schmollbraten
12515
Rep 1,985
Looks great, but what happened to the center trim panel? I see against the shiny light a few spots at the lower edge, kinda uneven to the red trim line...?
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
08-16-2018, 07:21 AM | #26 |
Rep 369
08-16-2018, 08:12 AM | #27 |
Schmollbraten
12515
Rep 1,985
Let me guess: You'd started the wrap direction from top to bottom, right? I see that the bottom line of the shiny carbon is wandering more downwards to the end of the panel, which leads me to this.
Its more efford but its worth it to start bottom up, deal with the more wrapping material to move upwards but you are be able to place the lower edge of the wrap direct at the small line of the colored accent line. Its important to place the wrap exactly onto the line and as you had maybe noted at work, this line isnt straight but holds a low angle from the grilles outside to the end. In my opinion its possible to wrap your way but to doing the final cut absolute perfect at lower end is so tricky and could ruin your work. Dont cut the round corner at this time, make your way upwards with the wrap until you're entirely done with it, the overstands are cutted and just the corner is left: Take a hairdryer and heat up the corner a bit, drive the exact shape of the corner with your fingernail or a soft spatula, then use a very sharp small knife or scalpel and cut piece-by-piece off the corner and around. Ensure not to slip over the edge and do some ugly cut-scratches, that happens at first try to me. When done make the final cut and remove the remaining wrap, you're done.
08-16-2018, 08:51 AM | #28 |
Rep 3,034
I will look closer when I am in the car later today, but not noticed anything wrong. IF there are any marks along that lower edge, it would be from me taking that piece on and off like 1,000 times as it was PERFECT when it arrived.
Dang3r12515.00 |
08-17-2018, 01:59 AM | #29 |
Schmollbraten
12515
Rep 1,985
I have circled the areas.
08-21-2018, 09:05 PM | #30 |
Rep 3,034
must have been light, reflection, I dont know what.. looked today and looks fine.
08-22-2018, 02:58 AM | #31 |
Schmollbraten
12515
Rep 1,985
'K, as long as its fine and perfect for you and its maybe really the angle of view.
05-23-2019, 10:41 AM | #32 |
CoolWhip_
Rep 44
Hi - I'm in Canada. The issue with Carbonius (spain), as with oCarbon (US) is that you'd have to factor in import duties and taxes on top of the cost and Carbonius is so much more expensive. Also, you'd have to return your trim to Spain or US to qualify for some refund, so that's added expenses.
I know that oCarbon wouldn't get you the bottom black glossy trim in mint condition (without scratches), as they acquire returned trims from customers to overlay the carbon fiber on top of them. You can always send them your own trims first if they're mint to do the work on them, however, you'd leave your car without trim for that interim period until you get back yours with the carbon fiber on them. ECS tuning sells Carbonius but only for the M4 and as such the pedestal iDrive trim comes with the second hole that a regular 4 series doesn't have. Has anyone been able to source any glossy trim for the F32 from somewhere else or have any suggestions? Any Canadian folks with the same issue? Last edited by F32 M Perf.; 05-23-2019 at 02:00 PM.. |
05-23-2019, 10:46 AM | #33 | |
Rep 1,953
Drives: 2013 328i xDrive
