BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Unexpected Computer Reset
Studio RSR
      06-26-2014, 09:48 PM   #1
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
Last Monday I stopped at my accountants office and when I got back into the car and started it, all the settings had reverted to factory settings.........
Seat settings .
All mirror settings, including mirror dipping on the RHS.
Interior temperatures and AC including flow direction of air.
Music.
Even the TPMS had to be reset.
There are probably a few more settings that I can't remember at the moment.
Has anyone else experienced this phenomenon?
Or is it because the car has the same aversion to accountants and the ATO as I do??
G20 M340iX, Sunset Orange, Tartufo Merino Leather, Pretty Well Loaded, OEM Aero Kit, Drive Recorder, BlackVue Dashcams removed and replaced with ACE 2.0.
      06-26-2014, 10:18 PM   #2
Aapparition90
Aapparition90's Avatar
Australia
193
Drives: 2016 lci m3 mw
2014 bmw 328i  [0.00]
2012 bmw 328i  [0.00]
that is strange, could you restore it using your driver profile by any chance ?
      06-26-2014, 10:49 PM   #3
knightsabers
knightsabers's Avatar
Australia
454
Drives: Audi R8 v10 Spyder
Maybe it could be the 'Power Magic Pro' you installed might have caused it to trigger a reset eg. battery level might have dropped to a certain rate, the system assumed it was going to run flat from external devices & thus cut off and restarted when you started the car up again.
Just a theory but I haven't had this issue before.
      06-26-2014, 11:09 PM   #4
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
I'm not sure how to restore with a driver profile. I'm assuming from your question that you have to save a driver profile to a USB or similar. This is something I have not done. And I am not sure if a driver profile is stored on the onboard computer and related to the particular key that is being used.
It took a little time, but I just went through each option and restored them manually.
      06-26-2014, 11:14 PM   #5
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
It's unlikely to be Power Magic Pro as the battery was fully charged, and I had only stopped the car for 30 minutes. No different to normal operations.
The PMP is programmed to shut down the cameras at 12.0 Volts, so there should have been plenty of battery life available to power the car's onboard systems.
Hopefully, this is a once only glitch. If it happens again, I'll have to investigate further.
      06-26-2014, 11:30 PM   #6
knightsabers
Australia
454
Possibly a glitch then, like you mentioned.
