04-10-2013, 07:01 PM | #331 |
Rep 115,999
04-11-2013, 06:55 AM | #333 | |
Rep 1,975
Keep in mind that gmail had a beta tag for quite a while before they took it off.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
04-11-2013, 09:07 AM | #334 |
Rep 478
Drives: '15 AY F80
When running an E85 mixture should I continue to run map 2?
04-11-2013, 11:36 AM | #335 |
Rep 1,975
Yup yup
04-11-2013, 03:01 PM | #336 |
Rep 556
Drives: 2012 BMW 335I
04-11-2013, 03:43 PM | #337 | |
Rep 1,997
It's real power is that it helps resist detonation because of of how it helps keep the engine cooler, therefore allowing for higher boost, timing, etc. I guess you could liken it to high octane gas + meth combined (slightly exaggerated but you get the idea) |
04-11-2013, 04:18 PM | #338 |
Rep 556
So we should be on map 2 with race fuel?
And we should be on Map 7 if on a 60/40 E85 mixture? |
04-11-2013, 04:21 PM | #339 | |
Rep 556
When I use a mixture of E85 with 91, it feels slower and not as fast as the 100 octane..Still quicker than stock, but still not as good as the 100 octane.. why is this? |
04-11-2013, 04:28 PM | #340 | |
Rep 1,997
In theory, the same E85 mix you referred to should put more power down than the 100oct mix but it won't be that much more, I'd suspect they'd be pretty close (93 alone vs a E85 mix is a difference of about 15 hp). This may be better directed to the tuning experts though. I bet someone from BMS or someone on their board can give you a better answer. Last edited by tdizzle; 04-11-2013 at 04:41 PM.. |
04-22-2013, 05:17 PM | #341 |
Rep 40
sorry if I missed it some where,
I have the previous JB4 Stage 2 for the E9X Would it work on the new F Series 335 ? maybe just with a adapter for the plug ? |
04-22-2013, 05:50 PM | #342 |
Zooombie attaaack!!
136
Rep 1,179
04-22-2013, 06:40 PM | #343 | |
Rep 1,575
Where the E85 mix and 100 mix can produce the same octane rating (example 95 octane) it will take more e85 mix to make the same power than the 100 mix. So the car has to learn that it needs more e85 mix vs. 100 mix... I felt something similar driving back from the e85 station and feeling the power difference as the JB4 adapted...pull one....pull two then once it adapted pull three, holy shit it was FUN. Effortless acceleration...and I only have JB4 & DCI!!! |
04-22-2013, 07:21 PM | #344 | |
Rep 556
04-22-2013, 10:29 PM | #345 |
Rep 1,400
I am running 5.2 gallons of E85 on a full tank.
04-23-2013, 12:38 PM | #347 |
Rep 1,575
I usually put in 5 gallons of E85
08-17-2013, 01:46 PM | #348 |
Rep 905
Mike,
Any updates on the intake as well? I'm looking to do the stage 2/intake combo...thanks.
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph 2008 BMW 135i (Sold) 12.8 @ 106mph |
08-17-2013, 03:04 PM | #349 |
Rep 883
Anyone know what could be expected with a stock downpipe running the E85 with the JB4?
I'm not sure if this would be considered stage two because it's a stock downpipe? Thanks.
08-17-2013, 03:57 PM | #350 |
Rep 1,339
all I know is its not recommended to run stage 2 with a stock down pipe
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
08-21-2013, 07:53 AM | #351 | |
Delivered!
Rep 139
I believe you might be referring to Stage 2, map 2. Map 1 is for stock vehicles, as far as I know. Map 2 is for those with an aftermarket downpipe.
See here: http://www.n54tech.com/forums/showthread.php?t=18588 Text: Quote:
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
