02-07-2014, 03:37 PM | #67 |
Rep 1,997
I think the cold is only part of the issue, as I'm seeing it in far warmer temperatures than others who are blaming it on the cold. It's also a fairly common thing, it seems, on recent BMWs as I saw in in various forums over the past 2 years.
I had my comfort access not work this morning and then get the message (car probably saw a low of 28 degrees at worst over night). Thankfully the car started. I've only not had this warning once this week when I've seen it a few times over the past few months and never in the year prior. SA said bring it in and (obviously) suspects the battery isn't reaching near full charge. Seems the most often issue was 1)Bad cell in the battery or 2) something with the CA door handle sucking juice when it shouldn't. We shall see, but cold weather doesn't seem to play a factor in my situation as I've seen the warning in 40 degree weather. Also oddly enough, my ASS kicked in about 5 mins into my drive in to work. Surely the car is smart enough to keep the engine on if the battery is almost dead right? Something is fishy with my car. I'm thinking I may have the CA problem. |
02-07-2014, 03:39 PM | #68 | |
Rep 160
02-07-2014, 03:43 PM | #69 | |
Rep 160
02-08-2014, 08:33 AM | #70 | |
Rep 345
Notes from the thread suggest a check of the battery and charging system are in order regardless - something to do on my firs/next service visit when/if I ever get my recall notice for the brakes. Still, I'm loving the car now it's winter for the traction vs my old and dearly missed 335 RWD E90.
2017 M240i xDrive Loaded 2013 328 xDrive Premium, Executive 2007 335i Premium |
02-09-2014, 12:46 AM | #71 |
Rep 1,560
Drives: 2022 X4M40i, retired ‘11 X3
This issue is happening on the 5 series and X3 boards as well. Someone on the X3 board said their dealer had found it is an issue with the PDM. BMW is aware of it and needs to redesign the part. For now, there is not a fix. It's amazing how many BMW's across the boards are having this issue. Wish they would issue a recall. I've lost faith in my X3 anytime it is cold out now.
02-09-2014, 07:56 AM | #72 |
Too much is never enough
655
Rep 3,079
Has anyone actually had a situation where the car wouldn't start or is everyone just getting the warning? I can't say that I agree that an aggressive warning strategy is a major defect. They probably just need to tweak the software.
02-09-2014, 08:03 AM | #73 |
Rep 160
The warning is not the problem , the battery discharging for no reason is. Add to that the very slow recharging of the battery and no heat when discharged too much.
02-09-2014, 09:37 AM | #74 |
655
Rep 3,079
Has anyone confirmed that the battery is indeed discharged or does the car just THINK it is? This is the point I was making. The algorithm may just be too aggressive or thrown off by cold temps and short drive cycles.
02-09-2014, 01:16 PM | #76 |
Rep 11
I live in southern California. I got this warning a couple days ago after sitting a day an a half in the garage while I was off work. I took it to BMW, after 2 days they said it was a programming issue, they did "test plans" that BMW told them to do and fixed it. I came the next morning to pick it up and when I started the car the warning came on again. I also noticed the car struggled a bit to start. I went back in to notify the service advisor and they said that they've getting a lot of these lately. They gave me a loaner unitl this gets fixed. Still no update since they're close today.
2013 F30 328i - Current
2007 E90 328xi - Sold 2001 S2000 - Sold 2001 E46 325ci - Sold |
02-10-2014, 09:24 AM | #77 | |
Rep 1,997
02-14-2014, 02:29 PM | #78 |
Rep 478
Drives: '15 AY F80
Just had this happen to me this morning. Nothing crazy as far as weather temperatures. Everything seems to be working fine except I have no music or tones from open door/back up sensors.
I have an appointment to take it in on Tuesday but is there a way to get the music and alert tones back on? |
02-15-2014, 09:37 AM | #79 | |
Panfilo
Rep 27
BMW has to do some reprogramming and maybe install battery tenders for their Canadian cars. I know it's a pain. But if you want heat to your feet we haven't much choice. BTW my wife's TDI is a freezer in this cold weather even with the ceramic heater! |
02-15-2014, 09:48 AM | #80 | |
Panfilo
Rep 27
02-15-2014, 05:00 PM | #81 |
Rep 189
I cannot prove it, but I think it has more to do with a detection issues of some sort, than a low battery. If the battery is cold, it disables a bunch of stuff (note the technical term).
I have had the warning on a few occasions throughout this winter. To test my theory, I never charged the battery, and as soon as the temps go up, the warning goes away and everything is good again. To note, I have never had an issue starting the car even when the temp went down to -35C. The limit temp seems to be around -20C. When the temp was around -30C, I drove at least 900km in a day and the warning remained. I would assume the battery had enough time to recharge on such a long trip. Then when the temp went up, whaddayya know: Gone. Finally, in the past week, when I left home in the AM, temp was at -25C and as soon as I reached work, the warning showed up. The temp went up throughout the day to -8C and when I left in the afternoon, the warning was gone, everything worked with the car staying in the parking lot for 12 hours. I doubt it recharged itself... This is puzzling as hell to me. And my dealer installs trickle charger on every car they deliver, so they know there is an issue somehow. But even when I had the warning last year and I used the charger overnight, it would remove the warning, but it would always come back on cold days as soon as I reached work. So that didn't work either.
2016 F26 Alpine White M40i
2014 F25 Alpine White 35i Sport - Retired 2012 F30 Melbourne Red 335i Sport Line - Retired 2007 E92 Space Grey - Retired |
02-15-2014, 06:34 PM | #82 |
Rep 1,560
This same issue is happening on the X3 boards. BMW claims it is the PDM that is causing all of the issues. They are aware of the problem and are currently redesigning the part.
It's a long thread, but if you read through it you will come to the posts about the PDM. If you want to read more, head over to the X3 board here: http://x3.xbimmers.com/forums/showthread.php?t=931162 |
02-15-2014, 11:38 PM | #83 | |
Rep 160
Current: 2017 330i xDrive M Sport
Past: 2013 328i xDrive, 2008 335XI 6MT, Legacy SPEC.B, MazdaSpeed6(best of all) |
02-16-2014, 10:02 AM | #84 | |
Rep 189
Again, this is my take on it based on my experience, nothing more...
02-16-2014, 11:49 AM | #85 | |
Rep 633
02-16-2014, 11:55 AM | #86 |
Rep 918
FWIW. Ours may sit for a week without use and we have not experienced a "low battery" issue so I'm betting it's some sort of a "technical issue" of no real consequence.
That said, we aren't located in a really cold climate like many of you so....... |
02-16-2014, 02:07 PM | #87 |
Rep 1,560
As said before, its the PDM causing the issue. BMW knows about it and is working on a fix.
02-17-2014, 03:27 PM | #88 |
Rep 1,997
Took it to the dealer last week. Naturally, the days preceding my visit it didn't give me this notice once in 7 days, while it did it 4 times the previous 7 days. Go figure.
They tested it, said the battery was fine and couldn't replicate the issue. Had it sitting for hours and did various tests over 2 days and nothing. They said maybe try not leaving my ipod plugged in and to keep an eye on it and they'll revisit if it starts happening again. Naturally, nothing for a couple days (hadn't had it go off in over a week). This morning boom, back again. Didn't dip below 40 last night and was in the low 50s this morning. Think it has nothing to do with the cold (or my ipod as it was disconnected). They said my battery was at 70% when I brought it in and held a charge after with no issue. Did mention my short trips (95% of my normal trips are under 15 miles each way) could be an issue. No clue why it would pop up after a year of not changing my driving behavior or stop with nothing changing then start up again. Basically, I've got nothing solved and hate taking it to the dealer. |
