10-20-2013, 05:44 AM | #4841 | |
Rep 31
4U2 and 0812 was OK after a "new connection" and "read VO" Is it necessary other coding after VO 4U2 Coding ? HU-CIC ECO_mode nich aktiv |
10-20-2013, 05:48 AM | #4842 | |
Rep 41,048
No matter though, while more work, you can manually FDL Code what you need.
10-20-2013, 09:04 AM | #4843 | |
Rep 31
as follow but is not possibile to flag some options ( see the pictures ) HU_CIC > 3000 HMI > ECOMODE >Aktive HU_CIC > 3000 HMI >HVAC_MSD_EFFICIENCY >Aktive HU_CIC > 3000 HMI >EFF_DYN_SYS_CID >Aktive HU_CIC > 3000 HMI > ECO_FDS_POPUP>Aktive HU_CIC > 3000 HMI > ECO_MODE_CONF>Aktive HU_CIC > 3000 HMI > ECO_ROUTE>Aktive HU_CIC > 3000 HMI > ECO_TIPPS>Aktive KOMBI > 3003 FZG >VERBR_HISTORIE_ENABLE>Aktive KOMBI > 3004 ERM > CTR_HSTY_DISP_KI_APPL >Aktive IHKA > 3000 > ECO_PRO_MODE >aktiv ICM ECU: 3000 -> IcmKod_B_ECONOMIC > verbaut Could yopu help me to find the right options ? |
10-20-2013, 11:52 AM | #4844 | |
Rep 41,048
10-20-2013, 12:01 PM | #4845 |
Rep 383
I must have the wrong info...
Can someone tell me where to code for pushing "lock" on your fob and the mirrors automatically fold in? Not holding the "lock" button, just a quick push. Thanks. |
10-20-2013, 12:13 PM | #4846 |
Rep 41,048
There is no such thing. You would have to code KMFRT_SCHLIESSEN = Werte 00 to make the folding near instant.
10-20-2013, 12:19 PM | #4847 |
Rep 383
That must be it because I did it awhile ago but then the dealer just performed an upgrade and I lost everything.
Can you remind me where that is located? FEMBody? Which # (i.e. 3110)? Thanks. |
10-20-2013, 12:27 PM | #4848 |
Rep 41,048
CAS module on F10, and FEM_BODY on F30.
10-20-2013, 01:35 PM | #4849 |
Rep 230
Hey guys,
A few questions: - I'm supposed to have a free year of satellite radio but I do not see Satellite under Radio at all or anywhere in the menus. Is that something I need to code in or bring into the dealership? - I also have the snap-in adapter (iPhone 4 Media version with the fan) and am trying to watch a video but I do not see the option for "Video" under External Devices > SnapIn Adapter. Does that (menu option) also need to be coded in? - Is there a way to have the folding mirrors fold automatically when you either lock the doors or turn the car off? I have coded it to where you can hold the lock button down on the remote (werte = 00). I was wondering if there was a completely automatic way to fold in every time. |
10-20-2013, 01:42 PM | #4850 | |
Rep 41,048
2) Does car have option 6NR? 3) No. * Check car options at http://www.bmwvin.com/ if you don't know.
10-20-2013, 02:03 PM | #4851 | |
Rep 31
could you check your options & Value for : 3003 ECO_FDS, 3C FDS_MENU_TEXT"n" & FDS_MENU_SIGNAL"n" Thanks |
10-20-2013, 02:08 PM | #4852 | |
Rep 41,048
You need to compare your car to a car with working ECO Pro from the factory.
10-20-2013, 02:22 PM | #4853 | |
Rep 31
you are right, Anybody in the forum has X3 F25 with ECO PRO function from the factory ? |
10-20-2013, 02:25 PM | #4854 | |
Rep 41,048
http://x3.xbimmers.com/forums/showthread.php?t=715297
10-20-2013, 02:50 PM | #4855 | |
Rep 31
http://x3.xbimmers.com/forums/showth...7#post14842767 |
10-20-2013, 07:18 PM | #4856 | |
Rep 230
http://www.bmwarchiv.de/vin/bmw-vin-decoder.html I do have these listed: - S693A Vorbereitung BMW Satellitenradio Preparation BMW satellite radio - S6NRA Apps Apps |
10-20-2013, 07:58 PM | #4857 | |
Rep 41,048
You should have Video function if you have 6NR. I am not sure if there is a "Video" menu option though, or if you just select Plugin, and it plays automatically if you start a video. The device must be in the Snap-In Cradle and not connected to the Center armrest USB Port for video to work.
10-20-2013, 08:06 PM | #4858 | |
Rep 230
10-20-2013, 08:10 PM | #4859 |
Rep 41,048
I don't have 6NF Base Plate so I can't say for sure. Someone with factory 6NF and 6NR needs to chime in an confirm.
10-21-2013, 10:43 AM | #4861 | |
Rep 230
ouch...this comes from my CA:
10-21-2013, 11:40 AM | #4862 |
Rep 25
Hi Shawn,
Sorry to add to the never ending list of peeps in need, but can I get a link to the latest and greatest versions/lists/etc. Thanks for everything you've contributed, G |
