02-29-2012, 01:46 PM | #1 |
Rep 258
Speed limit info, acoustic warning sound?
I read on a swedish BMW forum that if you have "Speed limit information" (se pic below) and when you exceed the speed limit you hear a acoustic warning sound, is this true? If it's true then I dont want this in my car.
/// M-Sport 328i // Packages -- Adaptive Drive-- Drive Comfort -- Function -- Visibility // 19" 403M // M-Sport Brakes // Harman Kardon // Head Up Display /// Last edited by Nero7; 03-01-2012 at 01:53 AM.. |
02-29-2012, 03:41 PM | #2 |
Rep 1,063
I would imagine that you can deactivate the warning. However, I've been unable to find any configuration information on this option in the 2012 F30 owner's manual. Anyone have this option on their 2012 yet?
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
02-29-2012, 03:51 PM | #3 |
Rep 96
It doesn't give a acoustic warning sound. The acoustic warning sound is a 'special' option you can set in the iDrive. If I'm correct the E90 has this iDrive option currently too.
02-29-2012, 04:01 PM | #4 |
Rep 258
Ok, nice to hear that you can deactivate the warning
/// M-Sport 328i // Packages -- Adaptive Drive-- Drive Comfort -- Function -- Visibility // 19" 403M // M-Sport Brakes // Harman Kardon // Head Up Display /// |
02-29-2012, 04:10 PM | #5 |
Rep 101
It's no big deal, you can set it to whatever speed you want. I was playing around with this while my wife was driving the car last weekend. It was at 71 mph, I then changed it to 60 mph and a warning light and beep came on, I then set it to 85 mph.
02-29-2012, 04:37 PM | #6 |
Rep 1,879
Drives: 2012 F30 328i
Is this the speed limit info that reads the speed signs on the street?
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
02-29-2012, 04:45 PM | #7 |
Rep 101
The car we were test driving didn't have the "speed limit info" option that displays the actual speed limit on the head-up display. I was just messing around with the iDrive/NAV and found it in there and played around with it a little. Even if the car had that option I'd imagine you could still set it to any max speed you want and it wouldn't alarm until you hit that set point.
02-29-2012, 08:30 PM | #8 | |
Rep 1,063
02-29-2012, 09:07 PM | #9 | |
Rep 1,879
Hopefully it is indeed possible to either set the speed limits up until when you want to hear no sound, or if to turn the sound on/off or something. I cannot imagine it is not possible but, then again, you never know lol
02-29-2012, 10:55 PM | #10 |
Rep 3,566
Yes it does. Used it once on my E90. The Merc actually limits your top speed selected.
03-01-2012, 02:56 AM | #11 | |
Rep 96
The iDrive option does. Sorry for the confusion |
03-01-2012, 06:19 AM | #12 |
Rep 1,879
That's ok, thanks
03-01-2012, 07:31 AM | #13 |
Rep 1,322
My Audi has something similar. It's good for reminding you if your speed has crept up on long motorway/highway journeys. It doesn't stop me going past the pre-set limit though.
04-13-2012, 07:09 AM | #14 |
Rep 14
I have the speed limit info system in my F10, but the speed limit warning you set in i-drive is quite separate to it and doesn't depend on the speed limit the speed limit info system has captured from the camera/navigation system.
it would make much more sense if the speed limit warning was based on the speed limit the camera system found (eg you are x km/h over the posted limit and you choose what "x" is). They should have made these two parts of the software talk to each other then it would be more useful. However considering how innacurate the speed limit info system is (accurate about 70% of the time in Finland) then the warnings would not be that reliable (mistakes are made both in over and under estimating the posted speed limit). |
04-13-2012, 07:18 AM | #15 |
Rep 3,566
You are, it does, I never use it.
07-05-2012, 02:50 PM | #16 |
Rep 126
Sorry to bump this old thread up-- but a quick question on the 'Speed Limit Info' option.
Does BMW ONLY rely on the cameras to pick up speed limits, or does it use some historical data from the navigation like other GPS (i.e. my Garmin, without cameras, still displays speed limits for every road I am on.) I think it would be more useful if the cameras are used to only UPDATE this info, in case the historical data is incorrect. Best, crow |
07-05-2012, 03:03 PM | #17 |
Rep 4,935
Drives: 340i MPPSK
The Speed Limit display (8TH) option in my F30 uses both the camera mounted in the rear view mirror to detect speed limit signs (as well as temporary speed limit signs and variable speed limit signs on gantries), and the information stored in the satnav (in the UK this option can only be chosen in combination with satnav).
As to the audible warning, this can be set to either a specific speed, e.g. 75mph, or the current speed of the vehicle, or whatever the speed limit is as detected by the Speed Limit display, or it can be switched off altogether. In the few miles I've done I'd say the Speed Limit display is accurate most of the time, plus it picks up changes within a few yards.
Life is a state of mind |
07-05-2012, 04:11 PM | #18 | |
Rep 126
07-11-2012, 01:28 PM | #19 | |
Rep 802
I'm curious whether it displays in both places - i.e. does it display speed limit info in HUD AND on the Nav Screen, or just in one place?
07-11-2012, 02:40 PM | #20 |
Rep 4,935
Drives: 340i MPPSK
The current speed limit can be displayed in the HUD and/or in the Black Panel Display. I haven't seen an option to display the speed limit in the navigation display though.
07-11-2012, 02:41 PM | #21 | |
Rep 126
-crow |
07-11-2012, 03:05 PM | #22 | |
Rep 802
