02-25-2016, 06:00 AM | #45 | ||
Rep 3,946
We'd also need to hold many more variables constant. Because if your contention is that adaptive suspension always makes the rear axle crossing less thumpy, we'd have to quantify it and prove that what you're feeling isn't attributable some of the following but not limited to: 1. Front axle impacts are felt more because there's additional feedback such as steering feedback that isn't part of the rear axle. 2. The exact same chassis isn't set up where the rear axle thump would be less to begin with Also, what's your point of reference? Is it a F10 5 Series? With Adaptive Drive, you would have Active roll bars, no? Let's just say that you are completely right for a moment. The issue here is that the improvement you believed to have felt may not even be mirrored in the F3x's DHP for the fact that the F3x does not have Active Roll bars. A stiff roll bar may help in resisting roll in cornering, but it also makes the axle behave and feel more like a live axle in cases (over road imperfections). If we're talking about ride quality over road imperfections, DHP may help. But the more effective solution is to not use low profile run flat tires. Bottom line: The improvement in ride quality for road imperfections is going to be way more significant going from 19" RFT tires to 18" non-RFT tires than whatever adjustments could be made to DHP for the F3x platform. http://f30.bimmerpost.com/forums/sho...d.php?t=942225 Quote:
02-25-2016, 07:14 AM | #46 | |
Rep 15,858
ARS on the 5-series will make no difference on an axle rise and fall, any more than a fixed ARB. We are talking a straight road here, so an ARB is not part of the spring rate/damping equation in this situation. I've another section of road with a wave of gentle undulations, again a piece of road which tests out any suspension system, both compression and rebound damping. I run onto this section and still wait for the adaptive to be caught out, because it feels too soft as I approach. But again the whole car stiffens as if I was running a much firmer suspension. The section of road is straight so once again ARS won't be the active element in controlling the vertical body movement, it is the damping which has firmed up. I understand drivers like yourself may not be convinced on a system capable of adapting well enough on the fly to make it worthwhile, no problem with that from my perspective. Simply put, adaptive suits me better than a passive sport suspension in my driving conditions, with a whole range of poor quality roads to drive. BTW, I've tested 5-series models 'back to back', and for me there is no comparison for the feeling of body control and composure on poor road surfaces. |
02-25-2016, 07:40 AM | #47 | |
Rep 3,946
Think about a roll bar this way. Why do you think a lot of off-road vehicles have roll bar disconnects? Because on technical off-road courses such as rock climbing, there is a need for greater axle articulation - which is the "rise and fall" - difference in ride height at each end of the axle. For on-road applications, the goal is the opposite... Now let's back up a bit. What's the purpose/definition of a roll bar? "To reduce sway or body roll by minimizing the suspension compression/extension on opposite sides". In order to make that work, the left and right control arms are mechanically linked. An "independent" rear suspension is not as "independent" as it would appear to be now. That means that bumps, vibrations, etc. from one control arm are transferred/propagated to the other control arm to some degree. Why do we use roll bars? Well, it's a pretty damn cost effective way of altering effective spring rate when we need to. But there's a downside, the stiff the roll/sway bar, impacts ride quality. Now if the Adaptive Suspension system works the way you allege it to, it would alter the stiffness of the Active Roll bar depending on the input of other sensors. If the priority was comfort and there were a lot of potholes and you're driving in a straight line, then it should reduce the stiffness to preserve ride quality. The point is that the system you are describing in the F10 5 Series is not applicable to the F3x platform. Now if you were to ask me if I'd get an F30 with DHP in 2016, the answer is most likely "Yes." But not the same reasons you would. I'd get it because it would be non-removable from the Track Handling Package which includes the M Sport Brake. The cost of retrofitting the M Performance Brakes exceeds the cost of replacing DHP dampers one time. Also, the main problem with the 2012-2015 Sport suspension is it's softness - for which the lack of spring is the problem. That problem was addressed in 2016 with the LCI and I'd be more comfortable with leaving the car in stock configuration (Track Handling Package) for it's entire life. Last edited by Polo08816; 02-25-2016 at 07:48 AM.. |
02-25-2016, 08:29 AM | #48 | |
Rep 15,858
ARS is virtually de-coupled in the straight ahead state, it is why single wheel bumps are also softer in the 5-series with ARS. There is no cross axle interference as with a fixed ARB in straight line driving. We are not talking about single wheel movements, or in bends, where the variables of ARB function come into play. Same for the undulating 'straight' road, ARS is not working for or against the adaptive damper rates. The ARB ends/links rise and fall without any cross axle torque, only the friction within the mounting bushes are of note and will cancel out side to side. If we move to driving bends and cross car undulations then we are into different territory, where the 5-series with ARS fitted is not comparable to the 3-series adaptive suspension. Hence not illustrating those situations where ARS really does assist driving dynamics. The ability to tune understeer/oversteer characteristics on the fly, according to how hard you drive is a design function which a driver can sense quite easily. |
02-25-2016, 10:13 AM | #49 | |
Rep 3,946
You're talking about the 5 Series's system which can: 1. Alter effective spring rate 2. Alter dampening characteristics (how quickly is up for debate) Compared to the 3 Series's system: 1. Alter dampening characteristics (again, how quickly is up for debate). They're not the same. They shouldn't be compared. |
02-25-2016, 10:55 AM | #50 | |
Rep 15,858
You are still misunderstanding the way the ARB is not influencing the spring or damping rates on a straight drive. There are therefore very similar characteristics in how the damping can change in that situation for both 3 & 5 series cars. |
02-25-2016, 11:04 AM | #51 | |
Rep 3,946
02-25-2016, 11:24 AM | #52 | |
Rep 15,858
For a moment forget the 5-series with ARS, I mentioned the Jaguar with CATS suspension. That too does exactly the same and gives that 'adjusted' rear axle feel over the ridge type obstruction. That like the 3-series has only got adaptive damping, no active ARBs. Both the Jaguar and the 5-series act the same way over the same ridge with VDC function. Any passive suspensions I've driven over it don't react that way, simply variations on typical passive suspension 'thump outs' of the ridge at the rear. |
02-25-2016, 11:38 AM | #53 | ||
Rep 3,946
02-25-2016, 11:50 AM | #54 |
Rep 378
Drives: '16 340, ex e92 335, ex e46 M3
OMG, somebody gets it. And don't forget another little 'technical term', unsprung weight. I didn't get a third Bimmer because I think it is a thing of beauty, I got it because I think it makes the best compromises available for my style driving. It's a, what would you call it? 'Driving Machine'.
02-25-2016, 05:44 PM | #55 | |
Rep 15,858
Getting back to the key issue, are you saying you don't believe BMW when they say the rear damping can be modified in less than the time it takes for the front to rear axle, to pass over the same pothole? Also that companies like ZF can't achieve that function with suspension systems we have fitted to our BMWs? |
02-25-2016, 06:13 PM | #56 |
Rep 2,266
The two guys with identical cars except for DHP strikes home for me in the fact I have owned 2 F30 335i M-Sports, one with Passive and my current with DHP.
DHP noticeably flatter in hard cornering, and more damping in Sport Mode than Passive. On bumpy roads, and freeway expansion cracks there is a noticeable difference even at speed between Comfort and Sport. The most obvious difference to me between Passive and DHP occurred when driving over speed bumps. Much more damping of the front end with the DHP. I opted to go a step further and got Dinan Springs and ECU Shockware. But that's a whole other story.
F30 Sapphire Black M-Sport 335i 6MT
02-25-2016, 07:07 PM | #57 | ||
Rep 3,946
The problem with what is in bold above is that is NOT what BMW says. http://www.bmw.com/com/en/insights/t...ive_drive.html What they specifically say is this... Quote:
The scenario BMW provides is when the left and right side of the car are traveling over slightly different terrain such as one side being on a gravel surface and the other on pavement, NOT when the front axle has ran over a pothole and the car subsequently adjusts the rear axle's dampening. In fact, BMW's scenario is in line with what Racer20 has stated as the limitations of adaptive suspension. It simply can't adjust fast enough to anomalies (ie. potholes) that are random, nor should it. Think about it! In the scenario BMW actually provides, how would the car know that the left side of the car is driving over pavement and the right side of the car is driving over gravel? It can't make that determination based on just the inputs of the right front corner of the car. To a computer that would just appear to be a bump in the road. It only knows that the right side of the car is driving over a gravel surface if BOTH the right front and right rear suspension were experiencing similar measurements. Only then would it adjust for the right side of the car driving over gravel. |
02-26-2016, 11:05 AM | #58 |
Rep 3,468
Adaptive increases chassis stability. Diving, squatting, weight shift, etc. It's ok, but in general no where near the suspension of my c5 camaro. Shocks were way better there, with the same or less travel. The harder I push the 4 series with the adaptive, the better it feels, to a point at least. Of course, these are passenger BMWs, so I wouldn't expect them to be as good, at least unless we are talking m3/4, but then it's not good enough to justify the price for handling alone, especially with kits like 1LE becoming available at lower price points. If BMW wanted to stay on top of the premium market, they'd offer (as an option) premium/performance suspension in all of their 2, 3 and 4 series, but they really don't, not at any serious level.
02-26-2016, 11:44 AM | #59 | ||
Rep 3,946
Let's work with this assumption: GM's MagneRide system is better then BMW's Electronic Damper Control Here's what Chevy states for their MagneRide system in the Corvette configurator: Quote:
F30 sedan traveling at 75mph with a wheelbase of ~110 inches covers approximately 1.3 inches per millisecond or approximately its own wheelbase in about 100ms. MRC total system delay from input in front axle to output in rear axle: 1 ms Sampling rate ? ms Software processing for all inputs 15 ms Changes to dampening* *this assume GM means it only takes 10-15 ms to change dampening after software issuing the command to change dampening. *it also assumes that it means target level is reach at the end of 15ms, not just started/initated >16ms best case scenario. It appears to be theoretically possible for GM's MagneRide system to be able to change rear axle dampening based on front axle input. But BMW never really provides us with quantifiable properties for it's Adaptive Drive/Dynamic Drive/Electronic Damper Control system. It never even explicitly mentions the front axle vs. rear axle scenario in its literature either... If the system was so advanced/great/fast, why wouldn't it be advertised as such just like GM's MagneRide system. Another way to separate out which events an adaptive system can respond to quickly and which it can't is to look at all the inputs it can process: 1. Cornering - A system can predict body roll from direct driver inputs such as steering angle, speed, etc. to know that the car will roll and make quick adjustments to the EDC to reduce *initial* body roll. 2. Braking - A system can predict dive from direct driver inputs such as brake pedal pressure/travel to know that the car will dive and thus reduce *initial* dive But potholes are another story. The system can't predict that a pothole is coming up because it can't use direct driver inputs to deduce that. Therefore, responses to potholes must be slower because it relies on what the chassis sensors are telling the system first. Also, EDC can only resist body roll and dive. Given enough time, theoretically, it will still reach the same steady state as a passive suspension with similar spring rates. If you want to reduce or eliminate a level of body roll or dive, it will probably need to come from increasing spring rates. Last edited by Polo08816; 02-26-2016 at 11:52 AM.. |
02-26-2016, 04:38 PM | #60 | ||
Rep 15,858
Let's use BMW data (readily available) that there is communication every 2.5ms to/from the EDC satellite control units. That technical data aligns with the BMW 'marketing' blurb for VDC. Quote:
So take a worst case, assuming the proportional valve is open and needs to close under full damping loadings. We have an event time of 5ms plus 35ms to close the valve, a total of 40ms. (Plus 2.5ms if we have just missed a communication). That is worst case, opening the valve is approximately half the time. OK, so we may be twice as slow in reaction times as the GM MagneRide system, but using your own time frame of 100ms, we still have over 50ms "to spare" in the worst case scenario for changing front to rear axle damping rates. Last edited by HighlandPete; 02-26-2016 at 04:48 PM.. |
02-26-2016, 05:53 PM | #61 | ||
Rep 3,946
http://www.bmw.com/com/en/newvehicle...trol.html#more It's dated from 2010 and almost never appears elsewhere even on the BMW USA site. As for the F3x platform, this is more applicable: http://www.bmw.com/com/en/newvehicle...nsion.html#t=l Quote:
02-27-2016, 07:36 PM | #62 | |||
Rep 1,190
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
02-28-2016, 05:09 PM | #63 |
Rep 740
I have a 2012 Sport and I have Adaptive M and in Sport+ I can feel the suspension get stiffer. I have driven in many crappy roads across the US and I can feel the difference. It is subtle, but it is there. In comfort mode the roads around here are a lot more bearable. Also the car had a weird sideways shift with RFT over certain potholes, it is not longer as pronounced with regular UHPAS tires, it is like the sidewalls cause the weird shift.
02-29-2016, 04:30 AM | #64 | |
Rep 15,858
What we do know, VDC I, like the more advanced systems is designed around the Skyhook principle, vertical movement is part of the continuous monitoring under the VDM controller. Front to rear axle/body movements are part of the skyhook regulation. VDC I uses the FleyRay bus, so similar data transmission speeds are in operation for VDC I & II. BMW do state VDC I requires damper adjustment with very rapid cycling, compared with VDC II, which doesn't have such high demands, due to the independent compression/rebound proportional valves. That rapid cycling for compression and rebound control from the same valve is likely its limitation. I can see situations where VDM control would calculate the requirement for low compression and high rebound rates, (or vice versa). VDC II can provide that, VDC I may have to be a compromise. |
02-29-2016, 10:19 AM | #65 | |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
02-29-2016, 05:18 PM | #66 |
Rep 740
Oh you mean between sport and sport+. For me sport+ is the got to and I do not use Sport, but for me sport+ does a bit more than plain sport. It holds the gears in place, mimicking more of a manual than in sport, which will shift. I also have VSS, which feels a bit tighter in sport+. I might have to use sport more often to see if it is placebo or not. In reality, I am usually in Comfort, or Sport+ most of the time. I can feel a difference in handling and road feel between the two.
